Author Topic: Filling Block... How To  (Read 36318 times)
CRX304
  • lick my gooch
    • My Music
« on: March 07, 2009, 08:47:48 PM »
ok, so this is basically common sense but here is a how to on what i did.
things that you need:
- stripped block of your choice
- epsom salt
- devcon liquid aluminum www.grainger.com ($45)
step 1:
make sure block is level (use a level on the deck)
step 2:
look to see that H2O drain plug is still in block, but loose
step 3:
w/ h20 pump removed, duct-tape up where the H2O pump was
step 4:
 pour salt evenly into the H20 jacket
step 5:
take a screwdriver and find height just abovethe H2O pump hole and mark it on the screwdriver
step 6:
take screwdriver around jacket at predetermaned height to make the salt even
step 7:
mix proper ammount of devcon liquid aluminum about 3/4lb
step 8:
pour slowly (leaving approx 3/16" from deck) ***take finger and run around jacket removing excess... works well***
step 9:
let cure at room temp for 2 hours and the at 200* for 4 hours. what i did was put the block over a heat vent and shut the rest in the house. so it was basically F.I. even before it was in the car 8) then after 4 hrs w/ heat, let stand @ room temp for 18 hrs
step 10:
pull drain plug after 24 hours (full cure time) and run water thru it to remove salt (at least 5 minutes) remember to spray WD40 in bores after H20
step 11:
put "new" gasket on top of block and mark it w/ a sharpie where the coolant holes go
step 12:
use a undersized drill (1/8") to make a "pilot hole" and on the slots, drill 2 holes for the outside radai of each slot
step 13:
goto larger sized drill and open up the holes, and slots
step 14:
blow out block after drilling then rinse w/ H20, respray WD40 in bores
step 15:
macine work, have it honed or bored or whatever
step 16:
rebuild
now, here's the thing....
i want to dispell the myth about the overheating issue....
if done right, you will have no problems at all.
 i have drove my car for 100 miles so far w/ no T-stat and the gauge hasn't went above C. i also can just barely feel any heat comming out of the vents. so if worse come to worse, and you are getting hot w/ the T-stat installed, remove it and you will see a temp drop.
good luck!
Dr. Mike
« Last Edit: March 07, 2009, 08:59:31 PM by CRX304 »
My old CRX :
Re: Filling Block... How To
« Reply #1 on: April 25, 2009, 02:49:15 PM »
zc
« Reply #2 on: April 25, 2009, 04:09:01 PM »
Never seen a block filled at the top before, Very interesting.
Nice work
« Reply #3 on: April 25, 2009, 06:10:41 PM »
I have mine filled.
B16Drag
« Reply #4 on: April 28, 2009, 02:28:57 AM »
CRX304, did you ever find out a good way to make those holes WITHOUT drilling the shiet out of it? Thought about using some PIXIE STIX :noel:
esi42
« Reply #5 on: May 02, 2009, 09:54:45 AM »
Closer pics?  ;D
This is interesting..
How far down the water jacket does it go?
