Pages: [1] 2 3   Go Down
Author Topic: the hunt begins, RT4WD civic  (Read 32664 times)
speedjunky01
« on: August 13, 2010, 10:14:04 PM »
not really sure of any forums for these beasts, i just want a winter car for the NH snow storms and to go snowboarding with.
been looking all over the net and no luck closest one is in CT (a bit far like 5 hours?) on CL
might get the one in CR but hunting local right now
Re: the hunt begins, RT4WD civic
« Reply #1 on: August 13, 2010, 10:16:13 PM »
Gangsta!!
And I too am in the same hunt there just really hard to find both 6 speed and not auto aswell as in even decent shape
speedjunky01
« Reply #2 on: August 13, 2010, 10:20:16 PM »
yeah i wouldnt abuse it or mod it like crazy
« Reply #3 on: August 13, 2010, 10:21:49 PM »
in that case whats wrong with an old subaru wagon easy to find and still a blast in the snow I know there not as cool.
speedjunky01
« Reply #4 on: August 13, 2010, 10:24:11 PM »
yeah there is a decent legacy wago around but how bad ass is a 4wd civic hahah and it has the a6 in it :D cant go wrong plus i have piles of parts for it, and maintenance isnt a PAIN
« Reply #5 on: August 13, 2010, 10:26:35 PM »
true but there is tons of room under the hood of a non turbo suby but I do like your logic I am in the hunt for just a shell I want to find an ef but hell any shell at this point
michigan_soler
« Reply #6 on: August 13, 2010, 11:23:46 PM »
That one jumping the dune is from west michigan...
« Reply #7 on: August 13, 2010, 11:44:26 PM »
Maine isn't that far, one for sale there.
schim187
« Reply #8 on: August 14, 2010, 01:40:01 AM »
Those models civs are everywhere up here in MT
« Reply #9 on: August 14, 2010, 04:32:57 AM »
Wes has a RT4WD 1.7 Z6 with a Crower 2 NA cam and an Evo8 turbo, and his brother has a 2WD caged version with a sleeved LS/VTEC and 60-1.  The 2WD has Skank9 1000lb springs and a complete suspension under it that is the smoothest thing I have ever been in - full throttle or transitioning to closed throttle from power, in straights or in curves, it just feels smooth and stable.  Very nice.
Gold DA9
  • OG LURKER
« Reply #10 on: August 14, 2010, 05:29:37 AM »
all the ones i find around here are FWD or autos. all the FWDs were speeds and the one auto was RT4WD which my friends sister uses.
Good luck in your search.
speedjunky01
« Reply #11 on: August 14, 2010, 02:25:52 PM »
link? i would gladly go to maine
« Reply #12 on: August 14, 2010, 03:32:51 PM »
Links to any for sale? ;D
« Reply #13 on: August 14, 2010, 03:59:55 PM »
roadtrip after seeing bisi rip on his got me really thinking
« Reply #14 on: August 14, 2010, 04:09:05 PM »
bisi's is 2wd  :?:
speedjunky01
« Reply #15 on: August 14, 2010, 08:40:32 PM »
bisi's is 2wd  :?:
and has piss injection
« Reply #16 on: August 14, 2010, 08:45:52 PM »
bisi's is 2wd  :?:
+1 meth injection is for pussies. i would rather have power all the time and not worry about if i have enough in my "special" tank granted you can only make bout 550 whp on pump
« Reply #17 on: August 14, 2010, 08:54:18 PM »
bisi's is 2wd  :?:
And traps 130s.
« Reply #18 on: August 14, 2010, 08:56:25 PM »
Epic Tuning 400HP D16Z6 powered Real Time 4WD EF hatch
even if its not a wagovan it still shows that hondas awd it strong as hell
« Reply #19 on: August 14, 2010, 08:58:10 PM »
Strong as hell?  Not really.  They are weaker than DSM boxes and shift similarly to a granny four speed from an 80s Ford truck.
« Reply #20 on: August 14, 2010, 09:04:11 PM »
idk i went through 3 dsm boxes breaking the 2-3 shift rail the 3-4 shift rail and the transfer case output shaft in one summer(and no i didnt have wheel hop) and i was only putting down 384whp. they cant be weaker than that. as far as shifting after seeing the shifter epic tuning had there is no argument there
« Reply #21 on: August 14, 2010, 09:08:54 PM »
Learn to adjust your shift cables, replace your cables when they stretch, and observe that the "DSM" gearbox was designed for a 2200lb car and not the 3200lb cars they came in.  You broke a T-case output shaft, Wes has dropped whole gears and broken two cases and isn't even making 300 whp at the moment in a 2400-2500lb chassis.
« Reply #22 on: August 14, 2010, 09:14:12 PM »
When you weld your center diff I found out that you need to run damn near solid motor mounts because the motor will cause the front wheels to spin just a bit different than the rears and i guess it put a bunch of stress on the t case output shaft. I have since sold the car and who the hell knows where it went. I sold it to some punk kid at my hs and from what i heard he blew it up seeing how fast he could get it to go
« Reply #23 on: August 14, 2010, 09:25:20 PM »
I passed up a rt4wd wagon the other day for 400. Pretty dam rusty though, I had thoughts of tprc2 so I ran away quick  :mexi:
« Reply #24 on: August 14, 2010, 09:41:37 PM »
damn how do these deals come up? is it still forsale??
« Reply #25 on: August 15, 2010, 01:41:37 AM »
stronger than you think...than even I thought!
Nothing like a RWD wagon, front axle openings were JB/devcon closed up.
« Reply #26 on: August 15, 2010, 08:59:15 AM »
Hah!  I need to see that, sounds like a veeeery interesting setup.
Did they keep or delete the viscous coupling?
« Reply #27 on: August 15, 2010, 10:42:56 AM »
Sounds perfect for getting abused.  Waiting to spot a deal like that in my area.  I'm probably going to roll it at least once if I get one, so rust isn't a big concern.
« Reply #28 on: August 15, 2010, 10:48:42 AM »
If I could find a solid one I'd rock it anyday. If I had more room at my house I would stock pile shit like that for futer use.
« Reply #29 on: August 15, 2010, 03:56:48 PM »
custom 4" driveshaft IIRC.
Pages: [1] 2 3   Go Up
