Author Topic: Mitchell On Demand 1st Quarter 2010 Torrent  (Read 49455 times)
imburne
    • TurboByHOLSET
« on: April 23, 2010, 11:08:18 PM »
Not the original uploader but seeding and wanted to make sure anyone who previously wanted this had a chance to grab it.
Torrent and Comments here..
http://www.demonoid.com/files/details/2198114/?show_files=&page=5#comments
Also Car list here
http://rapidshare.com/files/376633826/CAR_LIST_for_MITCHELL_1st_Q_2010.txt
Seed or Die.
Re: Mitchell On Demand 1st Quarter 2010 Torrent
« Reply #1 on: April 24, 2010, 12:33:03 AM »
MOD smokes Alldata
TTC
« Reply #2 on: April 24, 2010, 01:01:36 AM »
Can someone rapid share it?
hatchboy
  • Bombs Over Baghdad
« Reply #3 on: April 24, 2010, 01:03:59 AM »
ETA
3y 46w
Yes, 3 years. Ut ohhh, nevermind. Down to 1kb a second now.
Great torrent.
« Reply #4 on: April 24, 2010, 02:01:01 AM »
Must be a problem on your end. Average DL speed is 180 kb/sec
soontobeDA
« Reply #5 on: April 24, 2010, 02:18:55 AM »
awesome, i have the full alldata 09 and it did me good
can't hurt to have another program
hatchboy
« Reply #6 on: April 24, 2010, 10:33:26 AM »
Getting around 160 now that i let it go through the night, still going to take a week.
« Reply #7 on: April 24, 2010, 01:30:14 PM »
That sounds about right
« Reply #8 on: April 24, 2010, 03:10:18 PM »
Anyone who was part of the old HMT torrent, no need to reinstall just grab the data discs.  When you point your existing MOD5 at the first one it knows there are supposed to be X more discs with data on them.
hatchboy
« Reply #9 on: April 24, 2010, 05:03:59 PM »
Averaging 188 with 4 days 12 hours left. Damn, that is a long time. Longest downloading file i have ever downloaded
« Reply #10 on: April 26, 2010, 03:35:46 PM »
when i try to download it with utorrent it says one of the files is too large and will not save properly.
anyone know what i'm doing wrong?
likely your HDD is almost full.
« Reply #11 on: April 26, 2010, 04:10:20 PM »
EBT cards will not buy hard drives larger than 60gigs in size.
« Reply #12 on: April 26, 2010, 05:50:34 PM »
50% smoochie boochie, bitchez
« Reply #13 on: April 26, 2010, 06:13:32 PM »
You need to format the drive to NTFS, you are probably in FAT32 which has a 4GB file size limit.
hatchboy
« Reply #14 on: May 01, 2010, 02:43:25 PM »
download complete!
Now to figure out how to mount and install all these. hermm.
Does this need to be cracked? Whose got a key?
« Reply #15 on: May 01, 2010, 03:08:16 PM »
holy shit!, was about to start the download but noticed it was 73Gb lmao
« Reply #16 on: May 01, 2010, 03:12:33 PM »
I got 25 bucks for someone who want to burn me a set of these cd's
hatchboy
« Reply #17 on: May 01, 2010, 03:16:35 PM »
has anyone successfully installed this yet? I got the program installed but can't import data because i need a key floppy disk. The emulator thing that came with it wont run on vista 64 bit
TTC
« Reply #18 on: May 01, 2010, 03:39:13 PM »
It would take me a decade to DL that at home on my shitty dsl.
« Reply #19 on: May 02, 2010, 11:04:04 PM »
Works great.
The VFD program doesn't work on Vista/Win7 64 bit. All you have to do is put those key files on a USB drive and change it's drive letter to A:, then you can import everything.
« Last Edit: May 02, 2010, 11:10:16 PM by jagojon3 »
hatchboy
« Reply #20 on: May 03, 2010, 08:04:19 PM »
Works great.
Fuck i dont have a flash drive here. Any way i can mount it as a disk image through DAEMON?
soontobeDA
« Reply #21 on: May 03, 2010, 09:30:05 PM »
yep
i need more HD space!
or delete pr0n HAH
« Reply #22 on: May 07, 2010, 12:24:14 AM »
Works great.
I haven't tried it, but it seems like it might work as long as you mount to drive A:
imburne
    • TurboByHOLSET
« Reply #23 on: May 13, 2010, 02:34:03 PM »
Torrent starting to move finally. Get it while its hot and seed this! 75 gigs needs plenty of help.
SQ is the SQUAD
« Reply #24 on: May 30, 2010, 11:06:35 PM »
looks like its time for me to get the tb external harddrive
« Reply #25 on: May 31, 2010, 12:21:55 AM »
Might as well go for 2 TB
« Reply #26 on: May 31, 2010, 01:03:15 AM »
« Reply #27 on: May 31, 2010, 01:15:29 AM »
borrowing my friend's 1.5TB external to DL this.
« Reply #28 on: May 31, 2010, 01:18:41 AM »
I'd shy away from 2tb drives, even some 1.5's. They seem to be having a much higher failure rate than normal.
« Reply #29 on: May 31, 2010, 01:40:20 AM »
Its on an external hard drive, if you are coming up to visit like you say you are, Princess.
