Author Topic: Nuts and BOLTS!?!?!?!  (Read 14192 times)
Deleted User
« on: March 06, 2010, 09:48:44 PM »
2 things first, Integra LCA's in an EJ/EK 2000 civic 2 door? they fitting....my mild research has led me to believe no....
2nd thing, i stripped the nut that holds the strut in place on the top of the bushing on the top hat, but its basically completelty tightened, i didnt strip it on the outside, i stripped it on the inside....how big of an issue is this.... and dont give me my favorite answers like, you car wont start, or it cost 750 dollars to fix plus a blow job.
pics of the lowered wip coming soon!
theidealone
Re: Nuts and BOLTS!?!?!?!
« Reply #1 on: March 07, 2010, 01:32:52 AM »
If its just the nut, replace the fucking thing you lazy fuck. Or at least use another nut as a jam nut on top of that.
« Reply #2 on: March 07, 2010, 01:37:44 AM »
BAHAHAHAHA, you stripped what??????
Or is the strut rod spinning???
Deleted User
« Reply #3 on: March 07, 2010, 02:44:32 AM »
as soon as i posted this i put a jam nut on top i wasnt thinkin good call though....anyone know about the lca's though?
« Reply #4 on: March 07, 2010, 12:31:23 PM »
They go in your car
« Reply #5 on: March 07, 2010, 12:34:56 PM »
They go in your car
yup.  in the rear of the vehicle as well.
« Reply #6 on: March 07, 2010, 12:58:21 PM »
They go in your car
Yup, it will drive like shit without them
Deleted User
« Reply #7 on: March 07, 2010, 02:58:32 PM »
They go in your car
you guys are life savers, honestly ive been stressin for these answers for days now! thanks!!!
« Reply #8 on: March 07, 2010, 04:04:10 PM »
Why dont you take a tape measure and crawl under the car and measure how far apart your lower control arm bolts are and then check the other ones.
Deleted User
« Reply #9 on: March 07, 2010, 05:58:27 PM »
i did not think to do that....or i could take the integra LCA's that i have and place them up to the LCA's under my car now and see if they are similar!
« Reply #10 on: March 07, 2010, 06:26:39 PM »
96-00 Civic rear LCA's are different than any other civic/teg. If you need a sway bar attach point, drill a hole as they're stamped steel.
Second point: get a fucking $10 torque wrench and download a 96-00 civic manual off a torrent. Then you won't get in that bind. Double-nutted will be fine until you try to remove the shock.
« Reply #11 on: March 07, 2010, 06:56:32 PM »
www.hondahookup.com
down load a manuel from there
Deleted User
« Reply #12 on: March 07, 2010, 09:11:53 PM »
www.hondahookup.com
thank you and thank you.....i already double nutted the bitch! and im buyin a torque wrench i b fuckin to many bolts up SMH
