Author Topic: 1st gen cam timing marks  (Read 43991 times)
« on: August 04, 2010, 09:32:28 PM »
Anyone know how to line up the cam on the 1st gen crx FI motor???
the cams are different than all the newer motors, they don't have the same marks.
there is a tdc mark for the crank pulley but i don't know how to set the cam
Re: 1st gen cam timing marks
« Reply #1 on: August 04, 2010, 11:14:56 PM »
going out on a limb but are you talking about a 1st gen ZC. I could think that you could check the distributor to see if it lines up at the no1 terminal?(assuming its like a normal honda and the distributor only goes in one way.  i mean its at least a start??
« Reply #2 on: August 04, 2010, 11:19:22 PM »
86-87 Si????
Like timing a D15B1/2/7/8
« Reply #3 on: August 04, 2010, 11:22:35 PM »
i dont think the d15a3 or whatever it was has the same marks as the later motors. and it doesnt have dots or anything in the cam gear?
« Reply #4 on: August 04, 2010, 11:26:26 PM »
two marks on the cam gear level with valve cover surface and then TDC (white mark) on the crank pulley.
RTFM!!!!!
« Reply #5 on: August 04, 2010, 11:30:21 PM »
RTFM!!!!!
it could be 180 off that way...
what i have heard and am going to try is cam marks level with head and the side with the numbers on it facing up.
« Reply #6 on: August 04, 2010, 11:32:50 PM »
RTFM!!!!!
thats why i suggested look under the cap to make sure the rotor points towards no1 and not no4
« Reply #7 on: August 05, 2010, 12:22:44 AM »
UP means up, how hard is that to fuck up????
« Reply #8 on: August 05, 2010, 12:26:33 AM »
+1
« Reply #9 on: August 05, 2010, 02:14:49 AM »
morons,
there is not up on these old cams.
« Reply #10 on: August 05, 2010, 03:11:45 AM »
morons,
Try looking on the fucking CAM GEAR. Might be easier to see if you take that 12v cam out of your fucking ass!!!!!
« Reply #11 on: August 05, 2010, 03:15:08 AM »
morons,
why do dumb asses always have to start flame wars. there are no up marks on the cam gear.
there are only twostraight lines and three numbers
« Reply #12 on: August 05, 2010, 03:18:23 AM »
morons,
Where did I say up marks???? UP is on the cam gear, at least the one I was working on this weekend at Mid Ohio.
theidealone
« Reply #13 on: August 05, 2010, 03:46:01 AM »
What the fuck? Hes saying that the cam gear doesnt say ANYTHING about up. Only the side marks, that you would level with the head. So if he doesnt check to see that the dizzy is at #1, he could set it 180* off.
« Reply #14 on: August 05, 2010, 05:51:53 AM »
I guess I'm clueless on 1G CRX's.....although #23 is running my 13x6 Rials
I sold Ryan the rims for $100 on the basis they would return to competition, he made good on it!
oops.....
Ryan Scott off
« Reply #15 on: August 05, 2010, 07:49:43 AM »
Once again Johnny knows everything.
I guess he is too goddamn dumb to look at cam lobes to figure out how to net set the cam 180 out.
« Reply #16 on: August 06, 2010, 08:51:25 PM »
I own Foowee's old 86 Si.  Bone is correct, Johnny is dumb.
Johnny, DasShit posted up a MOD pass recently.
Johnny, there are links to Classic Si Helms manuals stickied in this forum.
Johnny, is this your first time working on a car?  I don't mean one of your imaginary nine second 52 mpg turbo builds that never have a problem and still run to this day, I mean working on a car in the real world?
« Reply #17 on: August 06, 2010, 10:31:10 PM »
Wrong.
Idiots.
« Reply #18 on: August 07, 2010, 02:27:51 AM »
i've worked on your mom several times, she is about the size of a car
« Reply #20 on: August 07, 2010, 10:06:26 AM »
I think you went to her neighbor's house, mom's lost a lot of weight due to the cancer.  I know it's an easy mistake for you to make, you see a real fatty unloading four dozen boxes of twinkies from her car and you get all sweaty palmed with excitement, don't even stop to check the house number.
Mom's probably lonely if you want to go over there and do some work now, though.
« Last Edit: August 07, 2010, 10:08:24 AM by Joseph Davis »
« Reply #22 on: August 07, 2010, 12:22:10 PM »
apparently the 86 si is different. because it doesn't have those marks
Post a pic of what you have.
« Reply #23 on: August 07, 2010, 04:14:00 PM »
Silence
« Reply #24 on: August 07, 2010, 05:05:03 PM »
« Reply #25 on: August 07, 2010, 05:07:28 PM »
so whats keeping you from getting everything in time?
« Reply #26 on: August 07, 2010, 05:09:07 PM »
teh fact that i don't want to work onit and i really don't care
« Reply #27 on: August 07, 2010, 05:12:11 PM »
spoken like a true asshole
« Reply #28 on: August 07, 2010, 07:30:14 PM »
So you are lazy and complacent.
I see no irony there...
« Reply #29 on: August 08, 2010, 09:09:22 AM »
Just put the belt on n go...  If you're off a tooth you'll be able to tell by the way it drives.
When I originally purchased the 86, that Joseph now owns, the cam timing was so far off it was causing the car to overheat.  I'm fairly certain you have to be off really far to bend some valves.
Also it's impossible to be 180 degrees off with a sohc...  the cam spins half the speed of the crank...
« Last Edit: August 08, 2010, 11:38:30 AM by Foowee »
