Author Topic: ls vtec cam timing  (Read 13340 times)
fuse
ls vtec cam timing
« on: August 17, 2010, 08:04:54 PM »
Hi I built a ls vtec
b18a1 bottom
gsr head
gsr cams
gsr belt
gsr water pump
I got the belt on works fine drives fine. It just looks to me like the cam sprocket lines are not lining up perfect just a hair off. Is the ls bottom just a hair taller? I know with mini mes you run into all kinds of cam timing problems due to this. Is there an easy fix?
Re: ls vtec cam timing
« Reply #1 on: August 17, 2010, 08:09:52 PM »
Non-VTAK B blocks are shorter, thus the timing marks are not quite dead on.
fuse
« Reply #2 on: August 17, 2010, 08:11:03 PM »
should I give a shit? How many degrees am I off? 2?
« Reply #3 on: August 18, 2010, 07:21:14 PM »
Just add boost = problem fixed  :D
« Reply #4 on: August 18, 2010, 07:47:33 PM »
« Reply #5 on: August 24, 2010, 05:29:57 PM »
Mine's off a cunt-hair as well too, no big deal.
Take ratcityrex's advice.
« Reply #6 on: August 25, 2010, 10:41:49 AM »
Its something like 0.55mm shorter, so it should retard the cams a little bit. Here is the way I remember what advance and retard does. Advancing helps low end, so it helps earlier (more advanced) on a dyno sheet. Retarding the cam helps top end, so it helps later (more retarded) on a dyno sheet.
Since the longer stroke will help with low end a little bit, that won't drop vs a gsr, but you should pick up even more top end than expected. Theoreticly according to cam timing, yet it tends to work this way.
