Author Topic: 88 hatch no cluster or blinkers work?  (Read 9767 times)
« on: July 17, 2012, 09:11:50 PM »
Ok long and short bro bought a 88 std. Dude before him fucked up wiring. I replaced sub and dash harness with 90si. Now nothin works and yes i used the 90 cluster. Turn on headlight and check engine comes on. Turn blinkers no flash but temp gauge moves. Dunno what the fucks goin on help
DasPoop
Re: 88 hatch no cluster or blinkers work?
« Reply #1 on: July 17, 2012, 10:22:40 PM »
88-89 and 90-91 are not the same when it comes to wiring you will most likely have to repin some connectors. You go through the same when going to a dash with a tach most times.
« Reply #2 on: July 17, 2012, 11:06:26 PM »
But i used all 90 wiring. Headlights to tails and all inbetween the only thing i didnt change was fuse panel
DasPoop
« Reply #3 on: July 17, 2012, 11:10:37 PM »
again check switch connectors just because it plugs in doesnt mean it works
« Reply #4 on: July 18, 2012, 01:13:12 AM »
True
« Reply #5 on: July 18, 2012, 08:22:49 PM »
Ok so today went to picknpull got 90 hazard switch, blinker switch and relay out the fuse panel and still nothin. When i turn the head lights on the check engine lights up dim and when i turn the blinker on it gets brighter. The relay clicks so idk what the fuck to do now
