Pages: 1 ... 5 6 [7] 8 9 ... 12   Go Down
Author Topic: **2014 June 28/29 RHMT/TT.NET DIRTY SOUTH MEET/DYNO DAY AND 88DX FUNDRAISER!***  (Read 259291 times)
Since WOT is fine, IDK why you're bitching.
^THIS^
IDK might have to do with the 1500 mile round trip....
Change the trans filter last night and put fresh oil. Seems to be a lot better now but I can still feel it. Trans temps seem to be a bit higher then they should be. Then this morning the alt desisted to die on the way to work. :P
This is why I do not like buying Chevy, ford, or dodge; they always have stupid shit like this failing.
An Alt, starter, fuel pump, and other common parts should not fail every 100k or so, ever!!!!  :noel:
/rant
Has around 180k, this will be the 3rd alt. No starters have been changed. Other wise its been a solid truck that I tow with a hand full of times per year.
BTW if you have not replaced the fuel filter in the last 15k and pump in the last 50k, get ready to.  :?:
Exactly why I have not owned a Domestic for a long time (not including my free '82 GT 'Stang).  :noel:
Fuel filter around 150k :noel:
I think they fixed the in tank feeder pump problem with the blue/green plug ECU trucks.
Its not like Hondas ever shit MR/dist/ignitor/coil, Russ.  All vehicles have problems.
I agree, when I was in the retail parts business those common problem kept me busy selling parts.  :noel:
8 days left!
Crx
Trans is back in
Rear cross memeber beef up
Front suspension bushings all swap
Front end re installed
Need to install linage
Swap oil pans
Redo return line
Reinstall all the reaer suspension
Yukon
Replace dead alt
Change all the fluids
Went over the brakes
Need 2 tires
Some much work and so little time :-X :noel:
I think every suspension piece on my jetta just failed at once
Maybe that's why the vdub boys go all "hella flush".
Less suspension to break....
Theres no way there's any logic behind herra frush.
Im on the prowl for a new ride.
Maybe hella flush is just broken and not a mod?
carkrazed
Sell ya a sweet 5 speed 850R. I'll even deliver it to the meet.
Head gasket not included.
nopeeeee. looking at gs/is lexus or a truck
carkrazed
I should have known you weren't cool enough to drive a 4 door volvo
next weekend bitches!
Gold DA9
  • OG LURKER
$5
$5
Crx is ready!
Yukon is not :-X.....
Wont shift into 4th, slight oil leak from the trans oil cooler fittings on the rad. Could this cause it not to shift into 4th?
$15
Crx is ready!
$5
Crx is ready!
A slight leak, no.  Do you have any CELs?
Throw tag on CRX
Drive it down
Take money saved on fuel and spend it on hookers and blow.
Rent truck, disconnect speedo so you don't pay mileage, ribs are on me.
Speed Phreak
  • I'm an OG because I say so.
I want a shirt and a sticker, find me one or suffer my less than infinite sarcasm.
1988 CRX HF - Turbo deathtrap
I'll be showing up tomorrow after work.
Who else?
carkrazed
Who else?
I'm leaving PA at 8 in the am. Should be in Asheville around 5. Staying at the Homewood Suites on Tunnel Road.
Should be down there tomorrow sharp
Paz is already in NC, albeit some ways away yet.
Speed Phreak
I'll be there Saturday AM, someone better have my fking waffles fixed by the time I arrive.
I'll be there somewhere between 7 and 8 depending on when I can get out of work.
Paz tow the crx down with the ho? It doing ok?
  €====8
Got foowees stuff loaded and were about to roll
I've got the untaxed on ice.
*winning*
*winning*
I would have to say........ That is a WIN
Pages: 1 ... 5 6 [7] 8 9 ... 12   Go Up
