Author Topic: 74 Civic 1200  (Read 12546 times)
JaredKaragen
74 Civic 1200
« on: February 24, 2012, 09:31:47 AM »
Needs a drive axle (clicks extremely bad), and a new charging system and it will be my daily driver.  I think the oil pan is leaking something fierce..... Gonna get it on a lift to track down.
Vidz on my YouTube channel.
Click the ad's. Make my broke ass rich.
YouTube.com/JaredKaragen
slappynuts
Re: 74 Civic 1200
« Reply #1 on: February 24, 2012, 09:38:28 AM »
My first car was a 1979 civic
Re: 74 Civic 1200
« Reply #2 on: February 24, 2012, 02:35:13 PM »
God danm thats sexy!
Re: 74 Civic 1200
« Reply #3 on: February 24, 2012, 05:04:43 PM »
jealous
Re: 74 Civic 1200
« Reply #4 on: February 24, 2012, 07:07:58 PM »
I like the wheel chock almost as much as the shift lever.
Re: 74 Civic 1200
« Reply #5 on: February 24, 2012, 08:03:08 PM »
needs a D and 10psi
JaredKaragen
Re: 74 Civic 1200
« Reply #6 on: February 24, 2012, 10:46:43 PM »
What about the OG drivers side seat "support" bracket I added? Lol
Re: 74 Civic 1200
« Reply #7 on: February 26, 2012, 10:29:48 PM »
Saw that took a sec. Good find. Needs some side drafts and a delta regrind
Re: 74 Civic 1200
« Reply #8 on: February 27, 2012, 04:08:45 PM »
are you using a crank for a parking brake?
JaredKaragen
Re: 74 Civic 1200
« Reply #9 on: February 27, 2012, 05:59:07 PM »
Ya, only when on hills and I need to idle the engine, otherwise I leave it in gear.  That's a jdm d15b crank :).  The ebrake cables need adjusting but I am waiting till I do my brake line replacement to adjust em.
Re: 74 Civic 1200
« Reply #10 on: February 27, 2012, 06:35:38 PM »
Do you have another one of those jdm d15b cranks?  :noel:
JaredKaragen
Re: 74 Civic 1200
« Reply #11 on: February 27, 2012, 08:33:30 PM »
i wish i did.
this one is a weld and regrind canidate...   id sell it for $40 XD
Re: 74 Civic 1200
« Reply #12 on: February 28, 2012, 07:50:09 AM »
It's not now. Bitch is probably warped.
Re: 74 Civic 1200
« Reply #13 on: February 28, 2012, 10:30:26 AM »
perfect candidate to do the old skool goldwing pistons mod.
JaredKaragen
Re: 74 Civic 1200
« Reply #14 on: February 28, 2012, 05:02:13 PM »
balance comes with weld and regrind... perfect cantidate.
anyways, no goldwing mod, i plan to do an obd1 swap, z6 or gsr.
Re: 74 Civic 1200
« Reply #15 on: February 29, 2012, 11:17:33 PM »
Fuck yeah, and a 1300cc crank and some head work ,o ring the block and run a set of side draft webers.
Ravage70
Re: 74 Civic 1200
« Reply #16 on: March 03, 2012, 12:36:54 PM »
Better pray you don't get into an accident with that tin can...
JaredKaragen
Re: 74 Civic 1200
« Reply #17 on: March 03, 2012, 04:48:20 PM »
Hahaha, see, I didn't care how crappy of a condition it was in because I planned on making a full cage in it;  engine guard, the works.  I would tuck the cage as close to the body rails as possible, but cut holes in the body/firewall for things like a pillar bars.
I didn't plan on it having an accessible back seat, I would probably open the trunk box to expand it there.
There were other ideas to do a mid/rear engine in this puppy.  It would take a lot of work, but I am more than compitent.... I just lack the location to do such a drawn-out project.   Maybe if I am lucky, In the future my boss will let me use the shop.
Re: 74 Civic 1200
« Reply #18 on: March 06, 2012, 02:31:27 PM »
I would just make it nice and cruise it. Find a rotted out beater to make into a racecar.
JaredKaragen
Re: 74 Civic 1200
« Reply #19 on: March 06, 2012, 08:20:01 PM »
Lol...
This car fits that description... Minus the race car portion ATM :)
Re: 74 Civic 1200
« Reply #20 on: March 06, 2012, 11:09:24 PM »
i would be sticking a D with a 14b in there and just cruise
JaredKaragen
Re: 74 Civic 1200
« Reply #21 on: March 07, 2012, 07:26:24 PM »
I'm planning on mounting a turbo directly to the intake manifold, and a ~50-70mm side draft carb to this bitch on the stock motor before I pull it out...
I really want to abuse this 1200cc engine as much as possible... After all it was free!
Re: 74 Civic 1200
« Reply #22 on: March 07, 2012, 11:46:44 PM »
Will not last long 2pc intake valves.  :noel:
