Author Topic: LS/gsr countershafts/pinion gear the same? Mista Bone?  (Read 12123 times)
mrgreengenes
« on: September 14, 2010, 03:48:40 PM »
2 gsr transmissions,
1 (bad) with ls final drive and quaife, the countershaft is worn at the bottom of the pinion gears, i guess the countershaft bearing snap ring wasn't seated and wore away the gear a bit.
can i just swap the quaife with the ls ring gear, or will there be interference?  i checked that both countershafts have the same tooth count, but didn't check for gear pitch or overall diameters...
thanks
phil
Re: LS/gsr countershafts/pinion gear the same? Mista Bone?
« Reply #1 on: September 14, 2010, 03:55:03 PM »
No they are not the same.
Gotta keep an LS CS with an LS ring gear; same goes for B18C1 CS and ring gear.
Even if the tooth count is the same on the CS(which it is IIRC), the pitch will be different.
mrgreengenes
« Reply #2 on: September 14, 2010, 04:13:26 PM »
thanks!  i put it together anyway just to see, and you can feel the final drive interfere while turning the input shaft in any gear.
oh well.
« Reply #3 on: September 14, 2010, 04:17:58 PM »
I'd be happy to sell you a large spline LS FD for pretty cheap  if I wasn't so far from home.
« Reply #4 on: September 14, 2010, 10:41:58 PM »
oh well.
94-01 LS FD, I should have a spare setup.
Yep, 64/15 = 4.267
$30 shipped USPS Priority, PM me if interested.
mrgreengenes
« Reply #5 on: September 15, 2010, 02:12:02 AM »
i was able to just re use the ls countershaft, but thanks for the offers.
on a side note, turned out that the damaged tranny had a type ARRR gearset with the ls quaife.  I just stripped the gears off, and swapped the CS's.
so now there's a type ARRRR clone with a gsr non-lsd diff, and a gsr with an ls FD and quaife.
