Pages: 1 [2] 3   Go Down
Author Topic: Cooper F22A  (Read 97642 times)
Re: Cooper F22A
« Reply #30 on: November 01, 2013, 10:02:30 PM »
He's just sour Bisi didn't pick JD to "break in" the back seat with him.
Re: Cooper F22A
« Reply #31 on: November 05, 2013, 12:34:34 PM »
Wut?
+2
Bisi never used stock parts, or made real power.  Sorry.
Come tune your car, hippie.
yea what ever, you know you wanna ride the bisi band-wagovan.
Rx7toCivic
Re: Cooper F22A
« Reply #32 on: November 08, 2013, 05:34:11 PM »
wat
DSharp
Re: Cooper F22A
« Reply #33 on: November 09, 2013, 12:39:01 AM »
I've done more DE-tuning here recently.
Re: Cooper F22A
« Reply #34 on: November 27, 2013, 10:51:17 PM »
H2B??
What IM??
Any pics of the ground clearance and the hood closed!
Sweet execution.
Re: Cooper F22A
« Reply #35 on: November 28, 2013, 08:27:24 AM »
Leans too far back for F2B, gotta be H or F tranny.
JD implied RBC intake.
Re: Cooper F22A
« Reply #36 on: November 29, 2013, 05:33:36 PM »
H2B??
There are no H or B parts used.  Reread title.  F22A.
What IM??
K20A2.  It's a direct bolt on.
Hood closes, I think it has washers stacked at the hinges but nothing radical.  Not sure the washers are for engine clearance.
Oil pan hangs a bit low, but it's nothing that has been a problem.  F-Tuned crossmember is as low, or close enough to make that claim, and car is on Eibach Pro-kit springs.  Not stock, not slammed, still has suspension travel.
krazy4
Re: Cooper F22A
« Reply #37 on: November 29, 2013, 10:20:02 PM »
Stock cam?
Sweet build, love it.
Re: Cooper F22A
« Reply #38 on: November 29, 2013, 11:28:08 PM »
f2b h2b same shit you know this because you are not a twit.
Good shit JD.  With that IM clearance, I think I'm going to do this with the ED once the turbo D15B2 comes out or blows up... But with the RHMT H2B setup with no adapter plate.  Like it should be done.  The way of the champions.
Re: Cooper F22A
« Reply #39 on: December 01, 2013, 10:19:32 PM »
Ok back for some more...
Hard to see in the radical cell phone pics.
What throttle body?  K i assume? map sensor plumbed into the IM im guessing?  running an IACV?
Whats the deal with the fuel rail?  F series redrilled or rigged to mount up some how i assume?
If I can find a cheap RBC (looks like you are using a PRB actually my bad) im going to try this.  It looks like it makes it so much more space friendly for an ED. Or is it just an illusion and the H22 or F22 IM gives just as much room?
I bought my trans today.
« Last Edit: December 02, 2013, 12:43:12 AM by danz »
Re: Cooper F22A
« Reply #40 on: December 01, 2013, 11:39:31 PM »
Skunk2 makes an adaptor to run a cable TB on the rbc. There are also bolt on fuel rail options out there.
I did an h2b with the qsd kit along with rbc intake also using a qsd plate. Both of those qsd products were a joke, but that's off topic. I made the fuel rail from extruded fuel rail stock from Ross Machine Racing.
Re: Cooper F22A
« Reply #41 on: December 07, 2013, 03:18:40 PM »
Stubbs what was your beef with the QSD h2k plate?
JD, fine ill do all the work myself.  Looks pretty straight forward anyways.  Should have a lots of space with the B series trans and my K24 accord TB should bolt right up.  Remote IACV, MAP sensor in the IM, and perhaps a TPS adapter or a new K series TPS since mine is busted.
Re: Cooper F22A
« Reply #42 on: December 07, 2013, 06:36:12 PM »
Nothing that can't easily be fixed, but for the money you shouldn't have to. The bolts that hold it to the head had to be ground on to fit and the ports were really shitty. I spent an hour on it with a die grinder to be acceptable. Not even perfectly matching.
« Last Edit: December 08, 2013, 06:36:27 PM by PhilStubbs »
Re: Cooper F22A
« Reply #43 on: December 08, 2013, 03:12:57 PM »
So for $50 less, the skunk2 will probably be a better product and cheaper?  I hate supporting those fucks tho.
Re: Cooper F22A
« Reply #44 on: December 08, 2013, 06:24:33 PM »
Yes, the IM is a direct bolt on.  Plenty of room.
What throttle body?
Probably the stock F.  Maybe a B-series.  The only thing K purchased was the PRB intake manifold.  Direct bolt on!
Bore/inj spacing is all the same, IIRC the H23 rail was the same bolt pattern.  Or, close enough to oval a hole and make it work.  Or Coop drilled an extra hole in his existing one.  I'm pretty sure I gave him the rail off my old inj test bench (H23 lower and rail) but can't remember.
Re: Cooper F22A
« Reply #45 on: December 08, 2013, 06:37:39 PM »
Are the F's like D's where all intake bolt patterns are the same? I wonder if I could go K on my vtec f23
Re: Cooper F22A
« Reply #46 on: December 08, 2013, 07:27:01 PM »
Not all of them, but most I think.
DSharp
Re: Cooper F22A
« Reply #47 on: December 09, 2013, 01:57:43 AM »
From what I remember...
F22aX, h23(non-vtec), f22b(JDM) motors all have same bolt pattern. more recent f22's such as the f22bX and f23 are different from the F22aX.
Re: Cooper F22A
« Reply #48 on: December 09, 2013, 07:18:57 AM »
This link shows a K20 intake manifold gasket on an F22A cylinder head:
http://www.onecamonly.com/showthread.php?t=2600
The outer holes won't be usable, so you may want to use the lightest coating of Hondabond. It looks like you just have to dill new holes, grind a little near the coolant port, then tap the port for a nipple. The runner shapes are nearly identical, enough so you won't have to do much if any port-matching.
Re: Cooper F22A
« Reply #49 on: December 09, 2013, 11:20:21 PM »
I dont really use gaskets for much anymore when machined surfaces are in play.  RTV ftw.  :D
TY for the link.  off to read!
And thanks for the updates JD, much appreciated.
You guys know ill do this swap justice.
Re: Cooper F22A
« Reply #50 on: December 30, 2013, 11:28:44 AM »
Obviously a direct bolt on!  Nothing to it.
Fixed.
Re: Cooper F22A
« Reply #51 on: December 31, 2013, 07:04:35 PM »
Fixed.
Not as direct as sliders for tuning!
Re: Cooper F22A
« Reply #52 on: February 08, 2014, 11:51:00 PM »
MOAR direct bolt on coming to a trailerpark near you soon...
Re: Cooper F22A
« Reply #53 on: February 13, 2014, 12:11:46 AM »
Cooper had to redesign the cable to hydro conversion.  Look closely, the revision is subtle.
Re: Cooper F22A
« Reply #54 on: February 13, 2014, 12:51:05 AM »
Jesus christ
Re: Cooper F22A
« Reply #55 on: February 13, 2014, 01:25:36 AM »
I love the fact that the bracket is welded to the body....lol pure trailer park there. I love it.
Re: Cooper F22A
« Reply #56 on: February 13, 2014, 02:42:14 AM »
awesome
Re: Cooper F22A
« Reply #57 on: February 13, 2014, 09:56:46 AM »
WOW, how I missed that in the first few pics is amazing. JD, only YOU would say "yes, I'll do the tuning" to a car like that. Fuck yeah.
Re: Cooper F22A
« Reply #58 on: February 14, 2014, 11:47:56 AM »
I busted out laughing when he texted me that :noel:
Re: Cooper F22A
« Reply #59 on: March 02, 2014, 03:43:13 PM »
Was there a specific reason he didnt use a cable B series trans?  Just curious.
Pages: 1 [2] 3   Go Up
