Author Topic: obd-2 to obd1 conversion?  (Read 16874 times)
MAJORAHOLE
  • fuckin C-unt
« on: June 08, 2010, 10:17:52 AM »
is that a bitch, i have z6 in my 95 and i found a 96 shell in decent condition for $900. i havent bought it, not sure if i will, but is it a total bitch to change?
also been looking the newer 96-2000 hatches too
Re: obd-2 to obd1 conversion?
« Reply #1 on: June 08, 2010, 12:50:59 PM »
It's pretty simple, if you can put a z6 into an eg, you can put one in an ek
MAJORAHOLE
  • fuckin C-unt
« Reply #2 on: June 08, 2010, 12:55:31 PM »
i have never swapped a engine before, the my 95 is an ex and it came in there. i just wasnt sure if the harness and everything needed to be swapped too
« Reply #3 on: June 08, 2010, 01:11:32 PM »
Use the 96 wiring harness, if it exists, and buy an OBD2A-OBD1 jumper to plug your ECU into.
I do not recommend trying to fit your 95 wiring harness into the 96 - that you have to ask about it lets me know you'd be in over your head.  I could do it, have done it, but what I'd charge to do it is a bit more than buying another engine harness.
« Reply #4 on: June 08, 2010, 01:18:12 PM »
Good luck finding a 96-98 EX engine harness for a decent price.  You better plan on doing your own VTAK wiring.
MAJORAHOLE
  • fuckin C-unt
« Reply #5 on: June 08, 2010, 01:33:24 PM »
NOTHING IS OVER MY HEAD!!!     j/k now that im thinking about it, i might want to leave the harness in my old car, so later i can put another engine in it and sell it as drivable, though i dont know.
nothing solid yet, just somewhat planning it out. id really like 92-95 hatch, there are a few within 250miles that run, but dont look all that great
MAJORAHOLE
  • fuckin C-unt
« Reply #6 on: June 08, 2010, 01:35:15 PM »
just looked and that shit is pretty cheap, ill probably do that if i need
« Reply #7 on: June 10, 2010, 04:25:31 AM »
you will need the 96-00 d series driver side bracket also
Plus figure out what dist you want to run. You can hack up a obd2a d series dist to fit onto the z6 head 2 bolts will line up after some grinding/large washers to mount too if you dont want to do any re pinning of the obd1 dist
You also if the car is a dx/lx/cx convert the iacv to a 2 wire. The d16y7 comes with a 3 wire iacv which is mounted on the throttle body unlike the d16z6 which is on the intake manifold
You also will need the 96+ d series rear transmission bracket d series.
« Reply #8 on: June 10, 2010, 11:29:43 AM »
I mapped out the conversion for my prelude to go full obd1 and its a shitload of work. Its not really difficult, you just need to be super organized as it is very tedious.
« Reply #9 on: June 10, 2010, 11:51:28 AM »
You must have some Prelude that I've never seen before.
mrgreengenes
« Reply #10 on: June 10, 2010, 03:49:51 PM »
must be doing it the hard way... pic from his garage...
« Reply #11 on: June 10, 2010, 03:57:31 PM »
why are we talking about preludes?
« Reply #12 on: June 10, 2010, 07:04:21 PM »
more work than i wanted to do.
« Reply #13 on: June 10, 2010, 08:21:12 PM »
« Reply #14 on: June 12, 2010, 09:51:18 AM »
Two hours?
« Reply #15 on: June 13, 2010, 05:55:35 AM »
Wow, did someone not realize most of the car wiring is NOT part of on-board diagnostics? My first major rewire was obd0-1 combined with mpfi conversion. The most time consuming part was soldering and, which was juuuust beyond the time needed of finding a decent shielded wire for the added dizzy sensor. Anyone not using a decently constructed jumper is either poor as fuck or is a completely anti-social anthropophobe.
MAJORAHOLE
  • fuckin C-unt
« Reply #16 on: June 14, 2010, 12:40:26 PM »
well this whole idea is on hold for now, thanks to the michigan police....
« Reply #17 on: June 14, 2010, 11:52:10 PM »
Two hours?
eh, i remember what i was doing.  I had a fucked up engine harness, had another harness but it was OBD1.  I mapped out the shock tower plugs, not all the way to the ecu.  That took a little while and after getting it all done, i found a obd2 harness for 50 bucks so i went the easier route.
