Author Topic: gsr crx burning oil very badly... boost it?  (Read 29608 times)
crx-ecutioner313
Re: gsr crx burning oil very badly... boost it?
« Reply #30 on: May 14, 2009, 03:41:55 AM »
sorry for all here bad news i just had my 350 million mile toyota paseo crushed ...thank god... now im forced to drive my 88 crx that sucks im gonna miss my 55 hp and that endless cloud of smoke and the bmw type smooth ride it had
« Reply #31 on: May 17, 2009, 03:25:19 AM »
mission accomplished  8)
buk9tp
« Reply #32 on: May 17, 2009, 03:38:43 AM »
well i think i found the leak...
will double check it tomorrow by hosing the fucker off with parts cleaner and then driving the fuck out of it...
but yeah oil pan in a really fucked up place... but it doesnt leak on the ground so my guess it only leaks while driving????????????
esi42
« Reply #33 on: May 17, 2009, 05:59:13 AM »
Ive had it leak at the honda bond seal bewteen the oil pump and block.  Ive also had the oring between the oil pump and block go out.  Hard to tell the difference bewteen those and an oil pan leak.  These leaks sort of spray on the alternator and get the whole pan wet on that side.
I was using oil in my rebuilt ZC and it turned out my PCV valve was clogged.   Switched to a catch-can setup and that fixed the issue.
My last d16a1 had great compression across all four cylinders, pulled hard to redline.  Used 12 qts in 3000 miles.  Fricken smokeshow.  I think it was the first d16a1 ever made lol.   Pulled the pistons and the oil rings were collapsed while the other rings looked ok.  Could be related to something like that.  This was obivous though.  My car was like Pigpen with his little cloud following him around.
« Reply #34 on: May 17, 2009, 12:26:18 PM »
One of my friends works at a Honda/Acura dealer alternative, he sees that a lot.  He suspects he can carb spray the gunk out of the oil control rings and put everything back together and it'd work fine.
« Reply #35 on: May 17, 2009, 01:06:18 PM »
Idk the mustang guy said it could be a vtek crack over issue...  i'd look there before I go tearing apart the bottom end.
« Reply #36 on: May 17, 2009, 01:30:41 PM »
EXACTLY!!! its such an obvious problem, i would def look there first.
« Reply #37 on: May 17, 2009, 03:03:22 PM »
I defer to the Mustang guy, as four cyls ain't got no goddamn torque + are a waste of time.
buk9tp
« Reply #38 on: May 17, 2009, 03:42:47 PM »
i have a catch can but too lazy to figure out how to install it :p
esi42
« Reply #39 on: May 25, 2009, 04:29:25 AM »
Try it first.  Cheapest fix if it works. Search around here, there tons of info on that.
Lazy way:
Gut the pcv valve, reinstall in manifold, attach hose and run to catch can.  Then run the valve cover breather hose to another port on the can too.  Plug the port on the manifold where the old pcv hose went.  Plug the intake pipe port where the VC hose went.  Hopefully your can has a breather filter on it.
Theres a better way where you keep the pcv valve in tact, but the writeup was on ohmt.  I dont know if it made its way over.
I saw another writeup using the exhuast to draw the pressure out, like old v8 guys do.  Probably the best way but the most cost/labor involved.
nig nog
  • rhmt equalizer
« Reply #40 on: June 04, 2009, 03:28:56 PM »
bump
1991 F-150 351W E-cam hedders
1988 Merkur XR4ti .50 T3/T4
2003 S2000
