Author Topic: Disassembly of tial 38mm wg  (Read 15094 times)
TTC
« on: June 26, 2010, 10:03:36 AM »
Hey fellas, my Chinese tial knock off seems to leak exhaust at idle. At the time there was no vac source, but that shouldn't matter since the 12lb spring keeps it closed. It doesnt stick, but i think its just carbd up some.
My question is, does the WG diaphragm just pop out? Is there a trick to getting it out, I dont want to tear it and since im not sure if its glued in I didn't want to yank on it.
Re: Disassembly of tial 38mm wg
« Reply #1 on: June 26, 2010, 11:15:56 AM »
Should not be glued in. should come out easily. If for some reason it is stuck to the flange, just slowly work around the edge till it is free.
TTC
« Reply #2 on: June 26, 2010, 01:19:30 PM »
Alright thx, I figure ill take it to the wire brush, throw some graphite after a carb cleaner soak and call it a day.
« Reply #3 on: June 28, 2010, 06:18:25 PM »
my chinese crap has a 10mm nut on it just undo that and no prob.
side not:
mine was doin the same thing and I have a 1 bar spring. Took it apart wire brushed the valve then decided I would lap the valve also just cause re assemled and hold 15 psi solid
« Reply #4 on: June 28, 2010, 06:32:43 PM »
It just fits into the groove, no glue or bolts holding it.
ifly87
« Reply #5 on: June 29, 2010, 12:22:49 AM »
The last time I took one of those ching chank valves apart, there was a set screw holding the valve to the diaphram. It actually looked like there was 4 set screws but the squinty eye that put it together must have forgot 2 or 3, after those were out the valve just slid out the bottom like nothing. Mine was leaking as well so I lapped it with the seat and it seemed to seal fine after that.
Lol...Fags
79fairmont
« Reply #6 on: June 29, 2010, 07:48:58 AM »
Anyone ever chuck one in a valve grinder? I've seen some pretty unique things when I did it. Same with the seats.
evo_lucian
« Reply #7 on: July 03, 2010, 11:16:32 AM »
Where can you buy replacement diaphragms ?
« Reply #8 on: July 03, 2010, 12:39:00 PM »
Tial
evo_lucian
« Reply #9 on: July 04, 2010, 08:11:31 AM »
Are their wastegates diaphragms  interchangeable with the cdm tial knock off wastegates ?
« Reply #10 on: July 04, 2010, 09:24:50 AM »
I had one where the shaft to the diaphram seized in the bore from rust after it had sat for a while. I took it apart and cleaned it up with some sand cloth and it was fine.
TTC
« Reply #11 on: July 04, 2010, 09:49:42 AM »
IIRC all parts are interchangeable, they are a direct copy.
evo_lucian
« Reply #12 on: July 04, 2010, 11:10:19 AM »
Ahh thanks, thats great because i have a friend with a cdm wastegate with a busted diaphragm. Tryna decide whether to buy a diaphragm or just buy a new cdm wastegate.
« Reply #13 on: July 04, 2010, 12:01:16 PM »
Explain?  Do you mean the seats aren't even concentric?  LOL, not surprised.
Tial
Precision.
TTC
« Reply #14 on: July 04, 2010, 10:35:10 PM »
Someday ill have a real tial, until then chingchongmeow will do.
79fairmont
« Reply #15 on: July 05, 2010, 12:49:31 AM »
Exactly that. Some one fell asleep at the grinder and I've seen some that ground like they were warped. One of the early ones I noticed tried to clog up my grinding wheel. The later ones seem to be better but....
Tial
Precision.
TTC
« Reply #16 on: July 05, 2010, 10:41:49 AM »
The hex nuts on mine were all stripped lol so you couldnt even get the valve out.
