Author Topic: got a question about the mini me swap and what timing belt to use?  (Read 11604 times)
jhonda
  • BOATS-n-HOES
ok so i am getting my b7/z6head, motor together now and forgot to get the timing belt so went to autozone and they had two different timing belts to choose a 1.5vtec and the 1.6 vtec i forgot witch belt i needed but was pretty sure it was the 1.6 belt since im using the z6 head. so i got that one. just wanted to double check since this is my first mini-me swap ;D everything else is done just forgot about the timing belt :-X .also anybody know how to wire a OBD1 distributor for a OBD2 wiring harness obd1 has the extra plug with two wires on it but i also have a obd2 b20 dist. that fits my z6 head but either way i am going to have to modify one of my dist. to work with the head THANK YAWZ
Loserkidwac
Re: got a question about the mini me swap and what timing belt to use?
« Reply #1 on: April 01, 2009, 02:27:41 PM »
match the timing belt to the head you are using so yes the z6 is the correct belt to use ;)
2002 BMW 530i Sport
1992 Mazda Miata
1998 K2500 454
« Reply #2 on: April 01, 2009, 02:44:21 PM »
Z6 Belt
Don't forget the cam gear needed
jhonda
  • BOATS-n-HOES
« Reply #3 on: April 01, 2009, 02:47:46 PM »
ok i thought it was the 1.6 timing belt THANKS
