Pages: 1 [2] 3 4 ... 22   Go Down
Author Topic: ~~~~~~~~~~~Blown turbo seals 9/15/10 Ratcityrex's B18a1 Build 296hp/289tq NO56k  (Read 488493 times)
Re: MY B18 BIG BLACK PROJECT........ 56k NO WAY!!!!!
« Reply #30 on: March 10, 2009, 02:36:03 PM »
Where you located at? We need to have an E. Washington mini meet or something.
Also, is your last name Stokes? I dated a chick who's last name was stokes. Twas a naughty bitch. :yes:
Im down for a meet just about anywhere in wa. And how the hell did you know my last name was Stokes?
Dude there is so many of us in the pnw I dont even know maybe 1/3 of my relitives. Where are you located at? I ran ito some chick in Thorp Wa. with the last name Stokes that was working the fruit stand there by the hwy. If I wasent married  :evil: But im not like that...lol
wow you must have some steady hand to lap those valves using a drill like that lmao
Man that thing was so off centerd it wanted to wobble all over the place, But when I kicked the drill int high gear it kinda self centered....lol X(
« Reply #31 on: March 10, 2009, 02:53:32 PM »
It says it on your crank, lol.
and I live in yakima, she does too.
« Reply #32 on: March 10, 2009, 03:51:42 PM »
I totaly forgot about that shit....lol
Dose her family have a ranch there? I have some family there that I have never meet. SO Im told
« Reply #33 on: March 10, 2009, 04:20:20 PM »
No idea. I only dated her for like 2 weeks, lol. Never even knew her parents names.
silverac
« Reply #34 on: March 15, 2009, 10:54:37 AM »
hey have u gotten tuned yet
PUERTO RICAN MADE, SOUTH BRONX BRED
« Reply #35 on: March 15, 2009, 01:31:39 PM »
I ran it N/A on the stock map and it ran great.
drunkinmaster1
« Reply #36 on: March 18, 2009, 09:40:36 AM »
keep up the good work. very clean build. that thing is going to make some nice torque
« Reply #37 on: March 18, 2009, 10:29:14 AM »
Well I have hit the rock bottom of my car account for this build. :-X im saving all my money to head to mexico in a month but when I get back here are some of the things im gona do.
So I still need to get a vw golf radiator to put in, new turbo center section, and I would also like a little bigger intercooler, so for now im going to thow it back together n/a :-[ put my 750's, my 3bar map, and my other fuel rail in and tune it that way.
turbo4life
Re: Ratcityrex's B18A1 Build........ 56k NO WAY!!!!!
« Reply #38 on: March 26, 2009, 12:45:21 PM »
n/a 750cc? am i reading corectly
End the fake food.
« Reply #39 on: March 26, 2009, 01:48:50 PM »
Yes sir, i said 750cc injectors. That way my whole n/a map will be dialed in and i will only have to tweek the vac. part of the map a little bit when i throw the turbo on ;)
« Reply #40 on: March 26, 2009, 01:53:38 PM »
I would bug 88dx about those delta cams I know he ran them
« Reply #41 on: March 26, 2009, 02:06:36 PM »
I bought his old skank2 spring that he was pushing to 8k on the delta cams. SO I know they Should hold up, hopfully
« Reply #42 on: March 26, 2009, 02:17:55 PM »
More like on getting them to idle etc. Unless your having Leed tune your motor
« Reply #43 on: March 26, 2009, 02:36:24 PM »
Fack it, Im gona get my basic tune down, and then give him a shout. I want to tune it myself and do some dyno pulls, and then swap to the deltas and see how much of a gain I really get.
« Reply #44 on: March 27, 2009, 12:06:32 AM »
hurry up with this shit already.   I had to stop my build for a minute
« Reply #45 on: March 27, 2009, 12:24:17 AM »
I ran the 272/260 like he has and they idled pretty good but the 2nd set i got 272/272  :-X They idled like a domestic and got about the same gas mileage  :?:
« Reply #46 on: March 27, 2009, 01:55:15 AM »
Why?
« Reply #47 on: April 18, 2009, 09:08:51 AM »
The 272s Wes campaigned in his otherwise stock B20B idled stock, made 159 whp.  A big engine makes a given cam "smaller," but I wasn't hugely impressed.
I'd rather find a used set of 403 (173 whp on LS with B16 pistons), 404 (170 whp on LS with B16 pistons, header with lower two primaries smashed half shut, and 2" exhaust), or the Brian Crower stage 3s (no dyno yet, but longer duration with slightly less lift and feels awesomeon LS with B16 pistons from 6500+ rpm, easy 190+ whp).
People get froke out by valvetrain prices but you can run stock steel retainers with most stuff (or you can with Z6 and Crower cam/springs), and with LS/ZC having easy valve upgrades available from other stock Honda engines it's really fucking cheap.
« Reply #48 on: April 18, 2009, 11:28:23 AM »
People also think cams are the end-all in making power where turbos are concerned.
« Reply #49 on: April 18, 2009, 04:57:32 PM »
Correct.  Cams are the end-all for making power where flow restriction is concerned.  So, that means all NA, or after a certain point with boost... say, 400-450 whp D-series, 300-550 LS (the early auto cams are crap), and 650+ B-VTEC.
edit:  I like cams earlier that the published figures (the ones I just published :P) for D16, LS, and B16, but it's not mandatory for D16 and one of the "better" $40 sets of OEM cams put LS and B16 in the same boat.
« Last Edit: April 18, 2009, 04:59:33 PM by Joseph Davis »
« Reply #50 on: April 18, 2009, 06:14:05 PM »
JD, thanks for kicking down the info in here. Im running out of time as the NW dyno meet is only about a month away. So im gona just throw the deltas in for now and tune them with a check valve in my wg line and tune the life out of the n/a area pull the check valve and go from there. Now one question i have is where do i set my aem cam gears at(i know aem but i got them brand new for $50) Do i just retard them both @ 2* or start at 0? When it comea to cams & cam gears im a noob all over. Everything ive seen is that you retard them. I know every setup is differant, but i have no clue where to start. Probably start a 0 and go from there when i get some dyno time.
BoostForLife
« Reply #51 on: April 19, 2009, 01:00:47 AM »
You're going to run your motor NA with the turbo on it? Are putting the check valve the to keep it open all the time? Makes sure to have a long enough dump tube then to tune idle.
caged
« Reply #52 on: April 19, 2009, 01:44:05 AM »
Iv never thort of that. sounds good.
« Reply #53 on: April 19, 2009, 02:30:21 AM »
Yep thats the idea, keeps it open so I can tune vac. Dump tube ties into my exhaust. No open wg rippers for me. But I do have a cutout on there and im thinking about using a old 75mm mustang tb ive got kicking around, and rigging a stock internal wg to open the tb cutout. Pure blackness!!!
Little trick my step dad used before. O0
« Last Edit: April 19, 2009, 02:34:24 AM by ratcityrex »
« Reply #54 on: April 19, 2009, 03:24:04 AM »
very nice sir, very nice.
Hopefully its ready to have boost for end of may
« Reply #55 on: April 19, 2009, 03:38:05 PM »
Oh it will be, basemap or not!!! I just got my Radiator on Thursday. And as soon as I get back from vacation on the 1st I'm ordering the intercooler and the inline radiator fill cap. I will be doing a write up on that too. How to get better cooling for a crx without running a halfcore all gangster leaned radiator and  tucking a larger radiator under the hood support and still keeping ground clearance. O0
 SHits gona be pimp son!!
« Reply #56 on: May 11, 2009, 06:50:49 PM »
Bump for AJ not having swine flu... Update O0
« Reply #57 on: May 13, 2009, 02:55:26 AM »
So I hate the gangster lean half core radiator that I have in my crx. And it started to leak some. I know that as soon as I boosted my car that it was going to overheat. I have seen it so many times, big boost, stock half core, and a b18 in a crx.  :-X But I need the room, whats a rhmt'er to do? So after alot of looking around I came up with this.
The radiator is 24.5"X12.5"X 1.5" Core is 1.5X12X20.5 = 369ci it also has 1 1/4" in and out, unlike the civic half core that has 1 1/8" also the stock half core core is around 1"X14"X14" 196ci
Radiator               $50 shipped
So the radiator is for a 85 Volkswagen Scirocco I got it frome here (the brand is Nissens part# W0133-1610603)
http://www.partsgeek.com/catalog/1985/volkswagen/scirocco/cooling_system/radiator.html
Inline Fill neck       $34 shipped
The inline neck I got from the seller TK Motorsports on ebay.
2- 5/16" grommets $1 w/tax
The rubber grommets I got from the ma and pa hardware store
Vented 13lb radiator cap I got from the local auto parts store
Radiator Cap         $7 w/tax
2- fender washers free, Had them on hand
Free
Fan temp switch (just to plug the hole in the radiator)
Free from the local wrecking yard
Total price $92
Call it a hundred or so.
On to the setup
It looked like this
SO first things first, drain your coolent and pull your shitty ass half core out.
Now that youve done that, you are going to need to mod your hood latch support bar. First score the 3 bolts where the latch assembly bolts up so you can get your hood to latch when your done.
Now pull the 3 10 mm bolts out, and squeeze the 2 plastic clips and and now your cable and latch us free from the support. Undo the 4 10mm bolts that hold the assemble to the headlight area, and the 1 10mm bolth that is attached to your lower support. Clamp it ito the vice, and now pull out the drill
Now I used a step bit to drill out the 4 spot welds that hold the upright support on, You will be getting rid of this to make room for your new radiator.
Now I used a flat head screw driver and worked it in between the support upright and the latch bar. I took my time on this because I did not want to bend the latch support up to bad.
Now go ahead and bolt the hood latch back onto the support bar and test your hood to make sure it closes and opens.
Ok with that done I now went onto the task of mounting on the tabs to hold the radiator in place.
So I took the 2 rubber grommets and slipped them into the washers and put them onto the bottom of the radiator.
and I held it upto where I needed it. I made some marks on the traction bar of where the washers hit it. I pulled the grommet out and tacked 1 of the washer into place with my welder. Let it cool down and put the grommit back in.
After I test fitted it, I double checked my other washer marks and pulled the grommet out and tacked the other washer into place.
Now I need to keep the top of the radiator from flopping around. So I had some scrap lying around.
Cut it down and drilled a hole in it. And grabbed a screw I had lying around too.
Now I saw just where I wanted it monted up.
Well with my awsome welding skillz :-* and some oil that I had sitting in between the sheetmetal from a previous busted oil feed line it turned out somthing like this  :-X :-X :-X :-X :-X :-X :-X
I used the stock 91 teg lower radiator hose and it worked perfect. For the upper hose I used 1 91 teg upper hose, and a piece of another teg upper hose.
Now there is a nipple off of the radiator so I took a vaccume cap and a hose clamp and threw it on there.
I then put my slim line fan on and put it back together.
Well see how it dose over the next few days but so far it seems great. and it tucks up under the support and out of the way of my turbo and downpipe.
Now I will be able to get my backdoor intercooler in there too, Just one step closer to being done.  ;)
caged
« Reply #58 on: May 13, 2009, 04:12:40 AM »
That radiator came up great :yes:. Good luck fitting the front mount in tho.
« Reply #59 on: May 13, 2009, 09:21:57 AM »
I already found it....
Now I just have to come up with the cash to pick it up :-\
Pages: 1 [2] 3 4 ... 22   Go Up
