Author Topic: Block guard questionj  (Read 23160 times)
Zeniceguycrx
« on: April 28, 2009, 01:34:53 PM »
does the d16 guard work on thw ZC?
TT site says it doesnt, has anyone tried?
The 30psi king of rice
Dweezil
    • Michigan Civics
Re: Block guard questionj
« Reply #1 on: April 28, 2009, 09:49:14 PM »
What ZC?
Zeniceguycrx
« Reply #2 on: April 28, 2009, 10:46:09 PM »
DOHC
Dweezil
    • Michigan Civics
« Reply #3 on: April 28, 2009, 10:53:05 PM »
The DOHC is different enough from the SOHC where nothing but the crank, rods, and pistons swap so I'm going to guess block guards apply also.
txdohczc
« Reply #4 on: April 29, 2009, 09:41:25 PM »
man you dont want to fuck with a block gaurd
« Reply #5 on: April 29, 2009, 09:54:22 PM »
Nothing wrong with a block guard by current designs, been running one for years.
« Reply #6 on: April 29, 2009, 09:58:46 PM »
Yep. Just as long as you make sure you're cylinders are true AFTER installing it.
Zeniceguycrx
« Reply #7 on: April 30, 2009, 01:37:05 PM »
The ZC dohv has its own block guard
its ordered
The engine is being bored and honed after its installed
PARTIZAN
« Reply #8 on: May 02, 2009, 07:03:53 PM »
After block guard you have to remachine or rehone sleeves for sure, I had that problem. I recomand not to use it it won't realy help.
