Author Topic: CARB GURU?  (Read 9281 times)
ochoa
CARB GURU?
« on: March 26, 2010, 01:23:21 AM »
need some imput for my hilbilly setup between being to lazy getting and not getting shit done and not having enough funds to boost my car for the summer im gunna try to get it going na. 88 fox body stock 302. wanna get it going carb'd for a eventual blow through setup just wanna make it work for this summer tho and beast some 13 sec cars.
just looking for some input on some parts i was looking at just wanna get most of them from one place are there better cheaper options and are these good cheap parts to get this bitch back on the road
also is 600 to big or should i only go 500
http://www.summitracing.com/parts/EDL-1406/
http://www.summitracing.com/parts/EDL-2121/
http://www.summitracing.com/parts/FMS-M-6250-X303/
ik some hillbillies hate edelbrock and some hate holley a friend was telling me he prefers edelbrock b/c of its simplicty to jet and tune its carbs
thanks guys
« Last Edit: March 26, 2010, 01:33:07 AM by ochoa »
Re: CARB GURU?
« Reply #1 on: March 26, 2010, 10:00:37 AM »
X cam and stock heads is retarded.  It'll make a bunch of noise and go nowhere fast.  Save that shit for a set of aftermarket heads.
You want a E303 and 1.6 rockers, some decent shelf dual plane IM, and take your pick of 650 Holley/Edelbrock with vacuum secondaries.  The Edelbrock is an easy out of the box carb, the Holley will make more power but you'll have to tweak on it to get it set up and then tweak some more every time the weather changes.
Now get your carbureted bullshit out of my EFI forum.
Re: CARB GURU?
« Reply #2 on: March 26, 2010, 04:24:04 PM »
www.theturboforums.com
it's where I go for my Blow through info.
Re: CARB GURU?
« Reply #3 on: March 27, 2010, 01:15:21 AM »
X303 cams are just lumpy and shitty Imho. E303 ftw. Put a demon on that bitch and call it a day. An x303 will give you mad interference if I remember correctly.
Re: CARB GURU?
« Reply #4 on: March 27, 2010, 01:42:30 AM »
X303 is a good cam, just not for a stock engine.
79fairmont
Re: CARB GURU?
« Reply #6 on: March 28, 2010, 04:02:40 PM »
If it was my car I would,  Get a wolverine 1087 camshaft(or whoever is cutting them now)
A 650 holley will fit the bill and since your going blow thru it will be the easiet to convert(mechanical secondaries if your gonna convert it, yes you can convert a vacuum secondary but it's a bitch).
A weiand stealth intake is a great choice.
Cylinder heads! gt-40's are a cheap upgrade but with the price of afr's,edelbrock's,trick flow, etc its not really worth it to gt-40's on.
Headers,exhaust, and suspension work.
ochoa
Re: CARB GURU?
« Reply #7 on: March 28, 2010, 05:02:20 PM »
going with edelbrock for now for the simplicty of it all and when its time to upgrade im just gunna get a real nice carb im just trying to get it on the road for now witth college student income. Wehn im making some better money this summer ill upgrade and plan on geting some AFR's
the current heads on it are the nasty stock cast ones but when the engine was previously rebuilt by the old owner they went thru the heads 1.72 roller rockers, upgraded springs,retainers,& pushrods gunna port them to match gaskets as well. It will get me by until i can upgrade
« Last Edit: March 28, 2010, 05:05:59 PM by ochoa »
Re: CARB GURU?
« Reply #8 on: March 28, 2010, 07:18:49 PM »
DOHC mustang 427 start up.  427
DOHC Mustang vs 8urSVT Camaro  347
both procharged.  and blow thru
i rode in it with the 347, ive never felt a car pull sideways in 5th on the freeway before.
