Author Topic: Creating uttorent backup list  (Read 6126 times)
« on: May 29, 2010, 01:01:33 AM »
Ok so I'm getting ready to reformat one pc so I'm wanting to transfer the twenty eight games I have seeding to my other PC and just pick up seeding there. Getting them to the other pc is easy, but is there anyway to backup my seed list to just open it on the other pc and start seeding?
Re: Creating uttorent backup list
« Reply #1 on: May 29, 2010, 01:07:13 AM »
I assume you don't have the option enabled which saves the .torrent files somewhere on your computer?
Just redownload the .torrent files from whatever site you got them from. When they open in your new utorrent point them to the file location. They will check and then start seeding.
« Reply #2 on: May 29, 2010, 02:38:39 AM »
C:\Users\Doug\AppData\Roaming\uTorrent
Backup
Restore
uTorrent should have it all loaded.
« Reply #3 on: May 29, 2010, 09:22:04 AM »
The seed files also need to be in the same directory location.
« Reply #4 on: May 29, 2010, 03:45:43 PM »
I know that, that's what I was trying to avoid.
Backup
Restore
I'll give that a try
So then I need to rename the location on the new PC to mirror the one on the old one?
« Reply #5 on: May 29, 2010, 04:35:51 PM »
Do you not have a secondary or external all your files are on?
They will need to be in the same path or the torrents will say "file not found" or re-download them.
I have a "torrents" folder on each drive with the torrent to every file that is being seeded.
:D  Usually I'll just save the program data/utorrent folder if I'm reformatting, but worst case I have all the torrents save and just need to open them all.
I'm still not done finding all the torrents for the files I have...only two drives done so far :(
« Reply #6 on: May 29, 2010, 05:04:26 PM »
Backup
Restore
Why are you trying to avoid that? You could've had it done by now, it's not hard at all.
« Reply #7 on: May 30, 2010, 07:17:09 PM »
Backup
Restore
You underestimate my laziness.
« Reply #8 on: June 15, 2010, 08:51:23 PM »
Backup
Restore
If you were lazy you'd pee in the shower.
« Reply #9 on: June 16, 2010, 02:08:49 AM »
Backup
Restore
I take a shit/piss before I get in the shower, so that would be more work to muster up more urine.
