Pages: [1] 2 3   Go Down
Author Topic: Hear SOHC VTAK Scream! LOL FlipNog's Street motor. "The little D15 that Could"  (Read 51431 times)
Times are tough and about to move soon. I'm keeping the 90 hf that had the built motor in it. That will be another thread in a few weeks. PBT Spec Kay twenty four.
Going for a streetable single cam in this bad boy.
Consisting of....
-d15b vtec block with p08's
-Y8 vtec head
-PBT 74mm TB/spacer/im combo
-will send another head for Chris to port. (This will be last on the list)
-crower valvetrain.
-looking to source Akmee cam (probably go crower 3 cam)
-tri-Y sohc header (will get my old buddy to see what he can do) DTR fab
-2.5" exhaust
Hopefully I can break 14's with a sohc. I did it a while back when I had a stock A6 in my old race car body when the 2L gsr was getting built. Ran 14.1 with just a header and cold air. Car gutted to shit with lexan windows and pipes for rear suspension. Lol.
« Last Edit: May 09, 2010, 01:39:51 AM by ApexSilver06MR »
Eggylshatch
  • Pen15 Club President
Re: flipnig's next chapter in the black crx
« Reply #1 on: April 22, 2010, 11:22:46 PM »
So you weren't kidding about the k24 eh?
« Reply #2 on: April 22, 2010, 11:39:29 PM »
Flipfail
« Reply #3 on: April 22, 2010, 11:41:29 PM »
« Reply #4 on: April 23, 2010, 10:52:33 AM »
Bah the nog changes his mine more often then a woman, it will be boosted soon :noel:
« Reply #5 on: April 23, 2010, 02:19:57 PM »
who moved this here?
« Reply #6 on: April 25, 2010, 09:49:45 PM »
You did.
Minor Threat
« Reply #7 on: April 25, 2010, 10:08:59 PM »
Why is it not stickied?
« Reply #8 on: April 26, 2010, 09:39:15 AM »
Why is it not deleted?
Minor Threat
« Reply #9 on: April 26, 2010, 10:48:36 AM »
Zing!
« Reply #10 on: April 26, 2010, 01:20:13 PM »
i think im going to do some rhmt itb's!
« Reply #13 on: April 26, 2010, 10:00:00 PM »
If i was to do a another set of diy cycle itb's for a sohc I would use the busa ones. 45mm plates. With a crower stage 2/3 and a good head I dont see why 150 whp cant be achieved on stock 1.5/1.6 bottom ends. Of course you will need to piston to valve check on the stage 3. the stage 2 cleared d15b vtec pistons no problem.
I have a set of busa ones bored out to 48mm plates I did awhile back if I ever did a street 1.6 dohc vtec which these may end up on the b16b. if not they will collect dust with all the other I lost motivation wierdo idea stuff I do. Maybe Ill have them next to the welded d16z6/d16a6 chamber heads to remind me never to throw time/money into a d series all motor build again.
I also have another set of busa's un touched. No flip nog boring out the cycle itb's will not be cheap. Consider my crack head pricing already x4
« Reply #14 on: April 26, 2010, 10:25:29 PM »
« Reply #15 on: April 26, 2010, 11:13:48 PM »
Well the b16b is planned to get a oem type r manifold cut/ported/welded back together. Composite spacer and a 83mm throttle body. The blowbench will tell me hands down the itb's lose with that setup atleast the cycle itb's.
If I had the luxury of time I would play around with the 48mm units but well thats not the case.
« Reply #16 on: April 26, 2010, 11:20:54 PM »
In other words boost > n/a
« Reply #17 on: April 27, 2010, 03:10:59 AM »
Not for what Im building the red crx si for. Lap times in 110 degree weather on boost=mega dupa overheating.
The b16b will shine out there.
Super awesome video!!
« Reply #18 on: April 27, 2010, 05:10:23 AM »
The black crx is alive!!!! And loud as fuck!
« Reply #19 on: April 27, 2010, 05:16:25 AM »
shit is alive.
got the mysterious JDM smoke for a litte bit with tons of blow-by coming out of the valve cover.
took it for a rip
open header
stock p28
ripped pretty good.  idles great at 750
no CEL's
MAD TITE VTAK YO!
its all good now.   no smoke or anything.
THANKS PBT!
« Reply #20 on: April 27, 2010, 05:19:48 AM »
Just need some boost!
« Reply #21 on: April 27, 2010, 06:32:11 AM »
jdm smoke is free of charge. You better help me bbq at cmi this summer.
« Reply #22 on: April 27, 2010, 06:33:59 AM »
vx timing belt?
If you want a lightened oem pulley I have one for you :noel:
« Reply #23 on: April 27, 2010, 06:43:32 AM »
akmee cams=mia
« Reply #24 on: April 27, 2010, 06:52:25 AM »
Oh the crower stage 2 ran pretty hard in a stock d15b vtech's. I approve of this choice.
Stage 3 I have not played around with and it seems not to many people have and those who have dont seem to share on the interwebz.
SOHCKLR657
« Reply #25 on: April 27, 2010, 09:48:53 AM »
Hey did you leave the y8 cam gear on the y8 head, just wondering cause i put a y7 head on my block with the 88 - 95 cam gear, i heard that the y7/y8 gear advances or retards the cam half a tooth so you had to put on the 88 - 95 cam gear.
« Reply #26 on: April 27, 2010, 10:06:13 AM »
If your are using  y8 head w/ cam gear use a y8 gear. If you have to use any other gear then use an adjustable timing and adv. it 4.5deg in respect to the cam. (9deg in respect to the crank) ;
D I did the adjustable cam route it was a lot easier.
Look at: http://www.d-series.org/forums/engine-building/41363-y8-cam-w-z6-sprocket-z6-cam-w-y8-sprocket.html
Look at first photo attachment.
This thread helped me out. :yes:
Knowing that flipnog has done this before he probably knows this already. :yes:
SOHCKLR657
« Reply #27 on: April 27, 2010, 10:14:55 AM »
Well i know what im doing today hehe im puttin back on the y7 gear hey thanks for the info man, im trying to get this thing done
« Reply #28 on: April 27, 2010, 12:17:38 PM »
this car actually had my stock a6 block and y8 head in the beginning.  i timed it the best that i could.  distributor was almost fully advanced at this time.  this was with a 88-95 cam gear
i do have the y8 gear on it now and i can leave the distributor around the middle area.
all sohc vtak cams are the same.  its keyway indexing thats different on the gears.
« Reply #29 on: April 27, 2010, 12:18:45 PM »
Yeap. :yes:
Pages: [1] 2 3   Go Up
