Author Topic: F22a1 valve springs  (Read 12654 times)
F22a1 valve springs
« on: July 11, 2013, 12:15:39 PM »
Building a new motor on the dirty cheap. Any oem valve spring upgrade that will drop in besides the f22a6 valve springs? Worried about valve float at higher rev's and boost.
Re: F22a1 valve springs
« Reply #1 on: July 31, 2013, 11:09:59 PM »
Find out your coil bind lift numbers, then shim them a to a safe amount below that number. Only use hardened shims, or at the very worst use them for the top & bottom shims.
« Reply #2 on: August 01, 2013, 09:46:42 AM »
I was thinking about that but since these are oem springs with untold miles idk if it would be a good idea :-\
