Pages: 1 ... 17 18 [19] 20 21 22   Go Down
Author Topic: ~~~~~~~~~~~Blown turbo seals 9/15/10 Ratcityrex's B18a1 Build 296hp/289tq NO56k  (Read 488554 times)
Will there be any ripper vids from this tuning session?  ;D
Probably not, But maybe... IDK
Just gona tune vacuum and maybe clean up some of the boost area. I plan on doing most of the boost tuning on the dyno at the rhmt DD.  :D
« Last Edit: April 14, 2010, 02:44:58 PM by ratcityrex »
Awesome will see you there then. ;D
pictures asshole
your battery doesnt take that long to charge  :-*
pictures asshole
there you go levi  :-*
Seems to be working, Not really any leaks, but I will need to switch to some differant hose. As much as I would love to keep the garden hose. It just is way to mushy when it gets hot, and Im worryed that it will pull away from the an fittings once it gets too hot. So Malichite is gona kick me down some hoe's and all will be good.
Now im gona go get a breather that looks like this and put it in place of the filter that is on my catch can
And run a hose from it down between my stearing rack and firewall so I dont puke fromt he fumes this bitch is unleashing on me when I drive. My heater is on recerc, and its still is bad.
narfdanarf
what size fittings are those?  Since it's obviously not very much hose, I can spare some black braided -10 if you need it.
-10
2@ 12"
1@ 16"
yamaha6611
ratcity, please tell me all the info on those wheels/rims, i would like exactly that same combo for my crx, thanks!
I have no idea hat the wheels are. I bought them from Beau. All I know is they are supper light, and they fit. Other than that I dont know what you want to know. I know that the are 13" and they are 4X100
« Last Edit: April 17, 2010, 04:19:02 PM by ratcityrex »
Cant wait to see the numbers this bitch puts down!
Me too. I will have 5+gal of good gas for it the day of the dyno. So once we max out on pump. I will mix in some of the go juice for the rest of the tuning. I will eather make my clutch slip, max out the turbo, or blow up the motor. Hope its the maxing of the turbo though.
yamaha6611
ah i was looking for wheel offset, tire size thats about it
Well, I got my 1/0 gauge welding wire installed instead of the 8ga I had running from the alt, back to the kill switch. My shit idles rich now. So Ive only drove it about 10 min to work and that was about it. I need to do some logging now to see where its at now. I also need to put the interior back together now.
Next on the list of things to do
1. Install relay, and 10gauge wire to my fan
2. Install my 2 stage boost controller
3. Install my new catch can lines
4. Install my new catch can filter, and remote mount the hose that connects to the filter
now I need Leed to respond to my text messages to I can figure out where to meet up with him on sat for the street tune.
theidealone
If you still need that sealed filter, I have one, never used. Just send me enough to flat rate it. PM me if interested.
already picked one up nog, thanks though.
Possible for a vid on tune day?
I dont think so. Unless you want a vid in the dark. Night time vids, are not even worth it.
2slow
fucking copy cat
Its on motherfuckers!!! Got Leed all lined up to street tune this bitch on saturday night!  :evil:
You best update us afterwards
Dont worry, I will.  :-*
Well tuning has been rescheduled for the 11th. So It gives me a few mor days to inish up a few things.
Wire a relay for the fuel pump with larger wire.
Wire a relay with bigger wire for my fan.
Put my turboxs 2 stage boost controler in and wire it up.
And set up my new catchcan lines, and filter.
sa noochiest of the boochies noglet
Finished wiring the fuel pump with the relay, and grounded to the thermo housing as per JD...lol
Also wired the wideband to the ecu, and set up my 2 stage mbc.
Fail, that's just going to create noise on the ECU's sensor ground as the inherent capacitance from aluminum oxide gets tweaked by the pump.
I have specifically stated to ground all analog sensors that are logged through the ECU to the ECU's signal ground (thermostat housing for Hondas, IM for most other cars) and ground all electrical loads to the block.  I'm glad you listened to me, but please keep in mind that I am very specific for very specific reasons.
FUCK! Im trying to listen for once and I fucked it up....lol
Well if its a problem I will move the pump ground to something else. I will find out shortly enough.
Quit overcomplicating it for the poor RAT CITY nog.
Fuck you, Spiker.  He should be paying you in grande latte enemas for you to come over and help him with his build, and maybe fuck his wife/him/the dog while you're there.
the dog will stand for none of that!
Tune went awesome besides my fucked up 3bar. So we ended up using a 2.5bar. It went great Dave was amazed at how much timing the motor wanted. He also said he wasn't sure if I would even need the good gas for the nog tune. But I figured I would pick some up just for a buffer anyway. 4th gear rippers on some back roads are a little sketchy with the LS gearing.....lol
Pages: 1 ... 17 18 [19] 20 21 22   Go Up
