Author Topic: any pipe sander/polisher?  (Read 40977 times)
walter
« on: June 29, 2013, 09:44:16 PM »
anyone have made a homemade pipe sander/polisher? im looking for make one..these are too expensive to get one ...
Re: any pipe sander/polisher?
« Reply #1 on: June 29, 2013, 11:10:15 PM »
walter
« Reply #2 on: June 30, 2013, 08:40:52 AM »
i meant for doing something like this..
idk why these fucking pieces are too expensive!
« Reply #3 on: June 30, 2013, 08:44:01 AM »
Make your own, all ya need is an angle grinder and a polishing pad/disc to do the same thing as that.  :noel:
walter
« Reply #4 on: June 30, 2013, 08:58:35 AM »
yeah but what i was looking is for the "spring/adjustable pieces" that it use..
« Reply #5 on: June 30, 2013, 11:29:20 PM »
grab a timing belt tensioner off something
walter
« Reply #6 on: July 13, 2013, 09:54:45 PM »
finally i will buy this pieces..
Episodio 4: "Pulir y satinar tubo redondo"
i will post some pictures soon when i receive the parts and polish some tubes!
« Reply #7 on: July 13, 2013, 11:49:19 PM »
Looks pretty straight forward. How much is it in America $$?
« Reply #8 on: July 14, 2013, 12:07:52 AM »
Build one and rock belt sander belts?
walter
« Reply #9 on: July 14, 2013, 07:27:17 PM »
i called them since they are frmo spain, roller cost around 90Euros (115$ or so) and belts around 10euro (13$), they have a some special belts that looks great, i will try to order everything this week!.  if i had a milling machine or lathe i'd make it myselft but i havent time and im pretty sure it cost more that some machinist make one of these.. that roller come with something like poliurethane ...
walter
« Reply #11 on: July 15, 2013, 08:38:52 AM »
110v only  :'(
« Reply #12 on: July 15, 2013, 09:39:31 AM »
What does Spain have? 220v? There has to be a way to make that work. That's a much better option over making one that costs more money
« Reply #13 on: July 15, 2013, 11:56:43 AM »
http://www.controlledpwr.com/help-international-voltages.php
220v/50hz  :noel:
walter
« Reply #14 on: July 15, 2013, 03:17:35 PM »
yes, it's possible but it will cost more than machine cost to convert 110v to 220v. i know this because i got ago long time a chopsaw and i have there not used for that reason..
anyway ive ordered already roller and special band saws.. i will let you know soon!
walter
« Reply #15 on: July 18, 2013, 10:42:24 AM »
received it, roller and some bands, they missed some another bands, i will test it this week!.
walter
« Reply #16 on: July 26, 2013, 07:53:04 PM »
Steel
Alu
works really great! i have to practice more for bends with small radious but it works great!
« Reply #17 on: July 27, 2013, 06:49:53 PM »
Did you build one or buy it? Pics of machine?
walter
« Reply #18 on: July 27, 2013, 07:25:59 PM »
bought the roller and sands...
another pic..
« Reply #19 on: October 05, 2013, 12:29:41 PM »
https://www.google.com/#newwindow=1&q=240+volt+variac&tbm=shop
I was going to tell you to buy one of these, but didn't realize how much they cost.
I use them at work to test line regulation.
Most electronics that are made for 60hz work fine on 50hz. If you can get the voltage down to 120, you should be able to run any US shit.
« Reply #20 on: October 05, 2013, 12:34:06 PM »
Unless you happen to be not afraid to run one of these
http://www.ebay.com/itm/New-40A-110V-220V-Power-Adjustable-Thyristor-Transform-4KW-PWM-Speed-Control-/251349987898?pt=LH_DefaultDomain_0&hash=item3a85a0723a
(my guess is that it would last about 2ms at 40 amps).
« Reply #21 on: October 08, 2013, 05:19:22 PM »
seems stupid easy to make .  weld a 5/8 nut to some shit like a pully with rubber on it, then flip belt sander belts inside out and thats about it
