Author Topic: Went 10.608 @ 132.19 today.  (Read 26358 times)
Dr. D-Series
« on: April 19, 2009, 09:17:59 PM »
Hot. Its nice to back up my past runs. 4 10 second passes so far this year. Im ALMOST satisfied.
The bad news....
Coming out of the burnout box @ 8900 in 2nd gear the differential exploded.
So I only got one run in today, but at least it was decent.
Went soft on the car 1st run, lift throttle shifting @ roughly 83-8400 rpm every gear. (8900 normally)
I regret that now, should have went balls out and possibly brought home a 10.4x
BTW im glad that the car didnt lose any mph after adding the cage (75% done, 2 front posts and floor plates left to weld in).
Hot.
D16Y8-Z6.
Re: Went 10.608 @ 132.19 today.
« Reply #1 on: April 19, 2009, 09:25:36 PM »
Going welded diff? Sent that spacer out this weekend. Im impressed as always.
Dr. D-Series
« Reply #2 on: April 19, 2009, 09:30:37 PM »
Might go obx. I feel welded diff is too dangerous with stock axles. The wall hurts.
D16Y8-Z6.
« Reply #3 on: April 19, 2009, 09:37:26 PM »
Any problems  towing the car back with the damaged trans?
Dr. D-Series
« Reply #4 on: April 19, 2009, 09:45:07 PM »
Nope.
D16Y8-Z6.
« Reply #5 on: April 19, 2009, 10:02:04 PM »
Got one local to me. He was a member on OHMT
« Reply #6 on: April 19, 2009, 10:18:27 PM »
How was the boost today? Solid now, or still dropping off?
« Reply #7 on: April 19, 2009, 10:18:41 PM »
excellent, I admire you
but still
no vids = fail
hotrex
« Reply #8 on: April 19, 2009, 10:40:31 PM »
noone cares.
« Reply #9 on: April 19, 2009, 10:48:53 PM »
An OBX LSD may destabilize you, if you aren't careful.  Closely inspect the washers (where the diff pin used to be) and make sure they are arraigned so that they are a little tight when you close the diff up.  If you leave them out, or jingling, you may get that sweet unstable side-to-side under power phenomenon.  Makes it really hard to hold the car between the lanes.
BangBusMaster
« Reply #10 on: April 19, 2009, 10:50:08 PM »
Awsome time dude  O0
I'd be fucking stoked to run those times on that build.
« Reply #11 on: April 19, 2009, 10:58:51 PM »
Joe nice times as always! I have that obx for you, not 100% you will be able to use it but its yours.
hotrex
« Reply #12 on: April 19, 2009, 11:00:03 PM »
noone cares.
you managed 0-911 in 12.1 seconds of fire
u cant even afford to do that
« Reply #13 on: April 20, 2009, 12:03:50 AM »
Nice times on the setup.  :yes:
d-rail
« Reply #14 on: April 20, 2009, 01:33:25 AM »
noone cares.
Nobody has to be able to afford to do it. All anyone has to do is drive to your house and let you work on something.
d-rail
« Reply #15 on: April 20, 2009, 01:36:20 AM »
But on topic good job with the setup man and I can only dream of having as good of a time as you with like 10x the money in mine. Good luck and after I blow my motor to hell and back I'll be looking at you and your progress.
« Reply #16 on: April 20, 2009, 02:19:18 AM »
check your pm
and good work on the diff.  i blew one last year with a stock z6.  they're not the most robust part in the case
any videos?
caged
« Reply #17 on: April 20, 2009, 02:44:58 AM »
Good shit!!  :noel:
« Reply #18 on: April 20, 2009, 03:05:05 AM »
i bet you could get rhmt to sponsor you, in some way/form
I just sent him free parts so its already begun
BoostForLife
« Reply #19 on: April 20, 2009, 03:16:12 AM »
I was about to say that Chris is already kind of doing it.
« Reply #20 on: April 20, 2009, 03:23:42 AM »
JD, no complaints here on all my installs, the washers are to control noise, not preload.
Dr. D-Series
« Reply #21 on: April 20, 2009, 09:23:08 AM »
Anyone know which cable trans have small and large bearings ?
Obx only makes the lsd for 40mm bearings correct ?
BTW thanks guys.
D16Y8-Z6.
birdley42008
« Reply #22 on: April 20, 2009, 09:26:14 AM »
What is your 60 foot?
Dr. D-Series
« Reply #23 on: April 20, 2009, 09:30:57 AM »
It went 1.69
Not my best but not bad.
D16Y8-Z6.
« Reply #24 on: April 20, 2009, 09:31:03 AM »
Chuck, have two at the shop that fight you under power, where before they were stable peg leggers.
« Reply #25 on: April 20, 2009, 09:39:43 AM »
i thought it was pretty well known that civic's torque steer, mainly d series.
« Reply #26 on: April 20, 2009, 09:44:37 AM »
They don't when there's an intermediate shaft and an alignment involved.  Neither of these cars are D-series.
birdley42008
« Reply #27 on: April 20, 2009, 12:43:52 PM »
What gear do you preload in? Atleast 2nd or 3rd correct.
« Reply #28 on: April 20, 2009, 12:48:29 PM »
yep, but if you got the dough, quaffie makes the 35mm ones.  you should be able to find five 40mm trannys for the price of one quaffie 35mm diff
http://www.importdpsonline.com/Store/Product/ItmGroupDetail.aspx?GroupId=55998&Make=HONDA
might have to cross refrence the engine code to the tranny code but hope it helps
fysh
« Reply #29 on: April 20, 2009, 12:56:29 PM »
5mm
