Author Topic: 1st gen cam timing marks  (Read 43986 times)
Re: 1st gen cam timing marks
« Reply #30 on: August 08, 2010, 02:32:30 PM »
make sure the keyway is up
« Reply #31 on: August 08, 2010, 03:10:44 PM »
Yep.
Just like it shows in the 1st pic link posted.
Bottom right.
http://www.redpepperracing.com/technical/v/87Civ-fsm/87Civ-fsm-chap6/aai.png.html
« Reply #32 on: August 08, 2010, 05:07:08 PM »
...Also it's impossible to be 180 degrees off with a sohc...  the cam spins half the speed of the crank...
I want you to think about that statement and tell why you are wrong.
« Reply #33 on: August 08, 2010, 05:17:02 PM »
Cause the dizzy drive can be slopped out n put in backwards?  If the dizzy key was removed from the dizzy and replaced incorrectly?
I don't see how I'm wrong...
DasPoop
« Reply #34 on: August 08, 2010, 07:21:04 PM »
on a 4cyl with 90 degree firing angles its possible to be 180 off. only motors i have worked on that cant be 180 off are 3 cyl geos because the crank angles are 120 degrees apart.
« Reply #35 on: August 08, 2010, 08:02:20 PM »
Think about this.  When if ever will the engine ever have both valves closed on cylinder 1, while pistons 2 and 3 are at TDC?
Never in a 4 cycle engine that I am aware of will you have both valves closed while the piston is at NDC.
DasPoop
« Reply #36 on: August 08, 2010, 08:10:02 PM »
both valves will still be closed at the bottom of the power stroke the exhaust usually opens around 30 degrees back up on the exhaust stroke
« Reply #37 on: August 08, 2010, 08:16:15 PM »
Not exactly what I was trying to get at, but I didn't think of that scenario.
DasPoop
« Reply #38 on: August 08, 2010, 08:30:37 PM »
lets just say if the cam is 180 off shit is going to get bent it wont run and you wont ever do it again
« Reply #39 on: August 08, 2010, 10:50:02 PM »
Okay...  1 and 4 are at tdc.  2 and 3 are at bdc.  Flip the cam 180.  Which valve events change kids?
« Reply #40 on: August 08, 2010, 11:47:19 PM »
I have been thinking it thorough in my head, and I was thinking crankshaft 180 degrees out apparently.  Different story.
In short you are correct, although possibly too narrow in scope?  Now that I think about it, it doesn't matter on any 4 stroke engine.
I R an idiot.
« Last Edit: August 09, 2010, 01:08:06 AM by snm95ls »
« Reply #41 on: August 09, 2010, 12:19:14 AM »
The old azn smiley would be apropo right now.
« Reply #42 on: August 09, 2010, 01:08:33 AM »
Or the old dunce cap smiley.
« Reply #43 on: August 09, 2010, 01:11:49 AM »
Random-strike threads always make me feel smarter after I read them. By smarter I mean superior in comparison.
What do you call 50 of johnny's posts at the bottom of the sea? A good start.
