Author Topic: Wheel bearing removal/instalation tool? Any body use this HF one b4?  (Read 7309 times)
Was wondering if anyone has used this HF bearing tool b4? I saw a writup online with some dude using same kind of set of tools, but that tool set was a nice one that cost $500+ so let me know because Im about to take on my first try here in a few days. If worst comes to worst I will take the hubs off and take it down to the machine shop and have them press my bearings in/out.
 http://www.harborfreightusa.com/usa/itemdisplay/displayItem.do?itemid=66829&CategoryName=&SubCategoryName=
i wish we had a hub tamer at work.  Those things are fucking bad ass.
I have pretty much always pulled the hub off, and used a shop press to get shit done.
If you try it out, be sure to post up how it works out.
I gots the hub tamer, it works ok.
i take spindles off
use big hammer and a punch
you hammer them back in  ???
I was new at it..........
lol, they dont like that  :P
Never had an issue doing it that way.
BangBusMaster
Hammer time
narfdanarf
I have a press.
SDRAWKCAB
  • D series BALLA!
  • Rhino
Re: Wheel bearing removal/instalation tool? Any body use this HF one b4?
« Reply #10 on: May 31, 2010, 10:55:28 AM »
REMOVAL
BFH
INSTALL
Bearing in freezer over night
Heat hub in oven
drops right in.
« Reply #11 on: May 31, 2010, 11:22:46 AM »
Well i think im gona buy the hf tool probably next week and give it a shot. Nar, my step dad has a press too, but it looks like this tool is 10x easyer than coming up with some nigger rig setup for a press. Ive used a press b4 and it works ok IF you have the right sized cups and shit. I also am going to do upper & lower ball joints, and extended wheel studs.
« Reply #12 on: May 31, 2010, 01:08:35 PM »
Press and a couple large sockets.
« Reply #13 on: May 31, 2010, 04:10:29 PM »
and two wrist pins.........
use the wrist pins where the caliper bracket attaches, then a socket by the tie rod.
Knuckle sits level and easy to press. Next time I do wheel bearings I'm gonna make a small jig as trying to balance everything is a PITA.
« Reply #14 on: May 31, 2010, 06:16:04 PM »
... Next time I do wheel bearings I'm gonna make a small jig as trying to balance everything is a PITA.
This.
It seems I end up with like 3 steel plates and 4 blocks of wood, and a small cambodian child, just to try and get it to sit still. The actual pressing is only a few seconds, the setup is where the time is.
