Author Topic: F2D gay as aids na Ef  (Read 117609 times)
Rioreded6
  • Aintcare
« on: June 30, 2012, 09:37:51 PM »
D15b1 with arp headstuds, delta 272, 450's, t25, obd1 and tuned on crome by me.
VIDEO0015.mp4 Video by 2006gli | Photobucket
« Last Edit: June 17, 2015, 12:17:47 AM by Rioreded6 »
Re: Noob intro
« Reply #1 on: June 30, 2012, 11:33:04 PM »
Damn that WG opens right away, guessing boost hits like nAOW.
Porn could be better, but a self-built setup is rare now a days and appreciated. Let me be the first to wish you a merry x-mas and a happy FUCK YOU. :)
Re: Noob intro
« Reply #2 on: July 01, 2012, 09:27:30 PM »
Well done!
Rioreded6
  • Aintcare
Re: Noob intro
« Reply #3 on: July 02, 2012, 01:11:30 AM »
Added more timing changed out uncrushed 1g dsm bov for crushed dsm bov, it's somehow holding 11psi now guess I had a leak...
2006gli - VIDEO0016.mp4
Re: Noob intro
« Reply #4 on: July 03, 2012, 02:00:09 AM »
Not bad lovin the d15 action
evo_lucian
Re: Noob intro
« Reply #5 on: July 11, 2012, 12:24:06 PM »
Welcome noob
Re: Noob intro
« Reply #6 on: July 11, 2012, 01:30:37 PM »
solid intro. Welcome.
NoPistons!
Re: Noob intro
« Reply #7 on: July 16, 2012, 03:59:06 PM »
Welcome.  It looks cheap and dirty.  Porn is acceptable.  Do work!
Rioreded6
  • Aintcare
Re: Noob intro
« Reply #8 on: September 02, 2012, 05:43:40 PM »
Well it done blowed up. I guess running 13pounds and 23 degrees of timing wasn't such a smart idea after all...
2006gli - VIDEO0028.mp4
Re: Noob intro
« Reply #9 on: September 02, 2012, 06:17:45 PM »
Awesome what next?   :noel:
boosted 00 black si
Re: Noob intro
« Reply #10 on: September 02, 2012, 08:01:57 PM »
nice work :noel:
go fuck your self
BORN TO BOOST
LITTLE B16.400whp on 16psi
Re: Noob intro
« Reply #11 on: September 02, 2012, 08:12:05 PM »
Put another d15 in usually free engines
Rioreded6
  • Aintcare
Re: Noob intro
« Reply #12 on: September 02, 2012, 10:42:08 PM »
Another turbo motar. Rode in a friends na b20/vtec ed hatch and I was dissapointed. So unless I'm building a na h22 beast, which I do not have the monies for, I don't think I'm going back to na...
That one was free lol and the one before this previous one was $75.
I have two sets of vitara pistons, 2 d15b1 blocks, a d16z6 block, a dohc zc block, two dohc zc heads, some ching chong d16 rods, a z6 head, a good non vtak head and two good d15 cranks. If I can find a virgin d16 crank I'm going dohc zc with vitaras. Right meow it might just be easy and cheaper to build another d15.
« Last Edit: September 03, 2012, 02:24:40 AM by Rioreded6 »
Rioreded6
  • Aintcare
Re: Noob intro
« Reply #13 on: July 20, 2013, 08:27:37 PM »
So since everyone in this forsaken shit hole I live in treats d15/d16's like gold I decided to do a f2d build without cutting into my cars body. Everyone on the interwebs says its impossible.... fuck them I'm a magician.
Since I work at a stealership and people can't take care of there cars I stumbled upon a 99 accord f23a1 with a fucked up head that needed valves. Bought the core motor for $100 put new rod bearings in it, a poor mans balance shaft delete and threw the head away.
Poor mans b/s delete
Got a f22a6 head ($50) a month later that needed a clean up badly. That got done and "ported" the manifold
Got my taxes back and decided to throw my monies at Faggotmoto. Also got the hasport drivers side mount...biggest $150 I regret spending :<
Flywheel is stupid light imho
Tried cleaning up my harness
Hammered the shit out of the drivers framerail pretty good clearences  :noel:
Cut the block...Fuck this noise
Soon...
Re: Noob intro
« Reply #14 on: July 20, 2013, 10:14:06 PM »
I'm guessing you shaved the 3rd step off the f23 pulley?
In case you didn't know, the H22/H23 upper plenum bolts onto the f22a6 manifold. More plenum volume & throttle body options.
BTW Wanna sell the F23 intake manifold?
hatchbone
Re: Noob intro
« Reply #15 on: July 21, 2013, 12:29:31 AM »
Solid
NoPistons!
Re: Noob intro
« Reply #16 on: July 21, 2013, 04:14:50 AM »
That's a smooth bounce back.
"13pounds and 23 degrees of timing"    Yolololololo!
Rioreded6
  • Aintcare
Re: Noob intro
« Reply #17 on: July 21, 2013, 08:37:02 PM »
I'm using a k series pulley.
I know about the h series plenum.
Rioreded6
  • Aintcare
Re: Noob intro
« Reply #18 on: July 21, 2013, 11:19:52 PM »
K24 pulley. I used a hacksaw to cut where the timing cover seal rides on. I'm a idiot and didn't tighten the crank bolt tight enough so the id wallowed out.
So I bought another one and instead of hacking it up I took it to a machine shop to have it machined down. I made another mistake and misjudged the amount I needed them to machine off so I had to cut some of the pulley off myself. On the brake lathe she goes.
Finished product
Re: Noob intro
« Reply #19 on: July 22, 2013, 01:13:12 AM »
Good work  :noel:
Re: Noob intro
« Reply #20 on: July 22, 2013, 11:22:03 AM »
Why the k24 crank pulley? Other wise im liking this!
I have a f23 with k20 rods and pistons coming soon.
Rioreded6
  • Aintcare
Re: Noob intro
« Reply #21 on: July 22, 2013, 01:40:22 PM »
Space, price and availability. I tried using a kias, Nissan, various Honda/Acuras and some domestic shit. J-series fit but are too pricey and are huge. F/H-series stick out too much. K-series pulley is $45 for me, I can get them over nighted for free ninety nine, and they require the least amount of work to get them to fit.
Re: Noob intro
« Reply #22 on: July 23, 2013, 07:52:02 PM »
Ok I can see that because of the plate pushing it over.
Re: Noob intro
« Reply #23 on: July 27, 2013, 07:53:33 PM »
Nice.
Rioreded6
  • Aintcare
Re: Noob intro
« Reply #24 on: July 29, 2013, 11:09:01 PM »
Pulley differences. k24 far left modified f22a6 middle and broken jseries far right.
Plans have changed. I was going to run an gm-5 turdblow from a 90's era duramax but I just picked up a dsm manifold, o2 housing, feed/drain line and a ported evo 3 big 16g with no shaft play for $300
Re: Noob intro
« Reply #25 on: July 30, 2013, 01:22:49 AM »
what are you doing with the gm5 turbo?
Rioreded6
  • Aintcare
Re: Noob intro
« Reply #26 on: July 30, 2013, 08:15:37 AM »
I haven't decided yet. I've had the hot side milled down to block off the internal gate.
Re: Noob intro
« Reply #27 on: July 30, 2013, 02:09:19 PM »
Well if you decide to dump it, let me know. I'm sure I could possible have a buyer for you.
Re: Noob intro
« Reply #28 on: July 31, 2013, 10:17:39 AM »
Question on the homemade balance shaft eliminator kit. Did you block the oil ports for the balance shafts?
Rioreded6
  • Aintcare
Re: Noob intro
« Reply #29 on: July 31, 2013, 11:00:28 AM »
Yes, I blocked the oil passages to the balance shafts using solid dowels. Don't try turning the bearings...its next to impossible.
Pages: [1] 2 3 ... 5   Go Up
