Pages: 1 2 [3]   Go Down
Author Topic: Question On Grounding/Wiring/Ignition woes  (Read 57787 times)
Re: Question On Grounding/Wiring/Ignition woes
« Reply #60 on: April 25, 2009, 06:38:41 PM »
Start the car with a decent digital voltmeter go from the NEG battery terminal to the block then to each device.  If your problem is still grounding issue, it will show voltage.  .003v is ok, problems will usually show up at .05v and above.
I'm done
« Reply #61 on: April 25, 2009, 06:41:25 PM »
I'm done
I did.
Pages: 1 2 [3]   Go Up
