Author Topic: TD05-18G prep for T3  (Read 19430 times)
JaredKaragen
« on: June 22, 2012, 01:31:00 AM »
Damned fucker I got the 18g from did a shitty job trying to add a T3 flange to this turbo.
Did it up DGAF RHMT style. If it cracks, I'll just get a new hot side.
Turbo repair RHMT style
Pics when it's cleaned up.
Hopefully California pigs don't know it's not CARB legal and let me get away with it.
Emperor
Re: TD05-18G prep for T3
« Reply #1 on: June 22, 2012, 03:10:13 AM »
looks like win for me ;DDD
so many times iam thinking about doing this on a subbi Td05....
RHMT Boost everything
-Cars
-Bikes
JaredKaragen
« Reply #2 on: June 23, 2012, 05:35:33 PM »
I don't get what the fuck you were doing there. Why wouldn't you just weld it with stainless rod?
They tried using a shitty wire feed that didn't adhere to the cast well at all.  A good tap with a hammer popped the flange off.
Why waste $$$ on stainless rod when you have all that flange material you can work into the weld.  Plus ideally you wouldn't use stainless rod on cast; they will cool exponentially different amounts and cause cracks as I got a few myself because the flange is stainless, need to touch it up before assembly.   This time I'll torch the housing red hot before welding to avoid further cracking.
« Reply #3 on: June 25, 2012, 11:14:34 PM »
I quite like 309 for welding cast.  :P
« Reply #4 on: June 26, 2012, 04:23:12 PM »
Ive welded cast a few times. Just heat that bitch up supper hot and then set the welder to nog and let her rip!
JaredKaragen
« Reply #5 on: July 04, 2012, 03:31:14 AM »
now to make a downpipe....
I have a 3" V-band adaptor.... but alas... I want to keep my A/C as I have it now.  So.... Maybe the OEM greddy elbow should clear =)  Just make a downpipe, swap out for the greddy oil line (unless I get lazy), and presto;  up from a TD04H-13C peewee to a TD05H-18G =)
then I REALLY will need a FMIC..... no beating around that bush.
« Reply #6 on: July 05, 2012, 03:41:10 PM »
Looks good. I would rock it!
« Reply #7 on: August 04, 2012, 04:15:24 PM »
damn man how'd u keep that from cracking wow good job
the only time i put a tig to cast it cracked the second i took the torch away.  lol
« Reply #8 on: August 08, 2012, 03:38:08 PM »
I'm curious, if MIG welding in this situation, would regular steel wire or 308/308L work better? And I'd guess pure argon would be best for the 308? This is the only stuff I have on hand.
« Reply #9 on: August 10, 2012, 03:06:57 AM »
I know it will work, but I have the stuff so I was just curious if it would hold better.
JaredKaragen
« Reply #10 on: August 10, 2012, 04:45:32 AM »
if u use oxy/acetaline... you use a coathanger for the best adhesion and cracking resistance...   oldskool trick... very solid when welding cast like a crack or something.
Im liking my buddies tig so far... gonna mess with it some more and try and get some aluminum work done for myself.
« Reply #11 on: August 10, 2012, 03:57:31 PM »
I've welded turbine housings with mild steel wire on a mig before. It doesnt work too bad. Just crank the heat and get it burned real good.
I also have done it, but I heated the cast iron up real fucking hot with a torch first, and set the mig to nog and let her rip!
