Forum > Fabrication
Small Block Chevy Single Turbo Build
<< < (9/10) > >>
HiProfile:
--- Quote from: carkrazed on April 16, 2012, 10:19:21 AM ---
--- Quote from: dvst8r on April 16, 2012, 10:11:34 AM ---3/8's O-ring would be my guess.
--- End quote ---
That's what I figured but everything that I've seen that took a straight cut o-ring fitting, had a little race on the port to accept the o-ring. This doesn't.
--- End quote ---
Use -6 AN o-rings! The o-ring is put on the thread-less area at the base of the threads, and seal on the outter chamfer on the female fitting.
Either get a "straight-cut" fitting that only uses an o-ring, or cut off the flare end on the AN fitting. If it screws in w/o bottoming out, you can just pop on an o-ring.
PhilStubbs:
Maybe npt?
Tim:
3/8 oring would be a -906 I believe.
if a -6 AN is the same 9/16-18 thread an SAE -6 is.
Passenger:
--- Quote from: SecksyPeePee on April 16, 2012, 12:22:24 PM ---Maybe npt?
--- End quote ---
Sounds like BSPP, which is the rest of the worlds version of npt, sort of.
PhilStubbs:
i am familiar, hondas use that for the oil pressure switch. i tap all of my blocks for npt, to make turbo plumbing easier
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
