Author Topic: PM6 tunage?  (Read 13148 times)
PM6 tunage?
« on: March 05, 2010, 07:48:25 PM »
can someone hook me up with a PM6 tune? i dont have any of that shit anymore. just need something for buddy, needs to work the first time cuz im soldering it to the board LOL.
Y8 with stupid high compression. stock injection. needs 8000rpms redline.  VTEC is one a switch unless its easy to do?
damn its been since forever for a PM6 lol...
Re: PM6 tunage?
« Reply #1 on: March 05, 2010, 08:09:49 PM »
obd0 has a rev ceiling of 7500 IIRC
Re: PM6 tunage?
« Reply #2 on: March 05, 2010, 10:27:27 PM »
The beave say's this:   "The stock PM7 maps go to 7400, and the fuel cut for the DOHC D is at 7800"
I can't say for sure myself...  been a minute since I've even looked at an editor...
So you could use a pm7 map in your pm6 n adjust from there...
http://www.xenocron.com/te.php?page=TEvtec
Oh and how high is "stupid high compression"?  You'll need to pull a lot of timing in the lower revs. to keep it from pinging and it probably willl anyway.  Your bud will probably need a 7 or 8 heat range plug...
I think I read somewhere that ng63 has additional columns that go to 9k...
« Last Edit: March 05, 2010, 10:35:17 PM by Foowee »
Re: PM6 tunage?
« Reply #3 on: March 06, 2010, 12:36:05 AM »
its a D16Y8 bottom end with ZC pistons in it im pretty sure. dont remember what head.
i dont care to edit any maps. im pretty sure he ran this motor a little last year. or a similar one on a stock ECU. he just hates the 6800rpm revlimit, needs little higher to keep from having to shift and fall out of powerband...
Re: PM6 tunage?
« Reply #4 on: March 06, 2010, 09:54:07 PM »
Tell him to not be a Jew like you, spend an extra $1 for a socket just in case.
Re: PM6 tunage?
« Reply #5 on: March 07, 2010, 02:42:02 PM »
he is a cheater.... needs to look stock 8)
Re: PM6 tunage?
« Reply #6 on: March 07, 2010, 02:48:25 PM »
go get an ecu from a 89 teg and call it a day.
Re: PM6 tunage?
« Reply #7 on: March 07, 2010, 08:04:39 PM »
needs to be the stock civic ecu.
Re: PM6 tunage?
« Reply #8 on: March 07, 2010, 08:34:25 PM »
from what i understand, the tune ability for obd0 stops at 7500 but you can take the motor higher.  its just that you need to tune the last row fat.
Re: PM6 tunage?
« Reply #9 on: March 08, 2010, 12:47:09 PM »
Both my pm7 and pg7 ECUs only let me rev to 7500, but then again the stock tach isn't the most accurate either.
Re: PM6 tunage?
« Reply #10 on: March 08, 2010, 02:12:59 PM »
So i take it you can't run a stock obd0 pr3 ecu and bre? they rev higher and from my understanding should be the same inside. you coudl switch the boards in the pm6 case.
Re: PM6 tunage?
« Reply #11 on: March 08, 2010, 02:20:51 PM »
even if it did swap inside, it has a knock board. wouldnt look like the others. and there is the cost issue.
there are a couple PM6's donated to this project. if we where swapping ECUs around it would most likely just get a P06 and can change hte revlimit to whatever we want.
Re: PM6 tunage?
« Reply #12 on: March 08, 2010, 02:30:11 PM »
just socket the pm6 that he has and run a basemap from there
Re: PM6 tunage?
« Reply #13 on: March 08, 2010, 03:51:20 PM »
Re: PM6 tunage?
« Reply #14 on: March 10, 2010, 08:46:02 PM »
Since when did Amtel or SST provide rom chips for pre-odb1 Hondas? ??? Just have him find another PM6, chip & tune it (quick & dirty like a JD tune), then solder the final and sell the other PM6. Profit X2. Just make sure to sand off the Amtel/SST markings and put a gelcoat (circuit board varnish) on it.
