Author Topic: making intake manifold  (Read 38777 times)
walter
« on: May 14, 2013, 11:27:00 AM »
Hi guys, im designing an intake manifold i have to fab for a VW 20Vt big port, i will keep stock runners but i will make a new plenum, ok, problem im having is 4Cyl isnt getting enought flow than the other cylinders..im trying to get the best design for to get it , trying and dont get it..gave some degrees to throttle body, wrong, change sizes of plenung..not luck..not sure if anyone can give me some tips...
here is some vids..
first test - flow simulation
Prueba 2
Colector Prueba 3
What do you think?
walter
Re: making intake manifold
« Reply #2 on: May 15, 2013, 08:12:02 AM »
after to many tests, got this..
Colector Prueba 7
i'd like to learn more about this, measure each port and so but this will give me a good advice so far.
« Reply #3 on: May 16, 2013, 07:35:00 AM »
Taper the back end to removr the turbulance and increase velosity. The long runners are going to shift your powerband down lower (which is probably where you want it in a 1.8t since vw motors all have longass strokes factory.)
walter
« Reply #4 on: May 16, 2013, 08:51:47 AM »
these runners are only for to see what flow/density is get , distance is similar to the stock runners i will keep.
This s the final test..
Colector Prueba final
I hope to get soon materials designet for welding everything.
I will post pics soon.
Thanks!
« Reply #5 on: May 16, 2013, 09:12:30 AM »
Walter, what flow modeling program are you using?
What format CAD drawing can it import?
Is it a free program?
walter
« Reply #6 on: May 16, 2013, 04:59:54 PM »
Hi, i use solidworks, and it's solidworks flow simulation..still learning  :-[
« Reply #7 on: May 16, 2013, 05:26:37 PM »
Kool, I did not know Solidworks has a flow simulation.  :noel:
walter
« Reply #8 on: May 17, 2013, 08:43:18 AM »
i think you can do whatever ...
Quad Bike Simulation in SolidWorks
« Reply #9 on: May 19, 2013, 03:26:32 AM »
Solidworks is awesome, but the Finite Element Analysis portion isn't especially good (meaning, not especially close to real life).
« Reply #10 on: May 20, 2013, 08:26:38 AM »
walter
« Reply #11 on: June 02, 2013, 02:55:38 PM »
idk to much about that info really.. well finally got parts i ordered, laser cut aluminium parts..
p.s. remove these killer gifs!!!
walter
« Reply #12 on: June 08, 2013, 06:19:04 PM »
i hope you like this work!  :)
70challenger
« Reply #13 on: June 19, 2013, 12:52:17 PM »
nice work
now make me one for a 2.7t  ;DDD
« Reply #14 on: June 19, 2013, 02:23:04 PM »
Looks good Walter.
FreshDA9
« Reply #15 on: December 04, 2013, 02:55:44 AM »
Can that simulation also be done in Autocad/Autodesk? im actually taking a drafting class next semester and wanted to see some flow simulation on an intake manifold idea i wanna try on my car. If its only a Solidworks thing ima have to grab a torrent and try it out.  :noel:
DSharp
« Reply #16 on: December 08, 2013, 01:41:03 PM »
