Author Topic: Well its time for a new swap, Im getting kinda tired with my setup  (Read 8800 times)
So here is a pic of what I plan on doing.
RotaryGeek
Re: Well its time for a new swap, Im getting kinda tired with my setup
« Reply #1 on: April 09, 2010, 12:41:51 AM »
What the hell? Where do you even find an engine that big? A cruise ship?
« Reply #2 on: April 09, 2010, 03:52:17 AM »
Off shore boat... You can actually WALK in the crank case of a crusie ship... WHILE ITS RUNNING
« Reply #3 on: April 09, 2010, 03:59:45 AM »
truth, my auto shop teacher had a rod/piston from some fishing boat, it was taller than i was by a few feet. motherfucker had to be 12-15 feet tall and 2-3 foot wide.
turbo4life
« Reply #4 on: April 09, 2010, 04:26:43 AM »
now that is read neck fantasy! its just missing the mallory dizzy and holly carb.
End the fake food.
« Reply #5 on: April 09, 2010, 05:03:14 AM »
 Length: 89 feet
 Height: 44 feet
 Maximum power: 108,920 hp at 102 rpm
 Maximum torque: 5,608,312 lb/ft at 102rpm
« Reply #6 on: April 09, 2010, 06:02:02 AM »
think about how big that mill has to be to make a block that big
Eville140
« Reply #7 on: April 09, 2010, 09:23:31 AM »
 Length: 89 feet
 Height: 44 feet
I bet the specs on the starter motor would even be insanely impressive also.
« Reply #8 on: April 09, 2010, 09:30:24 AM »
 Length: 89 feet
 Height: 44 feet
I remember reading about that motor strange rod and piston configuration.
One the most efficient motors I ever read about.
Whitey
« Reply #9 on: April 09, 2010, 04:20:18 PM »
 Length: 89 feet
 Height: 44 feet
There is no starter motor...They just push it and have Fing Fong Wong pop the clutch... Saves money
« Reply #10 on: April 09, 2010, 07:19:51 PM »
 Length: 89 feet
 Height: 44 feet
actually they have some seriously large compressors and reserviors to start it with compressed air.  on one of those kind of boats if they don't get it started on the first try, it takes like 30 min for the compressors to build up enough air to try again
« Reply #11 on: April 09, 2010, 07:25:49 PM »
They actually aren't quite as cool as you would initially think, they are all gantry style machines. This one is pretty cool though, 200hp ingersoll mill with 24" facemill, .75" axial and 18" radial cut :o
Heavy Cutting on Machining Centre
« Reply #12 on: April 09, 2010, 07:29:47 PM »
Need to just use c4 to start it.  There were some old aviation engines that used to use a shot gun shell to start them.
« Reply #13 on: April 09, 2010, 07:30:34 PM »
Love how there are ladders down into the, uhhh, oil pan?
« Reply #14 on: April 09, 2010, 07:42:56 PM »
Jesus!  That fucker is awesome.
« Reply #15 on: April 11, 2010, 01:51:01 AM »
 Length: 89 feet
 Height: 44 feet
Needs more holset.
