Author Topic: Das Build Thread. the all motor d15 "sleeze" :Update itbs done pics of wife:  (Read 35306 times)
Re: OMFG I have a Build Thread. the all motor d15 "sleeze" :ITBS!!!:
« Reply #30 on: October 27, 2011, 02:57:38 PM »
There not b16 rods? there z1 rods
I agree the itbs are a bit on the skimp side but should have better part throttle characteristics.
Not sure what you ment buy the third comment
Daswife well will be das wife come spring is alive and well.
Your pretty much wrong on all levels.
« Reply #31 on: October 27, 2011, 05:06:52 PM »
I am aware of what rods you have.  Keep thinking.  You're not good at it, but you aren't bad either.  You might figure something out.
What part throttle characteristics?  Alpha-n runs like ragged ass, and is a crude thing I wouldn't want done to my own car.
Reread your own thread.
You admit there is no Daswife, yet I am wrong on all levels?
« Reply #32 on: October 27, 2011, 05:33:11 PM »
He may not have a Daswife yet, but last weekend he did in some bitching from her.
He went the JY with her Jeep and got all muddy.   :noel: ;DDD
« Reply #33 on: October 27, 2011, 05:34:51 PM »
Jeep?  He has a DasHusband then.
« Reply #34 on: October 27, 2011, 05:40:40 PM »
dont go jumping into being married before you have to. its not all its cracked up to be
shogun
« Reply #35 on: October 28, 2011, 12:56:36 AM »
would the b16 rods need any kind of notching in the d15 block?
« Reply #36 on: October 28, 2011, 01:27:58 AM »
your kidding right? d15 rod journals are 42mm unlike the common 45mm used in most other larger engines.
jeremy_nash
« Reply #37 on: October 31, 2011, 12:50:34 AM »
THIS ^
« Reply #38 on: October 31, 2011, 08:37:31 AM »
Only for some of the D15 cranks, champ.
« Reply #39 on: October 31, 2011, 08:58:39 AM »
I only know of the JDM D15B with larger crank journals. Are there others?
« Reply #40 on: October 31, 2011, 09:06:11 AM »
Yep, but you gotta dig a bit, and one requires a skim of the journals to bring it down to size.
I'm turning into Bone in my old age.
« Reply #41 on: October 31, 2011, 09:49:04 AM »
Just the rod journal are larger than USDM D15.  :noel:
