Author Topic: HomeMade Corner Balancing  (Read 23291 times)
« on: August 14, 2010, 09:09:57 PM »
The local shop are Home Made as fuck, and decided a bathroom scale would get the call.
I've never seen this shit done before, but the premise is that the triangle gives a 3 to 1 ratio, and the other 3 wheels have blocks under them to raise them to the same level as the one on the scale.
JD style technical posts shall follow....
Re: HomeMade Corner Balancing
« Reply #1 on: August 14, 2010, 09:21:21 PM »
hmm go to Lane Bryant for those scales mine only goes to 300lbs
« Reply #2 on: August 14, 2010, 10:05:23 PM »
with the reduction of the triangle piece, a 300lb scale would work.
2400lb car @3:1= 800 lb car divided by 4 = 200lb per wheel
« Reply #3 on: August 14, 2010, 10:14:13 PM »
i know i quickly did the math in my head its just funny to see a car on a bathroom scale.
« Reply #4 on: August 14, 2010, 10:19:32 PM »
I was think about something a while back like this but never put it to practice.
I like it ;D
« Reply #5 on: August 14, 2010, 10:29:50 PM »
i live by a bunch of circle track guys and used to just ask them if i could use there scales. used to buy 205 wide 13s from there legend cars too  :noel:
michigan_soler
« Reply #6 on: August 14, 2010, 11:58:44 PM »
I highly doubt that the suspension is settled.  If it was drive on that would be different.
Someone on locost was talking about those...
« Reply #7 on: August 15, 2010, 12:11:30 AM »
it doesnt have to be settled for weight. only ride height and alignment need it to be settled
« Reply #8 on: August 15, 2010, 12:16:17 AM »
+1 just make sure you weigh in with 1/2 a tank that way it will have less effect if either full or empty
« Reply #9 on: August 15, 2010, 01:35:13 AM »
nice rHMT version of the Ruggle's setup.
« Reply #10 on: August 15, 2010, 09:10:50 AM »
I think the bathroom scale costs more than some strain gauges, but A+ for doing something useful and not making excuses for why you don't own $2500 scales.
« Reply #11 on: August 15, 2010, 11:49:43 AM »
http://www.amazon.com/Health-Meter-SAB998D-41-Scale-White/dp/B0014JVJQK/ref=sr_1_6?ie=UTF8&s=home-garden&qid=1281886711&sr=8-6
$40 in scales + $20 in angle iron > $700 http://www.jegs.com/i/Proform/778/67650/10002/-1
I remember reading about this bathroom scale jazz in a chassis setup book and have wanted to make one since.  Seeing one functioning helps...  :noel:
Kinda want to make some that bolt to the hubs.  To make it easier to adjust the chassis while loaded...
« Last Edit: August 15, 2010, 12:06:42 PM by Foowee »
« Reply #12 on: August 15, 2010, 12:20:47 PM »
Also keeps from biasing the scale by not having the tire perfectly centered.
slappynuts
« Reply #13 on: August 15, 2010, 04:28:02 PM »
Actually the weight is pushing down on a point on the lever system. Thats why there is a plate under the tire that pushes down on the point of the angle iron.You can put this on either side of the tire and you get the same reading.And the scales were $7 on sale at menards  ;D
« Reply #14 on: August 17, 2010, 11:28:12 PM »
Well if you use a thick rod as a pivot and a platform like a bike pedal, it doesn't really matter. The wheel remains vertical, keeping it from tipping off the pivot. Move the load side to side but keep it level, and the pivot point sees the same load. You just need to have those pivots equally spaced on both ends of the car.
I will have to make some of these if I get ground controls...
