Author Topic: quick ghetto budjet set up d16y7 vf11 rhb5 boost  (Read 19713 times)
turbo4life
« on: April 30, 2009, 02:42:53 AM »
d16y7
y8 IM
dsm 450  + bov
ihi rhb5 vf11
hf + adapter
egay obd1 jumper
crx resistor box
3/16 hydrolic line oil feeed NAPA
flux core down pipe
silicone.. (ran out of jb weld
timing belt tensioner spring instead of actuator on swing valve allowing more that 10.5 psi at the spike  (no boost guage) just boost cut set at 11.2 maximum.. if i set it at 10.5 it cuts so im running about maybe 9 when it stablizes
« Last Edit: April 30, 2009, 03:00:21 AM by turbo4life »
End the fake food.
Re: quick ghetto budjet set up d16y7 vf11 rhb5 boost
« Reply #1 on: April 30, 2009, 04:45:23 AM »
Perfect
« Reply #2 on: April 30, 2009, 04:54:30 AM »
downpipe looks a little low huh? but at least its boosted
Evan
« Reply #3 on: April 30, 2009, 06:28:13 AM »
Thats a tiny turbo.
« Reply #4 on: April 30, 2009, 08:11:06 AM »
Nice budget boost. ;D
« Reply #5 on: April 30, 2009, 08:39:45 AM »
Do you have an intercooler?
lilpooh21186
« Reply #6 on: April 30, 2009, 08:53:42 AM »
set your boost cut to 10.8 at 11.2 it may not cut out for you
Ecu chipping
basmaps
speedjunky01
« Reply #7 on: April 30, 2009, 09:05:05 AM »
looks like shit, great job now back it up with porn
« Reply #8 on: April 30, 2009, 12:48:57 PM »
good shit..  now take it to my house for a ripper or 2.   come over so we can tune that shit and the b20 at the same time
snarf
« Reply #9 on: April 30, 2009, 02:04:29 PM »
NICE, Very gangsta.  What are you tuning it with?
« Reply #10 on: April 30, 2009, 05:33:57 PM »
vodka
« Reply #11 on: April 30, 2009, 10:29:40 PM »
Thats HMT as fuck
Looks good
boosted 00 black si
« Reply #12 on: April 30, 2009, 11:43:04 PM »
i love them weld rhmt  O0
go fuck your self
BORN TO BOOST
LITTLE B16.400whp on 16psi
turbo4life
« Reply #13 on: May 01, 2009, 04:38:55 AM »
the weld is  a deep weld but with a few pin holes in it. but it Rhmt not ht
tuning.. well that part was a bitch the spring conrtolled wastegate idea..
who said it wont cut at 11.2 you was rigth i was pushign 14 15 on the guage (put a boost guage one it)  some times and i would hear pining.. so i  running 2 springs in series now and its holding 10 11 psi stead boost cut set at 10.9 its working.. car is slow in frist and second but the 3rd gear pulls are really dirty tourque monsters  need to make a vid
NO IC want to put one on tomorow im running it dirty rich its for my friends brother..
inside story:  he is a man of destruction to transmission this is the 4th tranny in the car in a time of 3 years
before this the car got a mini me and he spun a bearing with in 2 months ..
i set the rev limiter at 6300 for a good reason this time..
and the intresting thing is when i set it at 5900 there was NO REV LIMIT
POSTED MY BIN FINE DOWN LOAD AND CHECK IT OUT ITS HELLA RICH AND NO TIMING  so he wont get too exited with it  afr in boost 10.4 to 11.3 in some place.. almost no tuning on this bitch!!! i only tune for fuel economy best part was i had 2 o2 sensor in it so i was able to enable close loop and i liked how it was holding 14.7-14.6 -14.8 and so  it did not need much low end tuning :) just call it a day
spark plugs:  NGk 6's   .026 gap
my tread might not make sense im way too tired!!! im out nogs enjoy
« Last Edit: May 01, 2009, 04:45:36 AM by turbo4life »
End the fake food.
« Reply #14 on: May 01, 2009, 04:17:33 PM »
This has to be the highest non-intercooled boost I've seen on ANY honda so far. How much faster than stock is it now?
BTW crome has FTS right? Set it way low so he can't power shift.
« Reply #15 on: May 01, 2009, 04:36:59 PM »
what is FTS?
lilpooh21186
« Reply #16 on: May 01, 2009, 04:56:27 PM »
full throttal shift
Ecu chipping
basmaps
« Reply #17 on: May 01, 2009, 05:02:34 PM »
is that running of max voltage of tps or a seperate switch like the micro swithes used for NOS activation?
lilpooh21186
« Reply #18 on: May 01, 2009, 05:12:28 PM »
you have to run a sperate switch
Ecu chipping
basmaps
BoostForLife
« Reply #19 on: May 01, 2009, 05:23:59 PM »
I think you have to wire in a clutch switch for FTS, right?
turbo4life
« Reply #20 on: May 05, 2009, 03:26:57 AM »
 it needs teh clutch switch input to activate the fts  (full  throttle shift)set up properly it saves your gear box and makes quick easy shifts
it detonated lightly a few times cuz the boost went up to 14 or so.. boost cuz dont really work when set at 11.2 psi when running stock map sensor
End the fake food.
BoostForLife
« Reply #21 on: May 05, 2009, 03:30:38 AM »
Yeah no shit, JD said it only reads to about 10.6, 11.2 is a number made up by Hondata fags.
turbo4life
« Reply #22 on: May 05, 2009, 03:39:25 AM »
ill make a note of it 10.6 but i have it set and 10.9 and it dose cut and did cut as i was adjusting the spring controlled wg flapper 2 spings did the trick
some one asked is it fast..
its dirty fast for what it is im far surprised  in 3rd gear pulls that is free way is best for this thing 1- 2nd is mild.. only has power till 5500 rpm.. small ass turbo exhaust ect
End the fake food.
BoostForLife
« Reply #23 on: May 05, 2009, 03:42:58 AM »
is it just blowing really hot air after 5500? You're still not intercooled right?
turbo4life
« Reply #24 on: May 05, 2009, 03:46:05 AM »
nope no ic yet on it  yes hot air (say it like black people on the radio) hot air dam turbo is far out of efficency up at high rpm
End the fake food.
