Author Topic: Santa came late this year...  (Read 20105 times)
« on: December 28, 2011, 11:37:47 AM »
Re: Santa came late this year...
« Reply #1 on: December 28, 2011, 12:38:05 PM »
LOL, nice can ya send some super cheap?  :noel:
« Reply #2 on: December 28, 2011, 12:44:53 PM »
You plan to decap and resell I guess?
How many do you have in that bag? From the picture I estimate about 100  O0
« Reply #3 on: December 28, 2011, 12:46:13 PM »
NOG price on a set?
« Reply #4 on: December 28, 2011, 01:21:14 PM »
88 total. I plan to decap then flowmatch them like ID does. I just bought a fuel lap FPR and marren damper for my test rig. The only prob is they won't fit Hondas until I turn down the inlet, then they'll fit just like stock. I have a couple uscar-to-obd1 adapters, so they will be plug and play on Hondas. I'll definitely be running these on all my personal cars.
For price I'd have to consult with Sewell, we're going to be running a racket. Definitely cheaper than any other cleaned/matched high-flow saturated injectors.
« Last Edit: December 28, 2011, 01:23:40 PM by HiProfile »
« Reply #5 on: December 28, 2011, 01:25:02 PM »
good work sir
« Reply #6 on: December 28, 2011, 01:28:40 PM »
What is the planed flow of these bitches?
« Reply #7 on: December 28, 2011, 01:56:44 PM »
Super nog prices for the ogs?  :noel:
« Reply #8 on: December 28, 2011, 02:56:22 PM »
How much will they flow?
« Reply #9 on: December 28, 2011, 02:58:34 PM »
« Reply #11 on: December 28, 2011, 04:46:39 PM »
The only one I tested so far flowed 705cc, but at cold temps so they may flow more. As-is they'd be ID800's if ID was to name them.
In other words, enough for 400whp at ~85% or so. Regardless you can do the math at RC's website.
« Reply #12 on: December 28, 2011, 04:52:01 PM »
ID800?
I was hoping closer ID1000 or higher.  :noel:
Any possibility of any higher flowing ones?
« Reply #13 on: December 28, 2011, 04:53:28 PM »
In for Noggle price!
theidealone
« Reply #14 on: December 28, 2011, 04:55:06 PM »
Id be interested in a set. Itd be nice if someone could reproduce the 2000s.
tekno
« Reply #15 on: December 28, 2011, 06:18:50 PM »
I want a set. They going to be cheaper than racetronix? ???
« Reply #16 on: December 28, 2011, 07:11:51 PM »
« Reply #17 on: December 28, 2011, 08:16:15 PM »
even cheaper than oczc
« Reply #18 on: December 28, 2011, 10:22:22 PM »
Here's the thing, I saw someone selling modded crown vic injectors, which are the same or smaller. They flowed 840cc, so I'm just hoping the 20* temps affected my bench drastically.
In any case, once I get Tom his injector controller, he'll be able to get you noglets "ID1000" size injectors. Probably bigger, too.
If you mean their $49 Siemens 80lb'ers, they'll be cheaper and spray better. Just keep in mind I'm going to be turning down 88 injectors, cutting off 88 restrictor caps, then flow matching 88 injectors at 3 different duty cycles. Price will be determined, mainly because I don't want to bend you nogs over a barrel, nor do I want to work for free. :P
« Reply #19 on: December 28, 2011, 10:42:35 PM »
Sweet!! Keep a nigga updated!!
« Reply #20 on: December 28, 2011, 10:56:08 PM »
I forgot to mention I turned down some Denso and Bosch injectors I plan on running in my DD. My grampa's lathe works well so far. So the machining side of things will be fine once I get the lathe a live center.
theidealone
« Reply #21 on: December 28, 2011, 10:56:52 PM »
Ill be in for a set. And if Sewell can make something close to 2000cc, Ill be in for a set of those as well.
« Reply #22 on: December 28, 2011, 11:10:21 PM »
i dont see the problem there?
better question is: will they fit the green 1991 Galant VR4 parked in my driveway?  :noel: :Jew:  if i bought some i would be lookin for 550+whp E85 injectors... (already have 450/560/680cc injectors for it)
« Reply #23 on: December 30, 2011, 12:08:41 AM »
They should fit a VR4, but you may have to shim the fuel rail. They will be 48mm from rail to seal, DSM's are ~43mm.
Denso 24lb'ers before:
After:
I always wanted a purple injector. ;DDD
« Last Edit: December 30, 2011, 12:11:05 AM by HiProfile »
« Reply #24 on: December 30, 2011, 02:52:14 AM »
If you are still using mineral spirits I'm pretty sure that that flow number is low.  If those are the 040 core it's a nominal 820cc at 43.5 psi.
slappynuts
« Reply #25 on: December 30, 2011, 04:28:29 AM »
If you really want to know send them to me,we have an actual flow bench. I just got done decaping 100 injectors on the lathe and then flowing/matching them.
« Reply #26 on: December 30, 2011, 04:39:20 AM »
FUCK YOU!
I want a set!
No chance of getting high-tech and matching them according to dead times, amirite?
« Reply #27 on: December 30, 2011, 09:58:29 AM »
I just said I'd be matching all 88. I won't be going as crazy as ID has, but just ask Tom about how extensive they test them currently. You'd be surprised.
« Reply #28 on: January 03, 2012, 10:43:11 AM »
Update?
« Reply #29 on: January 03, 2012, 11:51:02 AM »
We're thinking $449/set for Tom's larger injectors, $425 for mine. :evil:
The price will probably be HALF that or less for 4.
