Author Topic: I normally think new engine designs are stupid  (Read 11849 times)
« on: November 13, 2011, 04:33:02 PM »
flat_black
Re: I normally think new engine designs are stupid
« Reply #1 on: November 13, 2011, 04:38:24 PM »
pretty neat, sounds cool too, i wonder why nothing ever comes of these inventions that people come up with, is the gasoline engine we have now really the best thing out there?
« Reply #2 on: November 13, 2011, 04:42:14 PM »
Interesting design, problem I see is the added complexity.  :noel:
« Reply #3 on: November 13, 2011, 04:43:18 PM »
i think what we have now is so cheap to manufacture compared to something new like this and thats why it sticks around. i think people would also be scared off if they had a choice between buying a car with this engine and one with a conventional engine. kinda like the rotary, they werent big sellers and rightly so. who wants to mix oil into their gas at the gas station. lol
« Reply #4 on: November 13, 2011, 05:07:52 PM »
That is pretty damn rad.
slappynuts
« Reply #5 on: November 13, 2011, 05:16:33 PM »
Where are you guys getting this extra complexity from? There is zero valvetrain. Looks pretty simple to me.
« Reply #6 on: November 13, 2011, 05:20:40 PM »
Because it doesn't use a standard ICE engine configuration, duh.
 :P
klyph
  • Proletariat for Life!
« Reply #7 on: November 13, 2011, 05:25:12 PM »
The head gasket is now a moving combustion seal just like the piston rings. I'd like to see how long it runs before that seal fails.
« Reply #8 on: November 13, 2011, 06:05:36 PM »
the only thing i see complicated is the "headgasket" but if they have a solid plan for that, then everything else is simple. everything can have roller bearings so there is no need for oil pressure. there is a lot moving, but not a lot of moving parts, its just a big chunk that looks complicated but its pretty simple. valve float, coil bind, broken valves, and piston/ valve contact are all non issues. you could boost the hell out of it and rev it to the moon.
« Reply #9 on: November 13, 2011, 07:40:49 PM »
the reason none of these designs make it to market is because of the people that have billions wrapped up in oil and traditional internal combustion engines.
« Last Edit: November 13, 2011, 08:08:11 PM by j.h.christ »
klyph
« Reply #10 on: November 13, 2011, 07:55:20 PM »
Uh this is an ICE.
« Reply #11 on: November 13, 2011, 08:08:32 PM »
SQ is the SQUAD
« Reply #12 on: November 13, 2011, 08:25:54 PM »
how much boost can it handle?
« Reply #13 on: November 13, 2011, 08:37:58 PM »
10 pounds on a duke will turn ya out!!!
« Reply #14 on: November 13, 2011, 09:53:07 PM »
its a gm ac compressor  :P
« Reply #15 on: November 13, 2011, 11:45:16 PM »
LOL, it's true.
klyph
« Reply #17 on: November 14, 2011, 03:58:37 AM »
No shit brah, for realsies.
« Reply #18 on: November 14, 2011, 12:12:41 PM »
I was thinking that too, since they don't mention "matching conventional reliability" anywhere. However I would imagine a bearing-like surface with oil fed onto it with a rubber seal. It probably has the same rotational speed as a large rear main seal on a larger engine, and they don't feed those oil, nearly all are just splash lubed.
The complexity is the parts themselves, but when you have 1/3 the parts that need 2x the machining, you've saved 1/3 of the machining time/costs. They already use a similar type of "pump" in some car's air conditioner compressors. The even cooler part about that, some of those compressors are variable-compression.
2slow
« Reply #19 on: November 14, 2011, 05:40:48 PM »
« Reply #20 on: November 14, 2011, 06:16:46 PM »
also this https://www.youtube.com/watch?v=eRhxctg5mns&feature=related
If ya speak German reminds me of some previously posted mighty mite engine.
« Reply #21 on: November 14, 2011, 09:37:57 PM »
The complexity is the parts themselves, but when you have 1/3 the parts that need 2x the machining, you've saved 1/3 of the machining time/costs. They already use a similar type of "pump" in some car's air conditioner compressors. The even cooler part about that, some of those compressors are variable-displacement.
