Pages: [1] 2 3   Go Down
Author Topic: Jearbear's Dirty D  (Read 47082 times)
ochoa
Jearbear's Dirty D
« on: April 01, 2009, 02:02:09 AM »
I have been collecting parts for some time now, finally got the build underway
heres the set up
1988 CRX Si
Engine
D16 ZC
Aries Pistons
Eagle Rods
ACL Bearings
ARP headstuds
Fj Gasket kit
Y8 Head
LSD Clutch Kit  (rated for 385 ft lbs)
Turbo setup
Welded Egay manifold
Wrx turbo
Egay intercooler
DSM 450's
Greddy BOV
Walbro 255
LM1 wideband w/ autometer gauge
EDT traction bar kit
Goal- max out turbo and injectors then upgrade later this summer when i have more funds
all the machine work is being done by my friend at his work
Before
After
Caleb at work
and now
and some milf action FTW
« Last Edit: April 19, 2009, 08:20:01 PM by ochoa »
Re: Ochoa's Dirty D
« Reply #1 on: April 01, 2009, 02:08:44 AM »
pictures of the car too
ochoa
Re: Ochoa's Dirty D
« Reply #2 on: April 01, 2009, 02:35:29 AM »
ill get some up on friday when i go back home and have some time to work on the car
Re: Ochoa's Dirty D
« Reply #3 on: April 01, 2009, 03:20:04 AM »
Fucking rights you will. Buy a bigger turbo too  :P
Re: Ochoa's Dirty D
« Reply #4 on: April 01, 2009, 04:02:01 AM »
something like a 62mm slug
mycarslow
Re: Ochoa's Dirty D
« Reply #5 on: April 01, 2009, 12:32:49 PM »
bout time you do this  boy  :somb:
Re: Ochoa's Dirty D
« Reply #6 on: April 01, 2009, 12:52:50 PM »
Pics of car??
Now!
mycarslow
Re: Ochoa's Dirty D
« Reply #7 on: April 01, 2009, 02:05:33 PM »
just a crx
Re: Ochoa's Dirty D
« Reply #8 on: April 01, 2009, 02:15:02 PM »
I have those wheels also.... ;)
They are light wheels.  Mine are gloss black.
ochoa
Re: Ochoa's Dirty D
« Reply #9 on: April 01, 2009, 06:40:48 PM »
bad news from the machine shop, after block was honed the pistons were under spec so they need to be sent out to be coated and the pins need to be upgraded to handle more boost.... so new plans ....all out race car now i need to get a big turbo. The car is going to be painted olive drab i also have some 16'' black rota slip knockoffs im gunna rock
Re: Ochoa's Dirty D
« Reply #10 on: April 01, 2009, 06:52:40 PM »
That sucks.....
Re: Ochoa's Dirty D
« Reply #11 on: April 01, 2009, 07:23:20 PM »
sounds like you need a better machine shop
Re: Ochoa's Dirty D
« Reply #12 on: April 01, 2009, 08:36:27 PM »
They didnt mic out the pistons before they bored it. WTF. I would have them get you a new block or sleeve it for free
Re: Ochoa's Dirty D
« Reply #13 on: April 01, 2009, 09:19:00 PM »
+1
bb4caleb
Re: Ochoa's Dirty D
« Reply #14 on: April 01, 2009, 09:41:49 PM »
the pistons were suppossed to be .020 over which would have been all fine and dandy but... before honing the block i checked the pistons and they are only .002 over stock bore.  :o and all the cylinders were tappered .002 and one cyl was out of round about .0025. no good. but the only other d block we have arould is a z6 that had been laying in the rain and basically junk. so we honed it to see what we could do and it turned out that they cleaned up ..0055 over what the pistons are....but the pistons recamended ptw is .004 so we are going to send the pistons out for coating and gain .001 so we should only be .0005 over spec. but for engines running high boost ( 30 psi +++) the piston manufacturers usually say to have a little more clearance. so the pistons will be sent out to coat asap and we'll see where that gets us. Have any of you had any problems with the wrist pins breaking???
Re: Ochoa's Dirty D
« Reply #15 on: April 01, 2009, 10:04:57 PM »
How much does it cost to get them coated.
Re: Ochoa's Dirty D
« Reply #16 on: April 01, 2009, 10:08:51 PM »
Thats alot of fucking coating if your trying to build the piston up.
I'd be chewin on someone's ear, machine shop, piston salesman, etc.
bb4caleb
Re: Ochoa's Dirty D
« Reply #17 on: April 01, 2009, 10:16:50 PM »
cost is 16 per piston. and i think your getting the wrong idea on the coating. we are only looking for .001. its pretty common to do. and its not the machine shops fault. we went into it knowing that it was going to be out of spec. but we cant return the pistons so we are just doing what we can do.
bb4caleb
Re: Ochoa's Dirty D
« Reply #18 on: April 01, 2009, 10:26:49 PM »
coating also helps when upper cyl lubrication is weak and helps avoid scratching. so its a win win situation. but it will set us back a little.. o well gives me some time to work on my setup  ; :yes:
mycarslow
Re: Ochoa's Dirty D
« Reply #19 on: April 02, 2009, 01:15:06 AM »
dont like like ill be able to work on mine for some time... im might be losing my DL dang but i might be able to get on  Illinois court supervision for speeding tickets  :) i hope
ochoa ima have to run the rex when my shit box runs  so give me till 2020 haha it might run then
ochoa
Re: Ochoa's Dirty D
« Reply #20 on: April 02, 2009, 02:18:25 AM »
sorry i kinda or made that sound bad. when i bought the pistons the were susposed to be .20 over but the order was over the phone  so they wont take them back now. so caleb is doing what he can to make them work give him a break his mom is hotter than shit
heres some more pics of the slut as it sits now in black primer
« Last Edit: April 02, 2009, 02:35:44 AM by ochoa »
Re: Ochoa's Dirty D
« Reply #21 on: April 02, 2009, 02:24:39 AM »
I couldn't tell if these were older looking young chicks or younger looking old chicks. Nice :yes: The cool thing about older chicks getting plastic sugurey - they do it right. No lopsided boobs, visible scars - just awsomeness.  :evil:
mycarslow
Re: Ochoa's Dirty D
« Reply #22 on: April 05, 2009, 08:57:53 PM »
ne news on the car  :somb:
biscuit
  • 300HP D In the Works
Re: Ochoa's Dirty D
« Reply #23 on: April 05, 2009, 09:27:53 PM »
Are you using the manifold that i sold you Ochoa?
mycarslow
Re: Ochoa's Dirty D
« Reply #24 on: April 05, 2009, 10:14:04 PM »
pretty sure he is
Re: Ochoa's Dirty D
« Reply #25 on: April 05, 2009, 10:51:53 PM »
id moff those miffs.
bb4caleb
Re: Ochoa's Dirty D
« Reply #26 on: April 05, 2009, 11:15:39 PM »
he needs a bigger turbine. mycarslow???????!!!!! your never gonna get yours done so hook him up son   :P
mycarslow
Re: Ochoa's Dirty D
« Reply #27 on: April 05, 2009, 11:22:38 PM »
boy i just called you  you lil fucker i was going ask you to look @ some piston and let me know what you think
Re: Ochoa's Dirty D
« Reply #28 on: April 05, 2009, 11:25:05 PM »
Any of you 3 have a boosted car runing yet?  ;)
mycarslow
Re: Ochoa's Dirty D
« Reply #29 on: April 05, 2009, 11:34:52 PM »
widebody   all 3 of us are still in school ... i for one am just having for fucking around and saving for 375 to 400hp  sohc non vtec ..... mine was running till a nasty boost spike
Pages: [1] 2 3   Go Up
