Author Topic: My cylinder bores: opinions  (Read 18465 times)
Re: My cylinder bores: opinions
« Reply #30 on: June 15, 2010, 01:38:28 AM »
That's your 120-130ish IQ speaking.
Inexperience, actually. Like I said previously, I've built about or less than 20 engines total. Nowhere near the level of some of you guys, which is why I am here.
  But I would like to know what I am not seeing. Is that shiny spot above (in the pic) the piston p2w clearance (or canyon), making it out of round? Or (more likely) am I completely off base?
« Last Edit: June 15, 2010, 01:41:36 AM by keelay »
« Reply #31 on: June 15, 2010, 01:39:17 AM »
i spend my days fixing other shop mistakes and my weekends getting drunk.
help me figure out how to get out of bed with a hang over on the weekends to go to a junk yard just to pull shit apart and i will  :)
« Reply #32 on: June 15, 2010, 01:48:41 AM »
Also looks to be sitting to low in the cylinder in relation to the piston next to it. Which would cause that light shining through that I mentioned above.
« Reply #33 on: June 15, 2010, 01:52:26 AM »
At least you don't have this guy's problem.
Looks about like throwing a hot dog down a hallway.
« Reply #34 on: June 15, 2010, 06:07:30 AM »
 ;D  Only car motor I've ever built.  This is what bad machining looks like.  When I put the pistons in they were almost that bad.  Machinist said "Oh well I called CP and bored to their specs."  See all the black shit on everything?  I forgot to put the dowels in the head when I put it together...
60k miles later this is what you have, gentlemen...  I cleaned the surfaces off last night, took some hours and my fingernails are all fucked up.  JD says to hit is with some rubber finger doohickey.
Basically I've had a blown headgasket and wallowed out bores for 60k miles and it has taken every bit of it.  40 of that has been boosted.  This is how you build motors, sirs.
« Last Edit: June 15, 2010, 06:12:22 AM by jabberwock »
« Reply #35 on: June 15, 2010, 09:19:25 AM »
I suspected a head gasket issue, but wasn't really sure. At least I got the wallowed out bores from that pic
« Reply #36 on: June 15, 2010, 12:12:06 PM »
"It must be the lifters"
« Reply #37 on: June 15, 2010, 01:43:05 PM »
Yeah head gasket was non existent.  I mean it was there, it just had black shit caked all over it.  Maybe the lack of dowel pins had something to do with that?  LOL
« Reply #38 on: June 20, 2010, 01:35:54 PM »
Holy P2W clearance batman.
« Reply #39 on: June 20, 2010, 02:04:28 PM »
That's not a p2w issue, thats a pistons-too-small-for-the-bore issue. Or the machinist is just a complete idiot.
« Reply #40 on: June 20, 2010, 06:06:26 PM »
This plus 60k miles = forged pistons lol @ soft sleeve metal
