Author Topic: 723 WHP S-ER Sentra dirty 4ths AND 5th gear burnouts.  (Read 19609 times)
RotaryGeek
« on: May 26, 2012, 04:20:30 PM »
This is my friends car, just got tuned at Converse in San Antonio on Thursday to 723 WHP. Was shooting for 800+ but didn't bring a strong enough wastegate spring. Only got 29 pounds of boost out of the turbo. He will be going back to get more tuning done after the SR20-forums.com meet in Ohio next week.
Uploaded with ImageShack.us
Me getting some turbo oral sex lol
And here is a vid of it going out on the highway. 4th and 5th gear burnouts from 70. Look how long his speedo stays pegged out lol. And his speedo goes to 150 mph. Sorry about the sound, i don't know why it didn't come out.
Ashton's S-ER Sentra 723whp
RotaryGeek
Re: 723 WHP S-ER Sentra dirty 4ths AND 5th gear burnouts.
« Reply #1 on: May 26, 2012, 04:22:15 PM »
Oh, forgot to mention this is on drag radials as well. Tuned with AEM EMS and running C16 gas.
And here is his build thread on the SR20 forum.
http://www.sr20-forum.com/turbo/45952-new-setup-build-updated-5-25-12-723whp-31.html
« Last Edit: May 26, 2012, 04:24:11 PM by RotaryGeek »
« Reply #2 on: May 26, 2012, 05:49:58 PM »
So does your buddy blow you or do you blow him?
« Reply #3 on: May 26, 2012, 06:55:11 PM »
transmission specs? death count?
RotaryGeek
« Reply #4 on: May 26, 2012, 09:41:00 PM »
The tranny is a newer 6 speed S-ER with a JDK spec bell housing (it's thicker). He has killed a bunch of transmissions in the last couple set ups, but this one also lived through his last build which was 650 whp.
« Reply #5 on: May 26, 2012, 10:14:13 PM »
Cool setup.
Great power.
Mo traction
Useless car...
No wonder trannys dont break LOL
« Reply #6 on: May 27, 2012, 12:42:50 AM »
Ill post up my buddy sr, he going to the same meet. Sr20vet, 20v head, sleeved, 6567 bb turbo, getting tuned this week. The main difference is my buddy hooks all 4   ;)
RotaryGeek
« Reply #7 on: May 27, 2012, 12:47:27 AM »
Post it up man, I'll bet they end up racing at the meet. We will see who wins.
« Reply #8 on: May 27, 2012, 12:59:49 AM »
Wow 20v head? I never heard of that how rare are those?  :noel:
RotaryGeek
« Reply #9 on: May 27, 2012, 01:22:57 AM »
I haven't either, but it sounds badass.
« Reply #10 on: May 27, 2012, 10:03:51 AM »
It's a rare head, but it's not a 20valve head, the valve cover is stamp 20v. Ports are bigger, better shape, and seems to make more power.
ashtonsser
« Reply #11 on: May 27, 2012, 02:32:04 PM »
Thanks Eldon for posting up.  Here is the setup.
Will be going to the track next weekend during the Convention.
Setup:
SR20VE block Sleeved and stepped by Mazworx. Drilled for 1/2" studs
SR20VE head w/ mild port work and port matched to the manifolds.
Mazworx 1/2" Headstuds
SR20VET metal headgasket
SR20VE oil pump and stock SR20VE crank pulley
SR16VE N1 cams
Supertech 130 lb Springs and Titanium retainers, Stock valves.
Custom Crower Billet Steel I beam rods
CP SR20Ve 9:1 86mm pistons w/ upgraded tool steel pins and upgraded clips
ACL Race 5 hole main bearings
ACL Race 19mm GTIR rod bearings
GTIR main bolts
AEM EMS
AEM Twinfire (new box)
Denso GSXR coils
AEM boost, fuel, and wideband gauges
AEM EGT sensor
Comp Clutch Custom 6 speed swap Twin Disk Clutch
04 Spec V 6 speed trans mated to a JDM P12 Bellhousing
Stock Spec V axles w/ B13 outer CV joints
DOC Race Equal length open scroll T4 manifold w/ JGS 50mm flange
JGS 50mm wastegate w/ 1 bar spring
BW S400SX billet 67mm w/ 1.10 AR turbine housing.  Divider was thinned out and port matched to the manifold.
BMC Race Custom Intake manifold
Golden Eagle B-series Pro series fuel rail
ID2000 injectors
Sumped stock tank
Weldon 1100-A fuel pump
Weldon fuel filter
-10 feed line
-8 return
Weldon 0-200 regulator
k-sport coilovers
ES bushings all around
Racing Hart Cybers w/ 225/50/15 drag radials for dyno use.
All work and assembly was done by me. Tuning done by Jorge at JMS Racing.
Here is a vid of the dyno.  Going back after the Convention to hit that 800+whp goal.  Just a wastegate spring swap away and maybe 35-36 lbs of boost. Plan to go to 40 lbs of boost.
723whp Turbo Nissan Sentra SE-R Dyno
« Reply #12 on: May 27, 2012, 02:41:07 PM »
ah you saw my post on HT eh? Cool car Now... Post porn fucker  :evil:
RotaryGeek
« Reply #13 on: May 28, 2012, 05:04:28 AM »
Haha yeah Ashton, that's the rules here. Noobs have to post porn lol.
« Reply #14 on: May 29, 2012, 01:01:20 PM »
krazy4
« Reply #15 on: May 29, 2012, 01:56:55 PM »
What's up with the altima?
Looks pretty legit!
« Reply #16 on: May 29, 2012, 02:40:48 PM »
Looks pretty legit!
Its not a altima ;)
« Reply #17 on: May 29, 2012, 07:02:33 PM »
Looks pretty legit!
Its not a altima ;)
U13 Bluebird SSS?  Also AWD?
ashtonsser
« Reply #18 on: May 29, 2012, 07:25:45 PM »
Yeah and goodbye awd gearbox.  Most of the gtir's and bluebirds dont handle good at 700+hp even with a dogbox, then goes the rear case.
« Reply #19 on: May 29, 2012, 10:42:49 PM »
Looks pretty legit!
Its not a altima ;)
Yes on some volks and fatty MT.
Car has been to gather for some time, only thing he had issues with was the fd, but that is what the custom straight cut fd is for :evil:
ashtonsser
« Reply #20 on: May 29, 2012, 10:46:17 PM »
Here is the vid done by JMS Racing.
https://www.facebook.com/photo.php?v=2930323352084
RotaryGeek
« Reply #21 on: June 02, 2012, 02:31:25 AM »
So just testing it out tonight he bogged on the launch and ran 10.5 at 147. Hopefully breaking into the 9's tomorrow at the meet.
krazy4
« Reply #22 on: June 02, 2012, 06:36:29 PM »
I wanna see the "altima" and the sentra run. That'd be a cool race to watch.
RotaryGeek
« Reply #23 on: June 03, 2012, 08:41:20 AM »
I haven't talked to him, but he posted on Facebook that he fucked a bunch of stuff up in the bottom end. Spun a bearing, shattered oil pump, and something else.... So 10.5 was the best he got out of it.
« Reply #24 on: June 03, 2012, 09:40:37 AM »
 He didn't end up going, ran into issues tuning a lifted the head. 25psi 630 hp and that was only on the low cam, wasn't crossing over.
krazy4
« Reply #25 on: June 03, 2012, 10:48:03 PM »
Damn, that sucks. He just got it going too.
ashtonsser
« Reply #26 on: June 05, 2012, 09:38:10 AM »
Yeah, had a 10.5@149.2 mph with a bogged 1.777 60 ft and horrible 330, babied the gears.  Next pass I had a 1.64 60 still bogging a bit but hit 2nd quick and my 330 was .4 faster than the 10.5 run but missed 3rd and just cruised it to a 10.6@132. Saturday my first run against the Mazworx GTIR I pulled another 1.64 60 ft bogging a bit and let off at about 900 ft right after I got into 4th.  I lost oil pressure probably somewhere in 2nd or 3rd gear as I was pounding off the 10k limiter.  Felt it bog and let off.  Started it back up and heard some nasty knocking from the crank more than likely and motor was turning over slow like it was binding.
Hopefully It didnt damage the main journals.  Crank is probably toast and bent by the looks of things. I have all the parts except bearings to fix it but its going to have to wait till I come back from Afghanistan before I can fix it.  It will get that 9 second pass at 150+.  Ill bring it back out with even more power and less revs to hopefully keep this problem from happening again and some other small changes.  All in all it doesnt look like anything too major to fix but wont know for sure until i rip into it.
« Reply #27 on: June 05, 2012, 12:26:13 PM »
Thats all part of the sport, just dont give up and keep it moving.
« Reply #28 on: July 02, 2012, 12:35:20 PM »
Cool setup.
Great power.
Mo traction
Useless car...
What kinda tard would run 700+ in a fwd car? lol
Any updates on this car?
ashtonsser
« Reply #29 on: July 07, 2012, 01:03:25 AM »
Yeah, got some changes in the works.  When its back out it will be making upwards of 850-900whp, less revs to keep oil pump issues from happening, some serious head work, and a bit more displacement.
As for having 700+whp in a fwd car. Its a drag car and with boost by gear you can have full traction all the way down the track.  At least I did on my first and 2nd pass.  Putting about 500whp down in 1st and 2nd and full 700+ down in 3rd and 4th.  3rd and 4th could easily see another 100-150whp more without having traction issues with the way I have the cars alignment, tire pressure, and suspension set up.
It will be back out when I get back from another year in Afghanistan.
700+HP B13 SE-R tuned by JMS Racing!!!
