what kind of oczc manifold should i make for my setup?
sinktrap ftw
- 9 (56.3%)
hhh
- 2 (12.5%)
crx
- 3 (18.8%)
oczc
- 2 (12.5%)
Total Members Voted: 16
Author Topic: finished pics!!! --90Turbotegs 1g dx crx, dohc d16a1 vitara build  (Read 104631 times)
90turboteg
  • Rebuildin turbos
Well, heres some info on my pos crx,
its a 1986 dx crx, was red when my buddy got it, he swaped a d16a1 motor in it and ran nitrous for a while, he rebuilt the motor and not long after that i got the car from him for cheap.
i drove it around as a daily driver with just arp goodies and zc head crap with a 75 shot, ran a best of 13.2 @ 106 in Sacramento when my friend had it.
I got bored of the car, and the transmission was super loud from 5th gear bearings being fucked. my friend had previously put a obx lsd in the transmission so no need for that.
My goal is to have around 300-320whp on pump gas and 400+ on race gas, we will see how my stock cams do, i plan on running delta 272s and supertech springs/retainers later on...
So we pulled the swap out to fix the trans, and build the motor for boost, heres the ricer list
Engine block d16a1/dohc zc
Std vitara pistons
fjt i beam rods
arp head studs
clevite bearings std
all new rings/seals/gaskets
new w pump
All machine work done by me at work free
polished crank, decked block, hot tanked, honed, notched block,
welded -10an fitting to back of breather
parkinized cams, polished journals,
complete valve job, new stem seals, decked head.
Running a pretty stock head for now other than having a chris m 74mm tb and spacer
with my ported 89 intake manifold
Boost stuff
homemade manifold-
borg warner s256 turbo with bullseye exhaust housing
dsm bov
sik fmic i got from dustin/turbohf
custom charge pipes/3" exhaust
any boost gauge
steathmode oil line kit
tial 38mm wg
3 bar map sencor
obd1 dizzy, conversion harness and running ec tune
injector clinic 850cc injectors
walbro inline fuel pump
ebay rad and slim fan
and some other shit im forgeting
trans,
all new bearings
, new 5th gear and syncros,
 custom oil mod for 5th gear outer case,
 obx lsd
clutchmasters 6 puck unsprung clutch kit
here are some before pics and pics of current progress
So far after taring everything down ive replaced
Front ball joints,
wheel barings
inner/outer tie rods
put 3" arp wheel studs in the front
replaced all bushings with energy suspention ones
new front rotors/pads
new drums/shoes
new master cly
13" steelies with stock hubcaps
painted engine bay black
and i just built the block today, everything specked in great and turned out good.
Didn't get the head done at work, didnt have time to cut the seats on friday, so i plan on doing it next week and puting the head together. then puting it on next week.
Hopefully my transmission will be done soon, and my clutch will be here early next month so the motor can go back in.
Then i can start progress on finishing up the turbo setup.
Should be fun.
Pic of my friends he351 and shorty in my car before i pulled the motor, still with a red engine bay...
at mission raceway with a 75 shot
mageshack.us/i/l111c39d4a2313ebd1626bb.jpg/][/URL]
pic of engine bay after paint, and after front end rebuild....
IT will be tuned by dave lee, and my goal is to have it on the road in june... i welded my valve cover -10 bungs on also, More updates soon to come...
« Last Edit: August 05, 2010, 01:56:00 AM by 90turboteg »
Re: 90Turbotegs 1g dx crx, dohc d16a1 vitara build thread.Dirty 3rds soon
« Reply #1 on: March 21, 2010, 12:18:39 AM »
This build has hotness written all over it!
« Reply #2 on: March 21, 2010, 12:31:50 AM »
Looks like it will be a great project. The only thing I would change would be the -10 where the breather box was. I think that you will be blowing some oil out of that hole and filling your can since the origanal black box was baffled. Other than that this build is on point, and total sex!  Jew :mexi: O0 :noel:
90turboteg
  • Rebuildin turbos
« Reply #3 on: March 21, 2010, 12:35:16 AM »
ya its coming alog, thanks nogs, ill have pics of geting the head on next week, the valve cover and turbo crap. hope to have it in soon. and more pics of the car. i did bafle the fitting on the back, and im also running a fitting to my oil pan, so anything that does make it in will drain back. Cant wait to get the thing on the road, the rally subaru is geting old.
« Reply #4 on: March 21, 2010, 12:38:01 AM »
So you put a bafle in b4 you welded the bung on?
90turboteg
  • Rebuildin turbos
« Reply #5 on: March 21, 2010, 04:09:37 AM »
ya its kind of weird, made it so any oil draining couldnt make it in there. its weird though, because people keep saying how much bigger of a combustion chamber cc my d16a1 head is but we put my head next to an a6 and there was really no difference. i just think no one wanted to take the time to check it because no one cares about these motors. but i guess theres maybe something im not seeing :mexi:
just ordered my clutch, now waiting on my transmission from gman, and resurfacing my flywheel this week at work. want to have the motor in early next month :noel:
« Reply #6 on: March 21, 2010, 10:39:29 AM »
build is lookin good.
those rods iz gangsta nigga!
« Reply #7 on: March 21, 2010, 12:39:34 PM »
Love the build, are those the long I beam rods?
Ask Chris M if he has a obd1 Zc intake manifold as they flow better.
« Reply #8 on: March 21, 2010, 12:45:36 PM »
my shit from the racecar
« Reply #9 on: March 21, 2010, 12:48:21 PM »
ya its kind of weird, Im reallllllllllllly FAT
90turboteg
  • Rebuildin turbos
« Reply #10 on: March 21, 2010, 03:39:27 PM »
ya they are the long rods, i have a 74mm tb on my 89 intake manifold, so im good on that. if im going to upgrade i plan on making a sheet metal one with velocity stacks.
 just like the rest of the nw crew  :mexi: but my cars not a boat anchor
« Last Edit: March 21, 2010, 03:50:50 PM by 90turboteg »
90turboteg
  • Rebuildin turbos
« Reply #11 on: March 24, 2010, 12:15:23 AM »
well, got the head all done today at work, surfaced it, valve job, cleaned it. new stem seals... and threw it on the head with arp head studs and cometic head gasket today. got it timed, bolted the intake manifold on. gotta put the 74mm tb on tomorrow, put the inner timing covers i forgot before i timed it on, and get all the nick nack shit on the motor. still waiting for my transmission to be finished, and my clutch should be here any day :mexi:
Re: -- MOTORS DONE--90Turbotegs 1g dx crx, dohc d16a1 vitara build thread.
« Reply #12 on: March 24, 2010, 12:23:29 AM »
every thing looks good, but that fram filter has got to go!
90turboteg
  • Rebuildin turbos
« Reply #13 on: March 24, 2010, 12:27:41 AM »
it was free, and its just for brake in, im going to be running honda after i change the oil and all the assembly lube and crap is gone. it will do the job til then. ya i want to button everything up tomorrow, and have to take my flywheel to work to surface it. cant wait, its coming along :noel:
« Reply #14 on: March 24, 2010, 12:32:04 AM »
Nice to see it coming along. Should be a fun ride. What turbo you gona end up using? Is this gona be your dd, or a track car?
90turboteg
  • Rebuildin turbos
« Reply #15 on: March 24, 2010, 12:38:38 AM »
im running a borg warner s256 ett turbo, got it for a good price, and its tits, but my buddy has a garret t3/t4 60trim w/.63 ar exhaust that needs seals, i was thinking of picking it up for cheap and rebuilding it to run it. not sure yet, both will make the power i need. I guess we will see what happens next month, going to be building some crazy custom manifold for it.
and for what the car is, well its my racecar, but im going to drive it alot this spring/summer because its alot better than driving my pos Subaru rally car around. but as soon as i get something better to drive, i plan on trying to make more than 400whp with it. for next season. id be happy to hit around 400whp on race gas this season, we will see, if i don't with my stock head, then i will end up getting the deltas and supertech springs/retainers and see how much that helps.
« Reply #16 on: March 24, 2010, 01:15:41 AM »
best be bringing this shit to mission.
RHMT show down.
90turboteg
  • Rebuildin turbos
« Reply #17 on: March 24, 2010, 02:08:18 AM »
RHMT show down.
oh ya for sure, im hoping to bring it up june/july ish depending on when its all done. have no idea what it will run, guess we will see when its all done. where abouts do you live?
« Reply #18 on: March 24, 2010, 04:02:10 AM »
X a muthafucking thousand.
90turboteg
  • Rebuildin turbos
« Reply #19 on: March 24, 2010, 01:03:24 PM »
thanks nogs, its coming alog slowly but will hopfully be all done by june. i cant wait to take it to mission when its all done, going to be some sad people :yes:
wish i  could get it done for the dyno day but lack of money wont allow it
« Reply #20 on: March 24, 2010, 01:26:40 PM »
good looking build is it gonna be done for dyno day???
« Reply #21 on: March 24, 2010, 01:28:02 PM »
« Reply #22 on: March 24, 2010, 07:03:30 PM »
Probably be done before yours is... LOL
« Reply #23 on: March 24, 2010, 08:54:52 PM »
TRUTH!  :D
90turboteg
  • Rebuildin turbos
« Reply #24 on: March 24, 2010, 11:23:03 PM »
if i pulled about 1000 dollars out of my ass, and didnt have bills for the next paycheck i could make it to the dyno day, but no im most likly not going to make it boosted. im going to ride down with my buddy eric, we are building our vitara setups in the same shop, but he started a while ago, so its almost done. 90 hatch z6 with he351 vitara setup, pretty dam nice setup, all we have to do is some misk wiring and button it up and it will be good to go for the dyno day, other than dave doing a street tune.
We should make a august dyno day too damit  :yes:
going to button everything up on the motor this weekend, and surface my flywheel next week. then get my clutch on when it shows up, and my friend thats rebuilding my trans is taking forever so hopfully it will get done soon....
i havent decided on what i want yet, lmk what u nogs think i should do. i dont really want to go with a run of the mill manifold, because my cars not quite run of the mill...
NEW POLL
« Last Edit: March 25, 2010, 11:11:16 AM by 90turboteg »
Poll sucks, only one voting option.
9TTSAP
90turboteg
  • Rebuildin turbos
 ::) its a semi good poll u ratard
Anything thats painted blue???
90turboteg
  • Rebuildin turbos
fuck blue shit. all about black nog. no homo blue dashes here :-*
Pages: [1] 2 3 ... 5   Go Up
