Author Topic: Velocity stacks  (Read 18404 times)
Velocity stacks
« on: December 21, 2011, 07:46:21 PM »
Does anyone know a RHMT priced source?
Re: Velocity stacks
« Reply #1 on: December 21, 2011, 08:32:39 PM »
No, but I remember Chris M. talk about using cupcack pans to make them.  :noel:
Re: Velocity stacks
« Reply #2 on: December 21, 2011, 08:57:30 PM »
I remember watching some vid where the guy made metal bowls using woodworking tools on a wood lathe. Seemed like the hardest part would be consistency.
Re: Velocity stacks
« Reply #3 on: December 21, 2011, 10:05:25 PM »
metal bowls, cupcake pans, I love this place!
shogun
Re: Velocity stacks
« Reply #4 on: December 21, 2011, 10:05:38 PM »
look for 4" subwoofer ports, ive used them a couple of times for turbo inlets and they are cheap
like these ones
http://www.ebay.com/itm/Subwoofer-Box-Areo-Tuning-4-Venting-Port-Obcon-/320814154121?pt=LH_DefaultDomain_0&hash=item4ab2038189
Re: Velocity stacks
« Reply #5 on: December 21, 2011, 10:12:43 PM »
Needing some for the inside of an intake manifold.
Re: Velocity stacks
« Reply #6 on: December 21, 2011, 10:27:17 PM »
I remember a while back somebody posted a site where you can get intake parts.
I'll look at my bookmarks and see if I can find it.
Re: Velocity stacks
« Reply #7 on: December 21, 2011, 11:03:29 PM »
this might work for you.
http://www.rossmachineracing.com/velocitystacks.html
Also metal spinning a set of velocity stacks would be incredibly hard and costly. Not for the average joe.
Re: Velocity stacks
« Reply #9 on: December 22, 2011, 12:53:45 AM »
Australia!
catsman50
  • perpetual noob
  • im a terrorist
Re: Velocity stacks
« Reply #10 on: December 22, 2011, 12:57:09 AM »
I made one out of a cardboard tube and foam....... pretty easy it wasnt perfect but it worked and i use it sometimes
FUCK VOLKSWAGEN'#039#039S
slappynuts
Re: Velocity stacks
« Reply #11 on: December 22, 2011, 01:49:46 AM »
What DIA and height? How many? I would have to make up a fixture for the lathe to do this but it looks pretty doable.16ga anneal and spin.
Re: Velocity stacks
« Reply #12 on: December 22, 2011, 07:51:41 AM »
Will post up in a bit. Waiting on the 2nd intake to arrive. Have to cut the plenum open and measure.
slappynuts
Re: Velocity stacks
« Reply #13 on: December 22, 2011, 09:05:43 AM »
I have a partially done fixture that I am going to give a spin this morning. I will let you know what happens. If it works out well I will hook you up.
Re: Velocity stacks
« Reply #14 on: December 22, 2011, 10:29:09 AM »
The last couple sets of cycle itb's I used the cupcake pans for stacks. They do the job. Some epoxy and some generic filters from the cycle shop down the street and your golden. Stacks for under 5 bucks. Now the best part is going into your local kitchen supply store/wal-mart etc with a pair of calipers measuring cupcake pans. Last time an old women asked what I was baking,lol
Re: Velocity stacks
« Reply #15 on: December 22, 2011, 11:53:17 AM »
Australia!
Lol I never noticed that. Most non-USA sites tell you their location on their main page.
What would sound better, "DINOSAURS" or "HORSEPOWER"?
DSharp
Re: Velocity stacks
« Reply #16 on: December 22, 2011, 01:44:46 PM »
This is one thing I have been considering making once I finish building my CNC.
slappynuts
Re: Velocity stacks
« Reply #17 on: December 22, 2011, 07:23:09 PM »
I didnt get a chance to fuck around with this project this morning so Im doing it right now. I will post pics up in a while.
Re: Velocity stacks
« Reply #18 on: December 23, 2011, 06:25:18 AM »
Sweeeeeeeeeeeeeeeeeeeeeet
slappynuts
Re: Velocity stacks
« Reply #19 on: December 23, 2011, 08:18:16 AM »
I did fuck around with the shit I had at the shop. I think I need to look for a different alloy though. I was having a hard time shaping it.
Re: Velocity stacks
« Reply #20 on: December 23, 2011, 03:41:54 PM »
Really prone to split?  That was what Crazy Dave's dad ran into when he did the Big Power ZC ITBs.
slappynuts
Re: Velocity stacks
« Reply #21 on: December 23, 2011, 11:22:07 PM »
It seems to go well for a while but then it work hardens.
Re: Velocity stacks
« Reply #22 on: December 24, 2011, 12:16:02 AM »
I assume you were just using 6061? Most comercially available 6061 comes in a T6 temper, which mean it won't form worth shit for tight rads. Two things you can do, heat up the material over 400F and let it cool slowly to lose the temper. Or use 5052, which is meant for forming. Some suppliers might even have 3xxx series sheet in stock but I hate working with it, its just too soft.
Re: Velocity stacks
« Reply #23 on: December 24, 2011, 04:14:36 AM »
Makes moresense to form tube...
slappynuts
Re: Velocity stacks
« Reply #24 on: December 24, 2011, 03:17:48 PM »
It was probably 6061 (just some shit from around the shop). I did the sharpie and propane torch anneal.
Re: Velocity stacks
« Reply #25 on: December 24, 2011, 05:15:46 PM »
It's all in material selection. That and having the tooling to be able to form the part.
Re: Velocity stacks
« Reply #26 on: December 25, 2011, 12:21:52 PM »
if you're going to machine something machine a die out of steel to press them on a hydraulic press out of aluminum tube :mexi:
You're wasting so much material forming those bitches out of solid stock.
Re: Velocity stacks
« Reply #27 on: December 25, 2011, 01:45:31 PM »
I was under the impression that we was trying spin them? You won't be able to get much of a radius with a die to form the tube, even if he did do a proper annealing to T0 with 6061 material. Machining them out of solid bar is hardly a waste, Aluminum is about 99% recycleable.
Re: Velocity stacks
« Reply #28 on: December 25, 2011, 02:06:28 PM »
of money
Re: Velocity stacks
« Reply #29 on: December 25, 2011, 02:06:43 PM »
and energy
