Author Topic: Hx-52 on a z6?  (Read 12811 times)
Hx-52 on a z6?
« on: October 25, 2011, 02:45:09 PM »
Thoughts on this, with maybe a small t3 before it? Im thinking log, t3 into Hx52, then use 2 50mm ebay wg to by pass the t3 on the higher boost levels.
Re: Hx-52 on a z6?
« Reply #1 on: October 25, 2011, 03:10:35 PM »
Thinking of something similar but with my SC14 supercharger.  :noel:
Re: Hx-52 on a z6?
« Reply #2 on: October 25, 2011, 04:28:59 PM »
You two fuckers always want to OVER complicate things, lol.
MTZ
  • Webadmin
Re: Hx-52 on a z6?
« Reply #3 on: October 25, 2011, 04:55:22 PM »
...................... retarded the 2 wg are going to become a bigger restriction than a t3 and your are going to be held back by the t3 without bypassing it at higher boost so just dont do it
its called toering
Re: Hx-52 on a z6?
« Reply #4 on: October 25, 2011, 05:28:40 PM »
use bigger map sensor
Re: Hx-52 on a z6?
« Reply #5 on: October 25, 2011, 06:50:08 PM »
and a pbt throttle body
Re: Hx-52 on a z6?
« Reply #6 on: October 25, 2011, 07:26:05 PM »
100 shot will help it spool.
 O0
Re: Hx-52 on a z6?
« Reply #7 on: October 25, 2011, 10:52:17 PM »
or new delrin spacer :Jew:
Re: Hx-52 on a z6?
« Reply #8 on: October 25, 2011, 10:55:28 PM »
How big of a shot of giggle gas do you want to use to spool that big fucker?
 :-X
DasPoop
Re: Hx-52 on a z6?
« Reply #9 on: October 25, 2011, 11:08:47 PM »
two fiddy ought to spool it by 6k
Re: Hx-52 on a z6?
« Reply #10 on: October 26, 2011, 12:36:55 PM »
HX52?  Too small.
Re: Hx-52 on a z6?
« Reply #11 on: October 26, 2011, 07:35:03 PM »
4bar, pbt 74mm tb, 200shot
How can you tell 2 50mm wg would become to much of a restriction?
caged
Re: Hx-52 on a z6?
« Reply #12 on: October 27, 2011, 05:50:58 AM »
I really want to have a play with compounding a 4cyl petrol, but from what iv read its not as good as on the diesels.
this is a good read
http://www.yellowbullet.com/forum/showthread.php?t=216811
MTZ
  • Webadmin
Re: Hx-52 on a z6?
« Reply #13 on: October 27, 2011, 09:36:38 AM »
 i cant, but i wouldn't try it based on the fact i cant prove they would be a restriction... its just not an ideal setup but hey thats why i love this forum so props to you for coming up with the idea and maybe trying it, hopefully you'll prove me wrong  (btw when i first read it i thought of two 38mm wg but even at 50 the flow characteristic and valve might hurt your flow maybe if you used a throttle body type valve
« Last Edit: October 27, 2011, 09:40:28 AM by MTZ »
its called toering
Re: Hx-52 on a z6?
« Reply #16 on: October 27, 2011, 12:33:04 PM »
think im gona use the 60mm wg on a cut out and use that instead of some electric motor cutout bull shit.
Re: Hx-52 on a z6?
« Reply #17 on: October 27, 2011, 01:06:04 PM »
I like that though  ;DDD
Re: Hx-52 on a z6?
« Reply #18 on: October 27, 2011, 02:44:47 PM »
60mm is 2.36"
Re: Hx-52 on a z6?
« Reply #19 on: October 27, 2011, 03:33:01 PM »
60mm is 2.36"
Yeah but if I am using them to relieve back pressure in the exhaust then kool.  :noel:
Re: Hx-52 on a z6?
« Reply #20 on: October 27, 2011, 03:57:29 PM »
that way I can keep my Tanibeeeeee muffler and still be able to make some power. Its 3" going into it and 4" coming out, but only 2.25" inside :'(
Re: Hx-52 on a z6?
« Reply #22 on: October 30, 2011, 02:52:13 PM »
Re: Hx-52 on a z6?
« Reply #23 on: October 30, 2011, 02:57:21 PM »
Mount a wastegate actuator on a throttle body.
The RHMT boost activated exhaust dump.
