Author Topic: ok wtf. D-series clutch/fylwheel help?  (Read 8553 times)
« on: April 28, 2012, 04:00:41 PM »
ok. so my swap came out of a 90 CRX Si. and i have a ACT H-023 pressure plate.... shit wont fit?!?!
pressure plate wont line up close to all the dowels. seems to be a little but bigger than the bolt pattern of the flywheel. my Bseries PP is even a little bigger than this one. wtf?
all D-series pressure plates (and discs) are the same 90-00?!?!
fuck i hate this project.
Re: ok wtf. D-series clutch/fylwheel help?
« Reply #1 on: April 28, 2012, 04:15:38 PM »
88-89 use a 200mm clutch, 90+ use 212mm. It's a Civic, crx, or integra, NEVER assume it has all it's original parts.
Before you go nuts, try all 3 angles with it. It will be close in 2 different positions, but only fit the third way.
« Reply #2 on: April 28, 2012, 04:45:48 PM »
swap was assembled when i got it. i compression tested it.
i spun that PP around 6 times. it seriously looks just a hare smaller than the flywheel.
Eggylshatch
  • Pen15 Club President
« Reply #3 on: April 29, 2012, 01:27:05 AM »
Could you have an 88 flywheel/pp?  They were a different size.  I had that happen with my civic, bastard blew the engine and put a new one in (but engine was 88), and the tranny was 91, different size shit swapped around to make it work, made for a cluster fuck trying to figure out what was going on.
« Reply #4 on: April 29, 2012, 01:34:29 AM »
Model          CRX
Year          1989
Door / Version          2DR / SI
Transmission         5 Speed - Manual
FUCK... really? people still dont know what kinda car they have? he wrote me a bill of sale for the motor. it says 1990 CRX Si... that above is a copy paste from majestic's website (i cant log into honda from my PC lol)
PS, i need a 90-00 flywheel like last week. pm/text me...
« Reply #5 on: April 29, 2012, 10:16:45 AM »
I have a few but shipping will suck from WI. Right now I just use them for frisbies (yes I'm badass :P).
« Reply #6 on: April 29, 2012, 11:07:06 AM »
I had a 90+ flywheel, 90-91 pressure plate in the tprc with a prelude disc (different splines on the 1988 TRANS) and a rt4wd wagovan release bearing. Mike hooked that shit up lol.
« Reply #7 on: April 29, 2012, 12:17:12 PM »
They for in z flat rate box from the usps ;)
« Reply #8 on: April 29, 2012, 12:45:38 PM »
correction, an entire flywheel/disc/pp can fit in a usps flatrate box  :Jew:
« Reply #9 on: April 29, 2012, 05:40:25 PM »
JDHH
« Reply #10 on: May 03, 2012, 12:51:57 AM »
**UPDATE**
Russ FTW. he hooked me up with a deal on a aftermarket 90+ flywheel. just double checked it with the ACT PP, and it lines up! the dowels are little big, or holes a little small, but easy fix...
now, back to the trans...
