Author Topic: mutt motor  (Read 25081 times)
turbocivichatch
mutt motor
« on: July 29, 2010, 02:56:43 PM »
does this sound right im putin a z6 block wit a a6 head and the only timing belt that lines up at tdc is a dx 1.5 belt
does this sound right every thing lines up perfect.
SOHCKLR657
Re: mutt motor
« Reply #1 on: July 29, 2010, 05:03:08 PM »
Spin the motor a few times and see if it still lines up, make a proper post and come back and tell me what you find out, if its wrong I might consider helping if you post a nice pair of tig ole bittys!!!
« Last Edit: July 29, 2010, 05:06:56 PM by SOHCKLR657 »
Re: mutt motor
« Reply #2 on: July 29, 2010, 05:04:52 PM »
Use a z6 or a6 belt. Your doing it wrong if a 1.5L belt with a completely different deck height fits.
SOHCKLR657
Re: mutt motor
« Reply #3 on: July 29, 2010, 05:11:30 PM »
x2
Re: mutt motor
« Reply #4 on: July 29, 2010, 06:17:25 PM »
x2
Yeap and turbocivichatch where is your noob post, build thread and porn.
2slow
Re: mutt motor
« Reply #5 on: August 01, 2010, 01:06:50 AM »
I thought this was realhomemadeturbo.com not imarealfaggotretardloserwhocantusegooglesearch.com fuck fave i think you were looking for the second website i listed
Re: mutt motor
« Reply #6 on: August 01, 2010, 05:24:28 AM »
x2
Eh.
88 A6 cam is keyed on the D15 index.  The difference should be in the cam gear.
If the head's been milled, block decked, it's not uncommon to be a half tooth or more off, although it doesn't seem to be "more" since you always set it by the closest tooth.
Get a cam gear, and an A6/Z6 belt.  Center your distributor.  Lock your timing at 16 degrees, adjust the cam gear *instead* of the distributor to set your ignition timing.  This sets mechanical and ignition timing all in one.
Re: mutt motor
« Reply #7 on: August 01, 2010, 05:32:49 AM »
Also, I found some old myspace account of yours that links to some beaten down trick with a big nose and overly plucked eyebrows who is either your sister or your girlfriend.  Regardless, you should post some nudes of her in exchange for the excellent assistance you have derived from this forum.
SOHCKLR657
Re: mutt motor
« Reply #8 on: August 01, 2010, 05:51:36 AM »
+1  :yes:
turbocivichatch
Re: mutt motor
« Reply #9 on: August 02, 2010, 02:48:40 PM »
fuck you guys with your bashin , just asked for a little tech help
been on this cite for many of years but dont post cuz most the time can handle my self  Jew
SOHCKLR657
Re: mutt motor
« Reply #10 on: August 02, 2010, 03:47:15 PM »
This would'nt be RHMT if we didnt bash newbs :yes:
fysh
Re: mutt motor
« Reply #11 on: August 02, 2010, 04:44:35 PM »
shut the fuck up.
Re: mutt motor
« Reply #12 on: August 02, 2010, 08:01:45 PM »
"CITE" or Site hasn't been around for years.  Noob post now!
Re: mutt motor
« Reply #13 on: August 02, 2010, 08:15:07 PM »
If you've "been here for years" even though the site is 1.5 years old then you'd know exactly what sort of response a n00b post garners.  Fuck you if you can't handle, or don't think you deserve, exactly what you knew was coming.  Based on having been here for years.
Re: mutt motor
« Reply #14 on: August 03, 2010, 05:08:24 PM »
I have been here for 6 years not sure where you guys have been.
bikewrench
Re: mutt motor
« Reply #15 on: August 03, 2010, 06:41:36 PM »
I'm also rebuilding a a6 with z6 block.  I've found through the web the d15 deck height is 207mm and the d16 is 212mm, Is this incorrect?  From this I could understand a d15 block throwing the cam timing off but not another d16.
So its a good rule to always match the cam gear with the block?
I have also found through personal measurement the z6 tensioner is saller than the a6, so I could see the a6 belt being too big.
Re: mutt motor
« Reply #16 on: August 03, 2010, 10:21:02 PM »
x2
Eh.
88-95 cam gears are all the same.
You'd need to mill .185" to be 1/2 tooth off.
Re: mutt motor
« Reply #17 on: August 03, 2010, 10:24:37 PM »
Yes, my block deck height measurements are correct. Slap head on, set cam gear timing to seven 'oclock, tension timing belt, done. The is no major difference between the D16 blocks that will effect cam timing.
turbocivichatch
Re: mutt motor
« Reply #18 on: August 10, 2010, 02:53:57 PM »
so the 1.5 belt sounds right for this combo cuz of the small tensh pully
Re: mutt motor
« Reply #19 on: August 11, 2010, 12:05:45 AM »
put the belt on with the gears in time, spin motor a few times and see if the shit is still in time.  that will let you know
bikewrench
Re: mutt motor
« Reply #20 on: August 26, 2010, 07:56:02 PM »
Just got my z6 block/a6 head running yesterday.
The b7 timing belt does fit better than the z6.
The cam was off 1/2 tooth
It runs OK, I guess I'll buy a cam gear.
turbocivichatch
Re: mutt motor
« Reply #21 on: September 02, 2010, 02:11:07 PM »
try a y8 gear its a hlf tooth dif than z6
bikewrench
Re: mutt motor
« Reply #22 on: September 02, 2010, 08:17:02 PM »
Thanks for the tip.  I still don't understand why its a half a tooth off :-\
h2a
Re: mutt motor
« Reply #23 on: September 05, 2010, 08:43:38 PM »
thats a nice pile of d series knowledge
Re: mutt motor
« Reply #24 on: September 05, 2010, 10:23:13 PM »
Different distances between bottom of the head and cam centers?
