Author Topic: Milling block deck and cam timing  (Read 47804 times)
« on: March 08, 2009, 05:17:06 PM »
If I mill the block deck ~0.01 to 0.02 in what should adjust my cam offset by?
My setup
D16z6 block
D16z6 3-layer head gasket
D16y8 head
Vitaras 0.5mm o/s
TT rods with new rod bolts
SC14 supercharger and later a T04b s-trim turbo or something larger for a twincharge setup.
Acccording to the http://www.zealautowerks.com/dseries.html I would have too mill 0.02in
 of block to get 8.0:1 comp which I think I may need b/c I live at elev. of 5000ft and higher.
Re: Milling block deck and cam timing
« Reply #1 on: March 08, 2009, 05:18:59 PM »
Fuck it run it as is. I dont think it would be a huge differance. ():)
« Reply #2 on: March 08, 2009, 05:24:39 PM »
I remeber reading somewhere a while back that for every 0.010 milled of your suppose to offset the cam timing a degree or two. but I do not remember the source.
CRX304
  • lick my gooch
    • My Music
« Reply #3 on: March 08, 2009, 06:48:31 PM »
grab a timing light and adj accordinly... in my vitera w/ Z6 head I milled .050" (yup) and it was 4 degrees
sorry if ur F'#39#39in retarded...95% of the ppl I meet are just like you
I.C.A.R. www.myspace.com/Imlaycityauto
My old CRX :
http://www.xceedspeed.com/forums/showthread.php?t=110829
« Reply #4 on: March 08, 2009, 08:09:03 PM »
milled 0.050 in damn here I thought 0.020 was a lot ;D
thanks for the info.
« Reply #5 on: March 08, 2009, 08:39:33 PM »
Can you elaborate a litte more on how you did this? You used a ign. timing lite to check your cam timing? ???
lilpooh21186
« Reply #6 on: March 08, 2009, 08:52:57 PM »
with your 3layer hg what is the thickness it may be thick enough to offset the mill
Ecu chipping
basmaps
« Reply #9 on: March 08, 2009, 09:40:24 PM »
Fuck and there is HT with tech and rHMT without, growing pains.
« Reply #10 on: March 16, 2009, 04:31:47 AM »
D series 1mm (.039") = 1 degree
« Reply #11 on: March 16, 2009, 09:58:09 AM »
I remember seeing that some where?
I am assuming cam timing you are refering to.
