Author Topic: Q31 Repairs  (Read 13100 times)
El Beefo
  • tongue punch my fart box
Q31 Repairs
« on: August 22, 2010, 06:13:00 PM »
Just picked up an p75 w/ a blown Q31 trans. Checked my parts P28 and pulled Q31 to fix said p75. Heres the problem The transistor on the P75 reads D1780 and the replacement I pulled from the p28 reads D1779. Can I still swap it? Only found one thread online bout this. Anyone else have some input.
http://forum.pgmfi.org/viewtopic.php?f=4&t=660
SgtB
Re: Q31 Repairs
« Reply #1 on: August 22, 2010, 06:42:08 PM »
The collector to base voltage is 10v less on the 1779, but it's still 60 which I doubt is too little for a 12v ecu.
I think it will be fine as every other spec is the same, or fairly close. They're both high hfe npn.
Datasheets:
http://mycomputerninja.com/~jon/www.pgmfi.org/twiki/pub/Library/D1780/2SD1780.pdf
http://pdf1.alldatasheet.com/datasheet-pdf/view/94898/NEC/2SD1779.html
« Last Edit: August 22, 2010, 07:50:54 PM by SgtB »
El Beefo
Re: Q31 Repairs
« Reply #2 on: August 22, 2010, 07:00:26 PM »
Bingo! thats exactly the info I was looking for. Honda ECUs arent to anal so I was thinking it should work. Ive also seen other boards w/  D1779 at Q 31.  ;)
theidealone
Re: Q31 Repairs
« Reply #3 on: August 26, 2010, 12:08:58 PM »
Q31 controls the Evap Purge, right???? Why fix it?
Re: Q31 Repairs
« Reply #4 on: August 26, 2010, 01:14:18 PM »
I replace them because I do not know what all the possible future uses of the ecus after me.  ;D
Re: Q31 Repairs
« Reply #5 on: August 26, 2010, 04:28:37 PM »
Cheap two stage boost control.
 :P
SgtB
Re: Q31 Repairs
« Reply #6 on: August 26, 2010, 05:24:22 PM »
You never know how a blown transistor can react either. It can dump line voltage back into the output of the cpu. Bad.
Re: Q31 Repairs
« Reply #7 on: September 08, 2010, 09:28:57 AM »
My plan for purge is to operate a solenoid valve that opens a quick spool valve... :yes: But there are many possibilities.
