Author Topic: any basemap plz?  (Read 12624 times)
walter
any basemap plz?
« on: November 09, 2012, 07:25:38 PM »
D16 12:1 , not sure if you have some screenshoots of timing maps around there , lmk
Thanks!
Re: any basemap plz?
« Reply #1 on: November 10, 2012, 01:43:58 PM »
Vtec? Cam(s)?
walter
« Reply #2 on: November 10, 2012, 08:15:22 PM »
sorry , Z6 w/ 59300 zex and p29 pistons.
JaredKaragen
« Reply #3 on: November 10, 2012, 09:40:24 PM »
Generally you won't see above 20-22* of timing in the 10psi range; other than that you should build and tune a regular basemap to get going
Injectors and can make it basically a crapshoot wether it will run at first or not.
walter
« Reply #4 on: November 10, 2012, 10:35:14 PM »
engine will runs NA only. not boosted. thanks for your reply!
« Reply #5 on: November 15, 2012, 04:16:55 AM »
obd-0/1?
walter
« Reply #6 on: November 17, 2012, 10:14:11 AM »
It's EG D16z6 with crome gold.i will try to post some screenshoots of timing map this week. anyway if someone has a tuned map just for reference i'd appreciate it a lot.
thanks!
walter
« Reply #7 on: November 20, 2012, 06:43:46 PM »
i will post a screenshoot of low cam timing map tonight, sometimes it knock and sometimes it doesnt in small areas, i think problem could be in spark plugs i will try with 7 heat range..i have to say too i had to retarded about 12-13 degrees... :-\
