Author Topic: My winter project (1350whp Bitches)  (Read 53809 times)
« on: May 11, 2012, 01:23:30 PM »
Here is what I worked on and off this last winter, we just finally had it out to the dyno middle of this week.
Yes I suck at taking pics as I go, so there are weird leaps, and missing shit, but until someone comes just to hangout and take pics this is as good as it gets. My phone is the only camera I own.
I still need to find a picture of it before I modded it at all, but I don't seem to have one, I will ask around and maybe add that at a later date.
Here is where I started, I had already added that abortion of a longer aluminum tube off of that turbonetics t66. Prior to that there was a short silicone 2.5->3" hose that kept splitting, and eventually caused us to run over the charge pipe at 140mph. That abortion, was just a temporary thing to get it through 1 sled pulling event.
Here is the intake manifold before I pulled it off the truck, the niggers that put it on there couldn't read a torque wrench and cracked it, I spent a lot of time repairing those cracks, but like lots of things didn't bother to take pictures:
Here is where I went with it:
Here is the new secondary turbo (billet wheel s476):
Here is what I had to make for a cover so it would all fit:
One of the biggest complaints of the old system (besides all the leaks, and blown silicone couplers) was how hard it was to work on, and remove the turbo's when needed, so here is where I went with that, starting with the new hotpipe:
Now that we don't have to support that S500 (billet 105mm) from the engine hoist (weighs about 80lbs) anymore, we can start on wastegates and charge piping (I really did a poor job of taking pics here) also some parts ready to go to ceramic coating:
Fast forward to done, or almost done, as the last few weeks of the build I took no pictures. I had too much going on and the few minutes that I had to work on it, I did just that work:
All of that work was rewarded when we hit the dyno (mustang dual roller eddy brake), and put this up, with obvious tire spin (see video):
The best the truck had done previously on the same dyno was 1170hp corrected (not sure of the uncorrected number that day, but that is what I go by, corrected numbers don't mean shit)
Here is a video of the best pass to date:
Ragged Edge Racing, Edmonton NHRDA
They are going to the track tonight to do some shake down passes, but the real test will be at the beginning of June in Mission for the BD trucking nationals. Hoping to knock out some Low 9's. I will also try to find a good sled pulling video.
Some quick specs on the Truck:
-2005 quad cab short box 4wd
-Current weight 6800lbs
-Tuned with Smarty SSR (by me) will goto efi live as soon as released.
-Spool rear, Eaton E-Locker front.
-Lowered about 4"
-All steel and real glass, other then the hood, which turned out to weigh as much as the stock hood, and looks silly in my opinion. Power window's still work, but other then that the interior consists of a cage and two race seats.
« Last Edit: May 11, 2012, 01:26:24 PM by dvst8r »
Re: My winter project (1350whp Bitches)
« Reply #1 on: May 11, 2012, 02:02:59 PM »
what you have done here, I love it!
« Reply #2 on: May 11, 2012, 03:30:37 PM »
« Reply #3 on: May 11, 2012, 07:31:07 PM »
Fuck man, that pig is flyin!
« Reply #4 on: May 11, 2012, 09:42:39 PM »
Fucking sick  O0
« Reply #5 on: May 12, 2012, 12:53:27 AM »
Oh fuck me.........
That's Shit hot!!
« Reply #6 on: May 12, 2012, 09:31:19 AM »
That build deserve 3 french words: C'est hot en tabarnak!  :noel:
I want. Reminds me that my car is slow as fuck.
« Reply #7 on: May 12, 2012, 03:33:56 PM »
They took it to the track for some shake down runs, I guess it was a really busy night (street legal's). Only made 4 passes, and they fought an electrical issue all night, so no overdrive. As such they were out of gear before the 1/8th mile. Best pass of the night was 10.88@111mph bouncing on the rev limiter from before the 1/8th.
I am gone to work, so this is all just second hand information. Sounds like they are going to re wire the overdrive (we just went to a manual valve body) and be out to Medicine Hat next weekend. Again I am going to miss that event, as I will be at knox mountain with highroller54, brine04, Trevor72 ect... Hopefully they have it sorted and can click off some mid to low 9 passes.
The good thing was, other then no overdrive, and one small oil leak that just required some Teflon tape to seal, up the truck was pretty much ready to hot lap all night.
« Reply #8 on: May 12, 2012, 03:54:54 PM »
The new head is comming along nicely. This thing is a beast.
« Reply #9 on: May 12, 2012, 05:16:26 PM »
Now you just need to get the block cut apart, and start designing those sleeves.  O0
« Reply #10 on: May 12, 2012, 06:09:09 PM »
Likely this week man O0
Head is mostly ported, still need to put the new seats, and cut out some more of the head so we can re shape the ports a bit more. Exhaust is already around 300cfm, gonna see if I can get the intake that high as well. The custom valvetrain is here so we are on it.
« Reply #11 on: May 12, 2012, 08:42:38 PM »
So how much more does this swap weight vs a K-swap? :evil:
« Reply #12 on: May 13, 2012, 12:04:10 PM »
LOL, about the same weight as the rest of a rolling civic. That engine dressed with pumps and manifolds (no turbo's) with oil is about 1200lbs. But it runs on pump diesel.
lsone_chevelle
« Reply #13 on: May 13, 2012, 10:14:33 PM »
saw you at castrol on friday. Truck sounds great. If I knew you were associated with the truck I would have stopped by!
« Reply #14 on: May 14, 2012, 12:21:02 AM »
Hard to miss that motorhome / stacker trailer. Not sure what our next event in Alberta will be, but I will let you know.
lsone_chevelle
« Reply #15 on: May 14, 2012, 08:28:40 PM »
never even saw where the truck was parked. Your stacker?
« Reply #16 on: May 14, 2012, 09:37:00 PM »
We were up front in the pro pits, no the owner of the truck's motor home and stacker.
« Reply #17 on: May 15, 2012, 12:37:17 AM »
I'm curious what that spring-loaded thing is in front of the lower/front-facing turbo? Hand-actuated boost/flow controller?
bouncinofftherevlimiter
« Reply #18 on: May 15, 2012, 01:07:49 AM »
Plate that cuts air flow in case motor takes off and kills motor, a lot of pulling classes require them.
No longer own a turbo car...
HX35 18lb 486hp/391tq
« Reply #19 on: May 15, 2012, 01:17:21 AM »
It's a guillotine to shutoff air flow if the engine ever tries to runaway.
« Reply #20 on: May 15, 2012, 07:05:37 PM »
Ive seen videos of that when the motors start running on oil. Fucking insane.
« Reply #21 on: May 15, 2012, 07:18:15 PM »
For this reason exactly, the pulling class the truck runs in requires it.
lsone_chevelle
« Reply #22 on: May 15, 2012, 11:41:27 PM »
On the return road side of the track? Yea thats where we were. Must have looked right past it lol. I did notice a dodge with 4 stacks. Thats a treat LOL.
« Reply #23 on: May 16, 2012, 12:08:23 AM »
I've seen them do it in person. Giant 2000+ HP quad turbo v16 on a Frac pumper take off and ended up tossing rods and shit, it was epic!
« Reply #24 on: May 16, 2012, 12:52:41 AM »
Yup return road side of the track, just up towards the track from where you saw that fag mobile. I'm surprised you don't see that truck everyday, he is from your neck of the world.
DSharp
« Reply #25 on: May 16, 2012, 11:29:45 AM »
jesus that things a beast!
NoPistons!
« Reply #26 on: May 19, 2012, 09:45:05 PM »
Speechless.
Fuck yeah for compound boost running 9's in a full size truck.
« Reply #27 on: May 21, 2012, 10:05:43 PM »
Got word it knocked out the converter in the pits before the first hit. Guess we hurt it in Edmonton, and that was part of our issue getting it to lock. It is at the trans guys place, trans is out waiting for the converter to be here early this week.
« Reply #28 on: May 21, 2012, 10:46:09 PM »
Holy shit, I could get a full turbo setup for the cost of all those gauges! Bitchen setup though!
Eggylshatch
  • Pen15 Club President
« Reply #29 on: May 22, 2012, 05:46:21 PM »
Any turbo setup that requires a "kill plate" to cut off airflow in case the turbos  TAKE ON A LIFE OF THEIR OWN AND BECOME TOO POWERFUL TO CONTROL get two thumbs and a boner way up from me.
